Chrome and Brave Crash Every Time I Open Them
For the past few months every time I open either Chrome or Brave they crash instantly (Firefox continues to work fine). Usually they appear to start up but then graphical glitches appear everywhere (like the video card is freaking out) and then everything just hangs and I have to reboot. Once in a very great while (like maybe 1 out of 20 times) it will actually open up normally but that hasn’t happened in some time. Chrome worked earlier this year but then started crashing so I tried Brave and that does the same thing. As I’ve said earlier though, Firefox continues to work just fine. I thought maybe it might be a flathub issue so I installed the bin version of Brave but that crashed too (although not as violently).
I’m running the latest version of Manjaro Gnome with Kernel 6.12.44 and I have a Radeon R7 360X video card. I’m thinking that somehow Chrome and Brave don’t like my video card but all the issues I’ve read about seem to be related to Nvidia video cards, not Radeon.
Any ideas? I need Chrome or Brave because an app I use doesn’t work with Firefox.
Which particular app?
Being Chromium based, Vivaldi might be a valid workaround.
sudo pacman -S vivaldi
Brave is available from the official Manjaro repositories, and yet you have opted not to use it. Try uninstalling your current instance and installing the recommended version:
sudo pacman -Rns brave-bin
sudo pacman -S brave-browser
I note that both brave-bin and google-chrome (and all other software sourced from the AUR) need to be fully rebuilt after each and every Manjaro update. If you have not done this, it’s possible that problems can accumulate over time.
Related: Best practice method for updating your system
Help us diagnose the problem:
Please create a new User account (for testing purposes). Reboot, and login to that account and verify whether or not you experience the same issue.
If the issue is no longer apparent, then this will indicate that the cause is limited to your main User profile, and this information will be invaluable for those who might wish to help; giving some direction; a place to start.
In the meantime, please provide system information as described (below). With those details given, I’m sure someone will be able to help further when they are able.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Zencaster is the app that won’t work with Firefox.
I tried running sudo pacman -Rns brave-bin and got this:
error: target not found: brave-bin
and then this:
 :: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring        [######################################################################################################] 100%
(1/1) checking package integrity        [######################################################################################################] 100%
(1/1) loading package files        [######################################################################################################] 100%
(1/1) checking for file conflicts        [######################################################################################################] 100%
error: failed to commit transaction (conflicting files)
brave-browser: /usr/bin/brave exists in filesystem
brave-browser: /usr/share/applications/brave-browser.desktop exists in filesystem
brave-browser: /usr/share/icons/hicolor/128x128/apps/brave-desktop.png exists in filesystem
brave-browser: /usr/share/icons/hicolor/16x16/apps/brave-desktop.png exists in filesystem
brave-browser: /usr/share/icons/hicolor/24x24/apps/brave-desktop.png exists in filesystem
brave-browser: /usr/share/icons/hicolor/256x256/apps/brave-desktop.png exists in filesystem
brave-browser: /usr/share/icons/hicolor/32x32/apps/brave-desktop.png exists in filesystem
brave-browser: /usr/share/icons/hicolor/48x48/apps/brave-desktop.png exists in filesystem
brave-browser: /usr/share/icons/hicolor/64x64/apps/brave-desktop.png exists in filesystem
Mod edit:- Please use formatting in accordance with forum guidelines.
See How to Post Command Output as Preformatted Text :eyes:
You can not use pacman for AUR programs only pamac
Thank you, pamac worked.
Brave (and Chrome) still crashes my system horribly when it runs though. You can see it starts to open up the browser window, but then the screen glitches out with rainbow colored pixel junk (like the video card freaked out) and the whole system hangs.
I tried it with the most recent kernel version just in case that had anything to do with it, but I still have the same problem.
Please post the output of:
pacman -Qo /usr/bin/brave
/usr/bin/brave is owned by brave-browser 1.82.170-1
While it is true that packages sourced from the AUR cannot be installed using pacman it will nonetheless remove/uninstall an application built via the AUR.
@tempest2084
Earlier you told us;
That is apparently no longer true according to your output:
The instructions given were;
Obviously, one cannot uninstall a package if it is not already installed; you must have another package type installed which was not clarified;
From your output, you already had brave-browser installed, so naturally, it will not install upon itself, it can only be upgraded.
Waveroom is a popular alternative to Zencastr, and I’m aware there are several others. Perhaps it’s time for a change (assuming they work with Firefox).
Again, on the chance the issue is limited to your User account:
Perhaps I uninstalled it after it also didn’t work? I know I ran the command to install it off the Brave page to install the bin version.
