Hello,
Chrome is crashing after 5-10 seconds. I made a shortcut to desktop and I ran it from terminal to catch the error. Fresh install (today) fully updated.
Not sure if it is related but when I installed it, it was running fine but at some point I got a notification that it is running on the background and from the two options of “Allow” and “Force Stop” or something like this, I hit the latter as I was about to restart the laptop anyways. I installed Google Chrome with Flatpak. Never worked after that. I see from the error that it is kwallet related?! I tried to disabled kwallet but issue exists.
I am new to Manjaro and Linux, if you need more info please let me know. Please the console error below.
Many thanks in advance.
Error:
(cobalt:2): Gdk-WARNING **: 20:06:16.107: Failed to read portal settings: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.portal.Settings” on object at path /org/freedesktop/portal/desktop
Stub sandbox ignoring command: /app/extra/nacl_helper
[2:2:0526/200616.347311:ERROR:nacl_fork_delegate_linux.cc(313)] Bad NaCl helper startup ack (0 bytes)
[2:43:0526/200616.405077:ERROR:object_proxy.cc(623)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.InvalidArgs: No such interface “org.freedesktop.portal.FileChooser”
[2:43:0526/200616.405095:ERROR:select_file_dialog_linux_portal.cc(274)] Failed to read portal version property
[2:2:0526/200616.407847:ERROR:object_proxy.cc(623)] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd5: org.freedesktop.DBus.Error.ServiceUnknown: org.freedesktop.DBus.Error.ServiceUnknown
[2:2:0526/200616.407860:ERROR:kwallet_dbus.cc(100)] Error contacting kwalletd5 (isEnabled)
[2:2:0526/200616.408026:ERROR:object_proxy.cc(623)] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: org.freedesktop.DBus.Error.ServiceUnknown
[2:2:0526/200616.408030:ERROR:kwallet_dbus.cc(72)] Error contacting klauncher to start kwalletd5
[2:2:0526/200616.408168:ERROR:object_proxy.cc(623)] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd5: org.freedesktop.DBus.Error.ServiceUnknown: org.freedesktop.DBus.Error.ServiceUnknown
[2:2:0526/200616.408172:ERROR:kwallet_dbus.cc(452)] Error contacting kwalletd5 (close)
[2:2:0526/200616.528846:ERROR:nacl_browser.cc(288)] Failed to open NaCl IRT file "/app/extra/nacl_irt_x86_64.nexe": -4
[57:57:0526/200620.662902:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
~/Desktop
