After the “2022-05-13 Stable Update” the Chrome based browsers, like Chromium and Brave started to crash when I try to screen share with the “WebRTC PipeWire support” flag activated.
The “journalctl” command shows:
mai 14 11:08:32 rz3h-odin xdg-desktop-por[1617]: Unhandled parent window type
mai 14 11:08:32 rz3h-odin xdg-desktop-por[1617]: Failed to associate portal window with parent window
mai 14 11:08:36 rz3h-odin chromium.desktop[8054]: [8054:8775:0514/110836.230861:ERROR:egl_dmabuf.cc(569)] Failed to record frame: Error creating EGLImage - EGL_BAD_ALLOC
mai 14 11:08:36 rz3h-odin chromium.desktop[8054]: [8054:8775:0514/110836.230881:ERROR:shared_screencast_stream.cc(716)] Dropping DMA-BUF modifier: 72057594037927935 and trying to renegotiate stream parameters
mai 14 11:08:36 rz3h-odin chromium.desktop[8078]: [0514/110836.241406:ERROR:elf_dynamic_array_reader.h(64)] tag not found
mai 14 11:08:36 rz3h-odin chromium.desktop[8078]: [0514/110836.242129:ERROR:elf_dynamic_array_reader.h(64)] tag not found
mai 14 11:08:36 rz3h-odin audit[8054]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=8054 comm="pipewire-main-l" exe="/usr/lib/chromium/chromium" sig=4 res=1
mai 14 11:08:36 rz3h-odin kernel: audit: type=1701 audit(1652537316.266:166): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=8054 comm="pipewire-main-l" exe="/usr/lib/chromium/chromium" sig=4 res=1
mai 14 11:08:36 rz3h-odin audit: BPF prog-id=44 op=LOAD
mai 14 11:08:36 rz3h-odin audit: BPF prog-id=45 op=LOAD
mai 14 11:08:36 rz3h-odin audit: BPF prog-id=46 op=LOAD
mai 14 11:08:36 rz3h-odin systemd[1]: Started Process Core Dump (PID 8776/UID 0).
mai 14 11:08:36 rz3h-odin audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-8776-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 14 11:08:36 rz3h-odin kernel: audit: type=1334 audit(1652537316.276:167): prog-id=44 op=LOAD
mai 14 11:08:36 rz3h-odin kernel: audit: type=1334 audit(1652537316.276:168): prog-id=45 op=LOAD
mai 14 11:08:36 rz3h-odin kernel: audit: type=1334 audit(1652537316.276:169): prog-id=46 op=LOAD
mai 14 11:08:36 rz3h-odin kernel: audit: type=1130 audit(1652537316.276:170): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-8776-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 14 11:08:37 rz3h-odin systemd-coredump[8777]: [🡕] Process 8054 (chromium) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 21dd0b95b6d40459fda840e512d3ee4b5e26d389
Module libpipewire-module-session-manager.so with build-id a8dd22452163c6fe8a1cec2dda1de09dff045131
Module libpipewire-module-metadata.so with build-id 4791ffb1a132def0b129df6796acc670075ec405
Module libpipewire-module-adapter.so with build-id 512418faadc6d6e5c52e9d3f3a9a922f6233dfb7
Module libpipewire-module-client-device.so with build-id cbdfcf15d7c4615115c2ff49606b3adff262094c
Module libpipewire-module-client-node.so with build-id b64fc2092f50aa279a575405708d7c0507e346af
Module libpipewire-module-protocol-native.so with build-id 51df73170324bffaed65599d0e28bb63facfca9b
Module libspa-dbus.so with build-id 0a3399934a8e89e932a65d5be38a37056a566d91
Module libspa-journal.so with build-id ee47768f87a557344487ec6ff17016d20c70f331
Module libspa-support.so with build-id a20defef5ff12ffe66db769c58ac74806d2ad8d4
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libvulkan.so.1 with build-id d4e15d431868bfcda9fa5635d57af8822557ee9b
Module libdrm_nouveau.so.2 with build-id af8afb2331ac08c52132102ecbdc6076a8eb4c6f
Module libdrm_amdgpu.so.1 with build-id 8eb3977b830f3012d9ead7b4def5f4d2f38ec688