Thats because I installed it using pamac after I responded to you using the suggestion from robin0800. It still crashes horribly.
Sorry I missed this the first time. I’ll give this a try later.
This is an important troubleshooting step. If it is limited only to your account, that can potentially save much much duplication and wasted effort by those wishing to help, which hopefully gets you back on track sooner.
Chrome browsers have a history of problems with crashing, as evidenced by the amount of issues over time.
There’s nothing obviously related in Known Issues and Solutions but perhaps you will find something useful in these results.
I tried with a different account with no luck.
I also tried Chromium and Vavaldi and they all crashed in the same way as Brave and Chrome. They all follow the exact same pattern:
  1. I start the app
  2. Manjaro says that the app didn’t unlock the keyring and I need to reenter my password
  3. The browser starts up either with a distorted image and lots of weird rainbow video card artifacts everywhere or the window is flashing very fast like a strobe light with rainbow artifacts everywhere
  4. The system crashes after about 2 seconds
I even tried deleting the chromium and brave directories out of .cache and .config in case something was corrupted in there but nothing helped. Firefox (which continues to work) doesn’t ever do the keyring thing, so I wonder if maybe that has something to do with it? Either that or maybe the Chromium based browsers are having issues with my video card?
Do you have (or can you borrow) another video card to see if the issue persists?
This might be a good time to provide the previously requested system information which may help others identify possible contibutors:
System Information
inxi -zv8
In Known Issues and Solutions there was a note about Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update.
While I’m uncertain this related – how it only affects chromium-based browsers – it might be worth investigating, despite only Nvidia being mentioned.
Unfortunately I do not have another video card on hand.
This is the output for inxi -zv8
  Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=55594bba-ae18-4e54-ad2e-ce5506f12ebb rw quiet splash apparmor=1
  Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
  Type: Desktop Mobo: EVGA model: 131-GT-E767 v: Tylersburg
    serial: <superuser required> uuid: <superuser required> BIOS: Phoenix
    v: 6.00 PG date: 10/26/2010
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
    status: discharging
  System RAM: total: 12 GiB available: 11.67 GiB used: 1.76 GiB (15.1%)
  Array-1: capacity: 12 GiB note: est. slots: 6 modules: 6 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: A0 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    volts: N/A width (bits): data: 1 total: 65484 manufacturer: N/A part-no: N/A
    serial: N/A
  Device-2: A1 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-3: A2 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-4: A3 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-5: A4 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-6: A5 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Info: model: Intel Core i7 960 bits: 64 type: MT MCP arch: Nehalem
    gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
    model-id: 0x1A (26) stepping: 5 microcode: 0x1D
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1596 min/max: 1596/2660 scaling: driver: acpi-cpufreq
    governor: schedutil cores: 1: 1596 2: 1596 3: 1596 4: 1596 5: 1596 6: 1596
    7: 1596 8: 1596 bogomips: 42471
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
    cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flush_l1d fpu fxsr ht ibpb
    ibrs lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
    pbe pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good sep ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc vme xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Bonaire XTX [Radeon R7 260X/360]
    vendor: XFX Pine driver: radeon v: kernel alternate: amdgpu arch: GCN-2
    code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 2
    speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-1
    empty: DVI-D-1,DVI-I-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:6658
    class-ID: 0300 temp: 37.0 C
    compositor: gnome-shell driver: X: loaded: radeon unloaded: modesetting
    alternate: fbdev,vesa gpu: radeon display-ID: 0
  Monitor-1: DP-1 model: Dell G2724D serial: <filter> built: 2024
    res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.659 y: 0.329 green:
    x: 0.286 y: 0.631 blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
    size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9
    modes: 2560x1440, 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: OpenGL v: 4.5 vendor: amd mesa v: 25.2.1-arch1.4 glx-v: 1.4
    direct-render: yes renderer: BONAIRE (radeonsi ACO DRM 2.50
    6.12.44-3-MANJARO) device-ID: 1002:6658 memory: 1000 MiB unified: no
    display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 82801JI HD Audio driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Tobago HDMI Audio [Radeon R7
