$ npm ls
wifi-switch@0.0.0 /path/to/nodejs-project
├── chromium@3.0.2
├── puppeteer@10.0.0
└── typescript@4.3.4
$ cd node_modules/puppeteer/.local-chromium/linux-884014
$ ./chrome --version
Chromium 92.0.4512.0
$ ./chrome
(chrome:6958): Gtk-WARNING **: 20:57:08.534: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
Opening in existing browser session.
As a result the default chromium browser runs instead, which I installed manually for daily use, and the version is 91.0.4472.77 .
It’s not just a warning when the default chromium (say A) in system for daily is running, in this case try to run chromium in node_modules will launch A as the warning shows.
It’s just a warning if no A is running.
What I expect is that by running chromium in node_modules will run itself anyway.