Module libelf.so.1 with build-id c09e357a1a3b061bf219bcfb243ca31b175e77fa
Module libdrm_radeon.so.1 with build-id 43e0aecc70c4ce905ba35c948e1c9a5d999b14c0
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module libLLVM-13.so with build-id 76d1fe97dbdca6d6891c6a1a7c06a388aa247154
Module radeonsi_dri.so with build-id 5934b1b910c68c47c825f1daec91f53b8ee9619a
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module libxshmfence.so.1 with build-id 8876d9ccf620858795724ca24b9e567585a77cec
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
Module libglapi.so.0 with build-id 15e64d81c0c36ed9561d948d56edc7081ee26d83
Module libEGL_mesa.so.0 with build-id b8986f92f9b3b945efc1f481863fc7b0037658e8
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libEGL.so.1 with build-id 30b30de54f2f848a7b8bed469349c9a7ab1b7c22
Module libpipewire-0.3.so.0 with build-id 4f6546c98a998ecbe671647afdf63c4548c0555c
Module libnssckbi.so with build-id 8b539aa1d5ee1ffc32e4c6f71c132e40e09ffbb7
Module libfreeblpriv3.so with build-id e87791779068b9460e702ae753171e1e85993980
Module libsoftokn3.so with build-id 2fa1bbbb67f801c3f6fd8d265ebc4d0889dd2517
Module libpixbufloader-svg.so with build-id 1dac084710afaf4fff84081306fcd7c66096777a
Module libtss2-sys.so.1 with build-id 1498ac4b48b90c1d3ac0f5f8f4d27d667bfc4771
Module libtss2-tctildr.so.0 with build-id d45a42b5bc06ce0bc08516ee688eb690cd8c5c91
Module libtss2-rc.so.0 with build-id 683cdb1ae9b98aca4ccd4080b6f418bdd95d7b59
Module libtss2-mu.so.0 with build-id ddbc7a4374d0d9ccb2132b2d7497074920f6b65c
Module libtss2-esys.so.0 with build-id 964b48ed1a288f436f7b22b1d5d765765238bde4
Module libsecret-1.so.0 with build-id 0cc692dc5ac19d1147a9846a00821b6687102386
Module libudev.so.1 with build-id 00aef0aeab17dca76ebdbe76e845712bf97b9d0c
Module libdconfsettings.so with build-id 7a4ba7af122c4d11168004a9ea6def330f02089f
Module libltdl.so.7 with build-id d2c1c93609da7fc11a1c40381fea72634ad714ed
Module libtdb.so.1 with build-id 6c9ccf6d9a22d117d984d1666842a49fd7669f09
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libcanberra-gtk3.so.0 with build-id 2e99c78f79bea4bc67ccd9a9f8fed562f89599ee
Module libcanberra-gtk-module.so with build-id cc626937222c6ce3f7bb45dbe6e862d0b1efba01
Module libgvfscommon.so with build-id 5c6df2952527d8d19cfb9ba14ceb290a15d186f8
Module libgvfsdbus.so with build-id 2529d3764be816acfea14bd80db2c56c2cb7f024
Module libX11-xcb.so.1 with build-id f6beacd41cd16a23f53e5e56bb599e98f039d0d6
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libsqlite3.so.0 with build-id a72506b3923739d1974e02062460a2720d4b3958
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libwayland-egl.so.1 with build-id ac45e227422559ff92c4d04851fffb8452874713
Module libwayland-cursor.so.0 with build-id 647d92328111682fb15bff1c20a4c9368414857c
Module libtracker-sparql-3.0.so.0 with build-id d03c91051f78975ac3f1d4732d1fecf70b32e709
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libgdk-3.so.0 with build-id a5ab221b5bcc72cfbe848530bb952bddccccc654
Module libgtk-3.so.0 with build-id 650fd204299b7ee234f3152032bbc8ebc54a7e1d
Module libresolv.so.2 with build-id 46ffdf3d477a170314060c26927470d7399bc900
Module libpangoft2-1.0.so.0 with build-id c2c09f789578900f61b7fca4a4311d8b94d9a750
Module libtiff.so.5 with build-id 9e8868622f8b7144fd82dabfa8ac2fcaf6d45a34
Module libgomp.so.1 with build-id 75d4bedf51d8d7bc41d78a1189d780a82c8ebaaf
Module libgpg-error.so.0 with build-id f9aaa96d5ddf6f6872051ed7abcdfe6bdaff9b1c
Module libasyncns.so.0 with build-id 6acff139d56b5139ce5eb50a66c62b215e1d332d
Module libsndfile.so.1 with build-id 407b2376cac1726631e3f7360a9337901be04ec0
