Chrome window gets chopped off after resizing/changing window size
So there is like a wierd issue with chrome where the tabs or other elements of the window disappear,
and goes back after it gets updated
Chrome Flags
--use-vulkan --enable-accelerated-video-decode --use-gl=desktop
--password-store=kwallet5 --no-sandbox --disable-gpu-driver-bug-workarounds
--ignore-gpu-blocklist --enable-gpu-rasterization --enable-zero-copy
--ozone-platform-hint=auto --disable-gpu-sandbox
--enable-features=WebUIDarkMode,VaapiVideoEncoder,VaapiVideoDecoder,CanvasOopRasterization
--force-dark-mode
--disable-features=UseSkiaRenderer,UseChromeOSDirectVideoDecoder
Enable the Use system title bars and folders
If is not working from right click, create a Window Rule in Settings - select the No titlebar and frame - set it to Force and to No …
Remove that and restart Chrome.
Unfortunately that, didn’t work
Also didn’t work
Removing --use-gl somehow fixed it, when previously testing I didn’t remove ones that
didn’t look troublesome
Removing --use-gl=desktop makes videos turn black if the window is not focused
Do I rename the thread or create a new one?
