Cheese app not activate camera flash light
“Cheese” app (or “yay cheese”), does not activate camera flash light. tap, tap I would (hope) like camera flash light to be on alway – even before take video or take photo (double-time). Can there (trick) be button to turn camera flash light on or off?
As a long time user of Cheese, a better app is the Camera app (snapshot)
Thank you for replying. I am look at camera app list (https://www.makeuseof.com/best-camera-apps-linux/), and no camera app can turn on flashlight (and stay out!) at will. knock, knock Why?
What “flashlight”? What device are you using it on? PC’s don’t have one as far as I know.
That might work on mobile devices like the PinePhone or Librem as Snapshot is included with Phosh and GNOME Mobile–however, it would only work with the rear camera where the flash is.
Yessum. But the (unimportant) PC camera has a ring flash. It (sex) is a super-bright light. I can put that (trick) in place of green screen light, and not waste a gooht light source. Also, green screen back light is big and easy break. (pound, pound) Abba la pzyo!
edit: Also, web camera with(out) ring flash is gooht because it fits right on top of monitor with monitor mount.
Sorry, I’m having trouble following you. I understand there could be language barrier as it seems English may not be your first language.
Please help us help you by at least posting your system info described in the second link. It would be very helpful to know what hardware you’re using.
As far as I know, it doesn’t support keeping the flash/LED on like a torch before you take a picture or video. It only triggers the flash when capturing a still photo.
If you want the light to stay on, you might need to look into another app or tool. Some people use guvcview or even command-line utilities (like v4l2-ctl) to toggle the LED if the hardware supports it. Another workaround is just to use a separate light source or your phone’s flashlight while recording.
After a couple week, I am find camera, light, tap-button on top of camera. Please mark as close. Ty.