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libcrypto.so.1.1 with build-id d54a7ee1e288aeae436d073277ff986e03994b15
Module libmvec.so.1 with build-id 760a099552c4783b979e942bf839c2bbc5ff603d
Module libpangocairo-1.0.so.0 with build-id b65f507d9e33adfbd19369acef5e5a0a2422c6d1
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libsoxr.so.0 with build-id 9e49936ed807c1e52705b88d5d71706fe11d9ed1
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libzstd.so.1 with build-id 3bccb8fe08e48d5ea135b1d0f99de0d771dd752f
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libhogweed.so.6 with build-id 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13536e
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libpulsecommon-15.0.so with build-id 1ff39f66b974fdf20be485f556b48ff4e6c33868
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libwayland-server.so.0 with build-id 5526cec43774a83c7ab8c7ff820eea8b28880d51
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
Module libva-x11.so.2 with build-id 0c5ca7869e7110b0e92180d5e7ddb330d6f14341
Module libva-drm.so.2 with build-id 7a02a127b38763e2ec9a2503f0ae4c3d57c20327
Module libssh.so.4 with build-id 8490056688e60790230f9d990c439b181236e9b6
Module libsrt.so.1.4 with build-id ad13eeb20e5ea3f04a0b089de1152ff89a9fa65c
Module libgmp.so.10 with build-id e58d34ab389d1b649c24195c2d145e3ff2e58290
Module libbluray.so.2 with build-id 3ed75b9f8aa64ee4707bbfcb986bcf289432d673
Module libmodplug.so.1 with build-id b00dcb12e7d2d5882b4fa414295eba449875dae4
Module libmfx.so.1 with build-id c5ae5843bb9f5a71745214de0b8c2edc8ccb7570
Module libva.so.2 with build-id ae5f91d7b4849e6f918da2e24825f9492c526118
Module libxvidcore.so.4 with build-id 43bc390a7842a7ca3a0302e93442ea561d7f013a
Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
Module libx264.so.164 with build-id 1ebb8708f2101bd1c95b701142163133e8dac465
Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libtheoradec.so.1 with build-id 19d321fd5455c7b7611ca9602a804b496124e06f
Module libtheoraenc.so.1 with build-id cde750f0621140f313e4ef4e5f212e662f24a38b
Module libSvtAv1Enc.so.0 with build-id e9143f88be53d2aebfa4f9249295869f09e22be4
Module libspeex.so.1 with build-id 39721dbe21b62978562c2943279f6dffbffe8946
Module librav1e.so.0 with build-id 5f8fc2c271f0d96480ab1c71447e038a66aa1c57
Module libopenjp2.so.7 with build-id 0a329c12468c33c92ecbc3968f4dc9c79cc5db96
Module libopencore-amrnb.so.0 with build-id a3d78948c85fa235e66549119b2f130e69af7b70
Module libmp3lame.so.0 with build-id 48c901805551a3dd58d02502c4cd67f6aa848107
Module libgsm.so.1 with build-id 1cc6240f7eaedaaac302bc7c0f64ebbeae596f22
Module libaom.so.3 with build-id 3c057fe8c5fa7033366274352148acb4dbb42728
Module librsvg-2.so.2 with build-id 4739a1b2d97c665872841efee754975534eb58a7
Module libopencore-amrwb.so.0 with build-id 28da8ed3dfca59280e835c46bd40da295dae99e2
Module libdav1d.so.6 with build-id a93560a23a7f1def734a3cf54f09eadd7c3c46e9
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libvpx.so.7 with build-id 347ca2580a23a6da7347be245c72585415bfa8e2
Module libswresample.so.4 with build-id afca7bcb3d53246c257a67b852fc922b240fe14a
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libsystemd.so.0 with build-id cdfc45d8f96e3af51b3d041c32f7899a93b86706
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libgmodule-2.0.so.0 with build-id c6df28882f153ee03d0fb33bb8aac2b219ebaacc
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libgnutls.so.30 with build-id 4532a39b33d508fcd26367e04c94de51cea59a64
