➜ ~ pamac update
Preparing...
Authenticating as: sum
Password:
Synchronisation des bases de données des paquets...
Actualisation de core.db...
Actualisation de extra.db...
Actualisation de community.db...
Actualisation de multilib.db...
Choose a provider for nodejs<20:
1: nodejs-lts-gallium 16.20.2-1 extra
2: nodejs-lts-hydrogen 18.18.0-1 extra
Enter a number (default=1):
At this stage I have no nodejs-lts installed, but the 20 version
➜ ~ pamac update --no-aur
Preparing...
Password:
➜ ~ cat ~/.zshrc
ZSH=$HOME/.oh-my-zsh
# You can change the theme with another one from https://github.com/robbyrussell/oh-my-zsh/wiki/themes
ZSH_THEME="robbyrussell"
# Useful oh-my-zsh plugins for Le Wagon bootcamps
plugins=(git gitfast last-working-dir common-aliases zsh-syntax-highlighting history-substring-search ssh-agent)
# (macOS-only) Prevent Homebrew from reporting - https://github.com/Homebrew/brew/blob/master/docs/Analytics.md
# export HOMEBREW_NO_ANALYTICS=1
# Disable warning about insecure completion-dependent directories
ZSH_DISABLE_COMPFIX=true
# Actually load Oh-My-Zsh
source "${ZSH}/oh-my-zsh.sh"
unalias rm # No interactive rm by default (brought by plugins/common-aliases)
unalias lt # we need `lt` for https://github.com/localtunnel/localtunnel
# Load rbenv if installed (to manage your Ruby versions)
export PATH="${HOME}/.rbenv/bin:${PATH}" # Needed for Linux/WSL
type -a rbenv > /dev/null && eval "$(rbenv init -)"
# Load pyenv (to manage your Python versions)
export PYENV_VIRTUALENV_DISABLE_PROMPT=1
type -a pyenv > /dev/null && eval "$(pyenv init -)" && eval "$(pyenv virtualenv-init - 2> /dev/null)" && RPROMPT+='[🐍 $(pyenv version-name)]'
# Load nvm (to manage your node versions)
export NVM_DIR="$HOME/.nvm"
[ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh" # This loads nvm
[ -s "$NVM_DIR/bash_completion" ] && \. "$NVM_DIR/bash_completion" # This loads nvm bash_completion
# Call `nvm use` automatically in a directory with a `.nvmrc` file
autoload -U add-zsh-hook
load-nvmrc() {
if nvm -v &> /dev/null; then
local node_version="$(nvm version)"
local nvmrc_path="$(nvm_find_nvmrc)"
if [ -n "$nvmrc_path" ]; then
local nvmrc_node_version=$(nvm version "$(cat "${nvmrc_path}")")
if [ "$nvmrc_node_version" = "N/A" ]; then
nvm install
elif [ "$nvmrc_node_version" != "$node_version" ]; then
nvm use --silent
fi
elif [ "$node_version" != "$(nvm version default)" ]; then
nvm use default --silent
fi
fi
type -a nvm > /dev/null && add-zsh-hook chpwd load-nvmrc
type -a nvm > /dev/null && load-nvmrc
# Rails and Ruby uses the local `bin` folder to store binstubs.
# So instead of running `bin/rails` like the doc says, just run `rails`
# Same for `./node_modules/.bin` and nodejs
export PATH="./bin:./node_modules/.bin:${PATH}:/usr/local/sbin"
# Store your own aliases in the ~/.aliases file and load the here.
[[ -f "$HOME/.aliases" ]] && source "$HOME/.aliases"
# Encoding stuff for the terminal
export LANG=en_US.UTF-8
export LC_ALL=en_US.UTF-8
export BUNDLER_EDITOR=code
export EDITOR=code
# Set ipdb as the default Python debugger
export PYTHONBREAKPOINT=ipdb.set_trace
eval "$(rbenv init - zsh)"
PATH="${HOME}/.rbenv/shims:$PATH"
# pnpm
export PNPM_HOME="/home/sum/.local/share/pnpm"
export PATH="$PNPM_HOME:$PATH"
# pnpm end
# export NODE_OPTIONS=--openssl-legacy-provider
alias codecode="unset NODE_OPTIONS; code ."
export PATH="/opt/brew/bin:$PATH"
export PATH=~/.npm-global/bin:$PATH