    360 / R9 OEM] vendor: XFX Pine driver: snd_hda_intel v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
    bus-ID: 03:00.1 chip-ID: 1002:aac0 class-ID: 0403
  API: ALSA v: k6.12.44-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
    vendor: eVga.com. driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: be00 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.05 TiB used: 1.37 TiB (67.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EADX-22TDHB0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 4D77
    scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q
  Optical-1: /dev/sr0 vendor: ASUS model: DRW-24B1ST j rev: 1.11
    dev-links: cdrom
    rw: cd-r,cd-rw,dvd-r state: running
  ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 256.45 GiB (56.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 55594bba-ae18-4e54-ad2e-ce5506f12ebb
  ID-2: /mnt/Backups raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 407.06 GiB (89.0%) fs: ext4 dev: /dev/sdd maj-min: 8:48 label: Backups
    uuid: ab3a709b-e0f4-431f-9716-210b2d5b2c63
  ID-3: /mnt/Storage raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 740.89 GiB (80.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Storage
    uuid: 4e39a9bb-f6a3-4f4a-83d5-1aeaca074caa
  ID-1: /dev/sdc1 maj-min: 8:33 size: 232.05 GiB fs: ntfs label: Windows
    uuid: E2C8BB34C8BB05B7
  ID-2: /dev/sdc2 maj-min: 8:34 size: 853 MiB fs: ntfs label: N/A
    uuid: 5A82C48282C463DB
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Device-1: 1-2:2 info: Dell KB216 Wired Keyboard type: keyboard,HID
    chip-ID: 413c:2113 class-ID: 0300
  Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Device-1: 2-1:2 info: Alcor Micro Flash Card Reader/Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 250mA
    chip-ID: 058f:6362 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-8: 8-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Device-1: 8-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 8-2:3 info: Mad Catz Street Fighter IV FightPad for Xbox 360
    type: <vendor specific> driver: xpad interfaces: 4 rev: 2.0
    chip-ID: 0738:4728 class-ID: ff00 serial: <filter>
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 10-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: radeon temp: 37.0 C
  Fan Speeds (rpm): N/A
  Packages: 1644 pm: dpkg pkgs: 0 pm: pacman pkgs: 1629 libs: 487
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 15
    1: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    4: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    6: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    7: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    8: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 278
  1: cpu: 100% command: ps pid: 4161 mem: 4.00 MiB (0.0%)
  2: cpu: 40.8% command: firefox pid: 3687 mem: 469.3 MiB (3.9%)
  3: cpu: 23.6% command: firefox pid: 3937 mem: 264.4 MiB (2.2%)
  4: cpu: 22.0% command: thunderbird pid: 3537 mem: 434.6 MiB (3.6%)
  5: cpu: 11.7% command: gnome-terminal-server pid: 4118
    mem: 66.4 MiB (0.5%)
  Memory top: 5 of 278
  1: mem: 469.3 MiB (3.9%) command: firefox pid: 3687 cpu: 40.8%
  2: mem: 434.6 MiB (3.6%) command: thunderbird pid: 3537 cpu: 22.0%
  3: mem: 336.4 MiB (2.8%) command: gnome-shell pid: 2333 cpu: 4.3%
  4: mem: 264.4 MiB (2.2%) command: firefox pid: 3937 cpu: 23.6%
  5: mem: 215.5 MiB (1.8%) command: firefox pid: 3873 cpu: 3.3%
  Processes: 278 Power: uptime: 5m states: freeze,standby,mem,disk
    suspend: s2idle avail: shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 4.64 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 257
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
    running-in: gnome-terminal inxi: 3.3.39
First, you can try to run Brave without any extension a see if the problem is Brave or one of the Extensions.
In my case, it was manganum.
• Manganum is like an annoying salesman that knocks on your Door.
If you are not careful, and they have cookies, it will be back on your System.
This Extension lead to long load time and random crashes.
If you need manganum, one workaround is to turn off Memory Saver in the setting, but that leads to more Memory use in the long run.
An Extension for a better Management of all Extension is to use: Extensity
How do I launch Chrome or Brave without extensions? I can’t get it to load at all without crashing my computer.
Try brave-community:
brave-browser --disable-extensions
Also try the --disable-gpu option.
Disabling the GPU seems to have fixed the problem! I assume I can do the same thing for Chrome as well? Is there a fix for this issue?
Being that all browsers concerned (in varying degrees) are based on Chromium, one presumes the --disable-gpu option should work on all.
<browser> --disable-gpu
Test each browser via the command-line first, and if the workaround is satisfactory, you can then edit the .desktop file either directly in /usr/share/applications/ or via the main Menu.
Without the cause being definitively identified, that’s probably difficult to know at this time, although I suspect the respective ages of both your system and GPU are not doing you many favours.
Could be, but I think it’s a driver issue myself.