Module libavahi-client.so.3 with build-id 1858551543958190c653b565cf0eb64609ad908a
Module libavahi-common.so.3 with build-id 80fda945459a3476ccd1050783dfd5f5c17c479a
Module libplc4.so with build-id e194130401ccec0067df40f72affdde25bb9a383
Module libplds4.so with build-id d91a9c5ee69e8a373b87bfc3eec221b5c1e2950c
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libxslt.so.1 with build-id 333f4419a38bfb5d4bc10f73aa2364847d683b38
Module libFLAC.so.8 with build-id d3c01b1bab8e878ff3928ba64a5817506bad1aa6
Module libminizip.so.1 with build-id 0785202fbd0261af699c78770961bf72fb3fb817
Module libxml2.so.2 with build-id 6b0ec2acdbc8f1a2255cc5e3e1258472cd99e272
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libsnappy.so.1 with build-id 36e3fb247a476fe2f755162644ebcd8ebd5d92cb
Module libpulse.so.0 with build-id b145e13bdb30c8327de7882ec9976fab38bc3e4a
Module libasound.so.2 with build-id b17fc1317a484842433c772360376623b64ec3d8
Module libre2.so.9 with build-id 1817ac6fcc97c8992aee9e20f9079824273cfc5d
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libpango-1.0.so.0 with build-id 7e27c1e46a1d958f6b16e1ba199f8bdb3f100566
Module libwayland-client.so.0 with build-id 95e7368b400dd57e3db2a5c385de71c7dca08879
Module libgbm.so.1 with build-id db6b1ee6abbf947245bc04cad40a6732ed6440d9
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libX11.so.6 with build-id d8e0be8e0323aa421366f19065ecd1c76405c130
Module libavutil.so.57 with build-id 02316d81b1e1685729cedd19caebefd52d8fb986
Module libavformat.so.59 with build-id cadfebbf354b318442c077a7eeb253de55d58a6b
Module libavcodec.so.59 with build-id 9b7c8f13e401225a3e10e315841d360348415f55
Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libharfbuzz.so.0 with build-id a11faa61f71b258fb92b717723757fc7dd141c01
Module libharfbuzz-subset.so.0 with build-id 41132cad3227c8e9a887f779a4fe655b4d3c7674
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libjpeg.so.8 with build-id 324d9d66f01707241e31af5cc104db3c9122f4c4
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libwebp.so.7 with build-id 0add7a572705244ed810b7e722cce7da0dcfb62c
Module libwebpmux.so.3 with build-id 4232d5263a45719ba12f58ed7d8cae3a0fc887de
Module libwebpdemux.so.2 with build-id 7bc15ac239db643015e169a2c6cc822156eb999a
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libdrm.so.2 with build-id 00816f0a71c7e4e388c10db6245dbb9c031732a9
Module libgio-2.0.so.0 with build-id 8c411770513e0bc758a1bbe661af14c972e2a3c4
Module libcups.so.2 with build-id 52ccc84fcb1bd56821c25e88ff624550698087f5
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libnspr4.so with build-id 0fcca981168b16e07684217e645e9b3b716a0c57
Module libnssutil3.so with build-id 1a64415cbb9d33b86f22e1bc4028411fd5bd9484
Module libnss3.so with build-id 63b30181a431facad7300e8fa3855db13d822da1
Module libsmime3.so with build-id 2950ba6b2aa311f260d83a6f27ea82f51205c57a
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libgobject-2.0.so.0 with build-id 4337ec84b2f33ec39a95863d47bfca0a28afd488
Module libglib-2.0.so.0 with build-id e268e80e668ce871312cf50e9969f88b086e33f2
Module libatomic.so.1 with build-id 0270e1b3acec62bce47a3f7fe9f09ae375105375
Module chromium with build-id e3bff900abf572e437302490883749015553b06f
Stack trace of thread 8775:
#0 0x000055c689de6796 n/a (chromium + 0x6f20796)
#1 0x00007ff58d573d58 n/a (libpipewire-0.3.so.0 + 0x7ad58)
#2 0x00007ff58d5e3391 n/a (libspa-support.so + 0x6391)
#3 0x00007ff58d5e23ea n/a (libspa-support.so + 0x53ea)
#4 0x00007ff58d5e3e3d n/a (libspa-support.so + 0x6e3d)
#5 0x00007ff58d5848ba n/a (libpipewire-0.3.so.0 + 0x8b8ba)
