Hi!
I have just started transitioning from Windows to Linux. I have them set up in dual-boot with two separate disks.
I’m relatively new to Linux but want to try it for the higher level of customization.
The problem I’m facing is that when waking up from sleep I get the message:
Desktop effects were restarted due to a graphics reset
plus Chrome and Discord both crash. Discord is just not there, while Chrome is fully unresponsive. both of these work just fine when I start them again.
output of inixi --full
Host: GLaDOS Kernel: 6.3.5-2-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.5 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.C0
date: 03/06/2023
Info: 8-core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP cache: L2: 8 MiB
Speed (MHz): avg: 2641 min/max: 2200/4850 cores: 1: 3312 2: 3058 3: 2883
4: 2200 5: 2200 6: 2200 7: 2200 8: 3026 9: 2912 10: 2200 11: 2200 12: 2200
13: 2200 14: 2888 15: 3681 16: 2899
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 530.41.03
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 driver: X:
loaded: nvidia gpu: nvidia s-res: 5760x1263
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2
Device-1: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: Razer USA Barracuda X driver: hid-generic,snd-usb-audio,usbhid
type: USB
API: ALSA v: k6.3.5-2-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
driver: r8169
IF: enp4s0 state: down mac: d8:bb:c1:3c:ed:b1
Device-2: Realtek RTL8125 2.5GbE driver: r8169
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: d8:bb:c1:3c:ed:b0
Local Storage: total: 2.5 TiB used: 13.19 GiB (0.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 500GB
ID-2: /dev/sda vendor: Western Digital model: WD2003FZEX-00SRLA0
ID-3: /dev/sdb vendor: Crucial model: CT250MX200SSD1 size: 232.89 GiB
ID-1: / size: 43.99 GiB used: 11.6 GiB (26.4%) fs: ext4 dev: /dev/sdb3
ID-2: /boot/efi size: 511 MiB used: 300 KiB (0.1%) fs: vfat dev: /dev/sdb1
ID-3: /home size: 143.02 GiB used: 1.59 GiB (1.1%) fs: ext4 dev: /dev/sdb4
ID-1: swap-1 type: partition size: 41 GiB used: 0 KiB (0.0%) dev: /dev/sdb2
System Temperatures: cpu: 51.8 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 344 Uptime: 46m Memory: available: 31.27 GiB
used: 6.65 GiB (21.3%) Shell: Zsh inxi: 3.3.27
Being able to use sleep is important to how I use my PC so disabling it is not an option sadly
If you need any other info please ask as I don’t really know what other information would be useful here.
Thanks in advance!
Edit:
I have found the following errors after reading the output from journalctl --catalog --no-pager -S "2023-06-18":
jún 18 18:26:53 GLaDOS discord[1036]: [0618/182653.474433:ERROR:directory_reader_posix.cc(42)] opendir /home/dpeter99/.config/discord/Crashpad/attachments/f4adbbab-db93-4b17-bc50-eb4846e53cd6: No such file or directory (2)
jún 18 18:26:53 GLaDOS discord[1415]: [1415:0618/182653.478617:ERROR:command_buffer_proxy_impl.cc(325)] GPU state invalid after WaitForGetOffsetInRange.
jún 18 18:26:53 GLaDOS discord[946]: [946:0618/182653.478954:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=512
jún 18 18:26:53 GLaDOS discord[946]: (electron) 'gpu-process-crashed event' is deprecated and will be removed. Please use 'child-process-gone event' instead.
