Hello,
since about two weeks the set charge control does not work anymore. The small green charging sign is permanently visible in the battery icon (taskbar). I have always used the charge control natively from the Manjaro settings and also installed tlpui two days ago, but unfortunately that did not improve things either.
~ >>> inxi -Fx
ID-1: BAT0 charge: 16.9 Wh (90.9%) condition: 18.6/23.5 Wh (79.0%)
volts: 12.1 min: 11.4 model: SMP 00HW023 status: not charging
ID-2: BAT1 charge: 18.7 Wh (98.9%) condition: 18.9/26.1 Wh (72.4%)
volts: 12.5 min: 11.5 model: SMP 01AV406 status: not charging
~ >>> neofetch
vogel@mensch-manjaro
OS: Manjaro Linux x86_64
Host: 20FAS3J300 ThinkPad T460s
Kernel: 5.15.65-1-MANJARO
Uptime: 5 hours, 36 mins
Packages: 1471 (pacman), 7 (snap)
Shell: bash 5.1.16
Resolution: 2560x1080
DE: Plasma 5.25.5
WM: KWin
Theme: Breath2 [Plasma], Breath [GTK3]
Icons: breeze [Plasma], breeze [GTK2/3]
Terminal: konsole
Terminal Font: Noto Mono 10
CPU: Intel i5-6300U (4) @ 3.000GHz
GPU: Intel Skylake GT2 [HD Graphics 520]
Memory: 4421MiB / 7803MiB
~ >>> tlp-stat -b
+++ ThinkPad Battery Status: BAT0 (Main / Internal)
/sys/class/power_supply/BAT0/manufacturer = SMP
/sys/class/power_supply/BAT0/model_name = 00HW023
/sys/class/power_supply/BAT0/cycle_count = 0 (or not supported)
/sys/class/power_supply/BAT0/energy_full_design = 23540 [mWh]
/sys/class/power_supply/BAT0/energy_full = 18600 [mWh]
/sys/class/power_supply/BAT0/energy_now = 16930 [mWh]
/sys/class/power_supply/BAT0/power_now = 0 [mW]
/sys/class/power_supply/BAT0/status = Not charging/sys/class/power_supply/BAT0/charge_control_start_threshold = 25 [%]
/sys/class/power_supply/BAT0/charge_control_end_threshold = 75 [%]Charge = 91.0 [%]
Capacity = 79.0 [%]+++ ThinkPad Battery Status: BAT1 (Ultrabay / Slice / Replaceable)
/sys/class/power_supply/BAT1/manufacturer = SMP
/sys/class/power_supply/BAT1/model_name = 01AV406
/sys/class/power_supply/BAT1/cycle_count = 0 (or not supported)
/sys/class/power_supply/BAT1/energy_full_design = 26060 [mWh]
/sys/class/power_supply/BAT1/energy_full = 18860 [mWh]
/sys/class/power_supply/BAT1/energy_now = 18670 [mWh]
/sys/class/power_supply/BAT1/power_now = 0 [mW]
/sys/class/power_supply/BAT1/status = Not charging/sys/class/power_supply/BAT1/charge_control_start_threshold = 25 [%]
/sys/class/power_supply/BAT1/charge_control_end_threshold = 75 [%]Charge = 99.0 [%]
Capacity = 72.4 [%]+++ Charge total = 95.0 [%]
Even if inxi -Fx and tlp-stat -b say that the battery is currently not charging, I get the green charging icon in the battery sign.
Up until two weeks ago, it was still the case that I could see from the charging symbol whether the batteries were currently being charged or not, this sometimes changed several times a day (which was true). The battery symbol also says “Fully charged”.
Am I alone with this problem or is this something general? Ideas how I get the before state again?
Have a nice weekend!