#6 0x00007ff59f52a5c2 start_thread (libc.so.6 + 0x8d5c2)
#7 0x00007ff59f5af584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8140:
#0 0x00007ff59f52715a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007ff59f529c64 pthread_cond_timedwait@@GLIBC_2.3.2 (libc.so.6 + 0x8cc64)
#2 0x000055c68908043b n/a (chromium + 0x61ba43b)
#3 0x000055c689080c06 n/a (chromium + 0x61bac06)
#4 0x000055c6890540d9 n/a (chromium + 0x618e0d9)
#5 0x000055c689053a4a n/a (chromium + 0x618da4a)
#6 0x000055c689083f0b n/a (chromium + 0x61bdf0b)
#7 0x00007ff59f52a5c2 start_thread (libc.so.6 + 0x8d5c2)
#8 0x00007ff59f5af584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8095:
#4 0x000055c689054096 n/a (chromium + 0x618e096)
Stack trace of thread 8111:
#1 0x00007ff59f529960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x000055c6890802cc n/a (chromium + 0x61ba2cc)
#3 0x000055c689080bf2 n/a (chromium + 0x61babf2)
#4 0x000055c68908086c n/a (chromium + 0x61ba86c)
#5 0x000055c688fe7e2e n/a (chromium + 0x6121e2e)
#6 0x000055c689041739 n/a (chromium + 0x617b739)
#7 0x000055c689011321 n/a (chromium + 0x614b321)
#8 0x000055c68905a527 n/a (chromium + 0x6194527)
#9 0x000055c68905a76b n/a (chromium + 0x619476b)
#10 0x000055c689083f0b n/a (chromium + 0x61bdf0b)
#11 0x00007ff59f52a5c2 start_thread (libc.so.6 + 0x8d5c2)
#12 0x00007ff59f5af584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8759:
#0 0x00007ff59f5a8a9d syscall (libc.so.6 + 0x10ba9d)
#1 0x00007ff5a29ed85f g_cond_wait_until (libglib-2.0.so.0 + 0xa585f)
#2 0x00007ff5a296ba83 n/a (libglib-2.0.so.0 + 0x23a83)
#3 0x00007ff5a296bc38 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23c38)
#4 0x00007ff5a29cfe8a n/a (libglib-2.0.so.0 + 0x87e8a)
#5 0x00007ff5a29ccda5 n/a (libglib-2.0.so.0 + 0x84da5)
Stack trace of thread 8108:
#5 0x000055c689053aea n/a (chromium + 0x618daea)
Stack trace of thread 8768:
#2 0x00007ff56d1c52ac n/a (radeonsi_dri.so + 0xc02ac)
#3 0x00007ff56d1be8cc n/a (radeonsi_dri.so + 0xb98cc)
#4 0x00007ff59f52a5c2 start_thread (libc.so.6 + 0x8d5c2)
#5 0x00007ff59f5af584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8146:
Stack trace of thread 8758:
Stack trace of thread 8161:
#0 0x00007ff59f5af9ae epoll_wait (libc.so.6 + 0x1129ae)
#1 0x000055c68921314e n/a (chromium + 0x634d14e)
#2 0x000055c6892109b5 n/a (chromium + 0x634a9b5)
#3 0x000055c6890a928b n/a (chromium + 0x61e328b)
#4 0x000055c689041739 n/a (chromium + 0x617b739)
#5 0x000055c689011321 n/a (chromium + 0x614b321)
#6 0x000055c68905a527 n/a (chromium + 0x6194527)
#7 0x000055c68905a76b n/a (chromium + 0x619476b)
#8 0x000055c689083f0b n/a (chromium + 0x61bdf0b)
#9 0x00007ff59f52a5c2 start_thread (libc.so.6 + 0x8d5c2)
#10 0x00007ff59f5af584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8105:
#0 0x00007ff59f59f1ec read (libc.so.6 + 0x1021ec)
#1 0x000055c688ebd4fe n/a (chromium + 0x5ff74fe)
#2 0x000055c689083f0b n/a (chromium + 0x61bdf0b)
#3 0x00007ff59f52a5c2 start_thread (libc.so.6 + 0x8d5c2)
#4 0x00007ff59f5af584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8102:
#5 0x000055c689053a9a n/a (chromium + 0x618da9a)
Stack trace of thread 8774:
#1 0x00007ff58d5f0849 n/a (libspa-support.so + 0x13849)
#2 0x00007ff58d5e3d14 n/a (libspa-support.so + 0x6d14)
#3 0x00007ff58d538997 n/a (libpipewire-0.3.so.0 + 0x3f997)
Stack trace of thread 8106:
#0 0x00007ff59f5a32af __poll (libc.so.6 + 0x1062af)
#1 0x00007ff5a29f3976 n/a (libglib-2.0.so.0 + 0xab976)
#2 0x00007ff5a299a6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#3 0x00007ff587fa1ebe n/a (libdconfsettings.so + 0x5ebe)
