Hi,
I have problems with my audio with or without headphones:
- It is choppy.
- It sometimes stops completely and only comes back after a restart.
does anyone have any feedback on this?
Cheers.
Hi,
Cheers.
If you use pipewire have a look at this:
Hello,
Thanks for the link. I do not know if I am using pipewire, I also have never heard of that software. My manjaro installation is as it came from the iso from which I installed. Does anyone have any suggestion to fix this problem or could you tell me how to find out if I am using pipewire?
Cheers.
To give us more info about your hardware please post the output of
inxi -Fz
There will be a line like:
Sound Server-2: PipeWire v: 0.3.45 running: yes
If that’s the case you can go ahead and fine tune your pipewire config:
Hi,
It seems I have that software installed:
[angelc@manjaro ~]$ inxi -Fz | grep PipeWire
Sound Server-3: PipeWire v: 0.3.45 running: yes
[angelc@manjaro ~]$
However:
Is there an easier way to fix the sound? Like for instance, uninstalling pipewire and installing something else? Or I have to go through those 4 pages of instructions to get the sound working?
Cheers.