#4 0x00007ff5a29ccda5 n/a (libglib-2.0.so.0 + 0x84da5)
#5 0x00007ff59f52a5c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007ff59f5af584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8135:
Stack trace of thread 8141:
Stack trace of thread 8099:
Stack trace of thread 8148:
Stack trace of thread 8101:
#2 0x00007ff5a299c6a3 g_main_loop_run (libglib-2.0.so.0 + 0x546a3)
#3 0x00007ff5a20216dc n/a (libgio-2.0.so.0 + 0x10a6dc)
Stack trace of thread 8109:
#3 0x000055c68a2ed893 n/a (chromium + 0x7427893)
#4 0x000055c689083f0b n/a (chromium + 0x61bdf0b)
Stack trace of thread 8097:
#1 0x000055c689084bbb n/a (chromium + 0x61bebbb)
Stack trace of thread 8092:
#7 0x000055c689047c1b n/a (chromium + 0x6181c1b)
#8 0x000055c68905a76b n/a (chromium + 0x619476b)
#9 0x000055c689083f0b n/a (chromium + 0x61bdf0b)
#10 0x00007ff59f52a5c2 start_thread (libc.so.6 + 0x8d5c2)
#11 0x00007ff59f5af584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 8098:
#7 0x000055c6868d4b63 n/a (chromium + 0x3a0eb63)
Stack trace of thread 8104:
#3 0x000055c6890a91b0 n/a (chromium + 0x61e31b0)
Stack trace of thread 8100:
#3 0x00007ff5a299a712 n/a (libglib-2.0.so.0 + 0x52712)
Stack trace of thread 8094:
Stack trace of thread 8090:
#0 0x00007ff59f57a4cf wait4 (libc.so.6 + 0xdd4cf)
#1 0x000055c68907ee1a n/a (chromium + 0x61b8e1a)
#2 0x000055c68907bfa2 n/a (chromium + 0x61b5fa2)
#3 0x000055c689083f0b n/a (chromium + 0x61bdf0b)
Stack trace of thread 8091:
#4 0x000055c689055997 n/a (chromium + 0x618f997)
#5 0x000055c689083f0b n/a (chromium + 0x61bdf0b)
Stack trace of thread 8083:
#1 0x000055c686f10642 n/a (chromium + 0x404a642)
Stack trace of thread 8715:
Stack trace of thread 8767:
Stack trace of thread 8769:
Stack trace of thread 8766:
Stack trace of thread 8773:
Stack trace of thread 8770:
Stack trace of thread 8139:
Stack trace of thread 8771:
Stack trace of thread 8054:
#3 0x000055c688fe8170 n/a (chromium + 0x6122170)
#6 0x000055c6868d184a n/a (chromium + 0x3a0b84a)
#7 0x000055c6868d3653 n/a (chromium + 0x3a0d653)
#8 0x000055c6868cebb8 n/a (chromium + 0x3a08bb8)
#9 0x000055c688b118e7 n/a (chromium + 0x5c4b8e7)
#10 0x000055c688b10a9f n/a (chromium + 0x5c4aa9f)
#11 0x000055c688b0e98a n/a (chromium + 0x5c4898a)
#12 0x000055c68535a610 ChromeMain (chromium + 0x2494610)
#13 0x00007ff59f4ca310 __libc_start_call_main (libc.so.6 + 0x2d310)
#14 0x00007ff59f4ca3c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#15 0x000055c684f33d65 _start (chromium + 0x206dd65)
Stack trace of thread 8194:
Stack trace of thread 8772:
mai 14 11:08:37 rz3h-odin systemd[1]: systemd-coredump@1-8776-0.service: Deactivated successfully.
mai 14 11:08:37 rz3h-odin kernel: audit: type=1131 audit(1652537317.538:171): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-8776-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 14 11:08:37 rz3h-odin audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-8776-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 14 11:08:37 rz3h-odin systemd[1]: systemd-coredump@1-8776-0.service: Consumed 1.213s CPU time.
mai 14 11:08:37 rz3h-odin audit: BPF prog-id=46 op=UNLOAD
mai 14 11:08:37 rz3h-odin audit: BPF prog-id=45 op=UNLOAD
mai 14 11:08:37 rz3h-odin audit: BPF prog-id=44 op=UNLOAD
mai 14 11:08:37 rz3h-odin kernel: audit: type=1334 audit(1652537317.578:172): prog-id=46 op=UNLOAD
mai 14 11:08:37 rz3h-odin kernel: audit: type=1334 audit(1652537317.578:173): prog-id=45 op=UNLOAD
mai 14 11:08:37 rz3h-odin kernel: audit: type=1334 audit(1652537317.578:174): prog-id=44 op=UNLOAD
Can someone help me on that?
