I have an odd issue with my new KDE Manjaro build (My old Gnome build is fine) where if I boot up with my USB Record Deck turned on then I get no sound at all, PulseAudio Volume Control hangs and KDE shows no devices at all.
If the machine is booted up already then turning on the Record Deck will then cause PulseAudio Volume Control to hang, but devices are already loaded. Turning it off makes it all wake up again.
I’m not sure what info would be most useful to enable help with this - To start with here’s an INXI (With the USB Record Deck switched off)…
Host: silvershield Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.2.1 parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=656d8930-a03a-4850-a10b-696abf952cd4 rw rootflags=subvol=@
quiet splash udev.log_priority=3 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: PRIME Z690-P D4 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1008
date: 01/13/2022
RAM: total: 31.1 GiB used: 8.63 GiB (27.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 12th Gen Intel Core i5-12600 bits: 64 type: MT MCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 5
microcode: 0x26
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2625 high: 3300 min/max: 800/6100 scaling:
driver: intel_pstate governor: powersave cores: 1: 600 2: 3300 3: 3300
4: 600 5: 3300 6: 600 7: 3300 8: 3300 9: 3300 10: 3300 11: 3300 12: 3300
bogomips: 79284
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36
pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni
smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-S GT1 [UHD Graphics 770] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: DP-1,HDMI-A-2 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:4690 class-ID: 0300
Device-2: Microsoft LifeCam Studio type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 1-1.1:4
chip-ID: 045e:0772 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2032x571mm (80.00x22.48")
s-diag: 2111mm (83.1")
Monitor-1: DP-1 pos: primary,left model: LG (GoldStar) HDR 4K
serial: 100167 built: 2022 res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2 chroma:
red: x: 0.682 y: 0.314 green: x: 0.278 y: 0.675 blue: x: 0.153 y: 0.047
white: x: 0.314 y: 0.329 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080,
1600x900, 1280x1024, 1280x800, 1280x720, 1024x768, 800x600, 720x480,
640x480
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: right model: Samsung U28E590
serial: HTPJ806172 built: 2017 res: 3840x2160 hz: 30 dpi: 160 gamma: 1.2
chroma: red: x: 0.635 y: 0.341 green: x: 0.310 y: 0.635 blue: x: 0.157
y: 0.059 white: x: 0.314 y: 0.329 size: 608x345mm (23.94x13.58")
diag: 699mm (27.5") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080,
1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 95
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel UHD Graphics 770
(ADL-S GT1) direct render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 1-1.1:4 chip-ID: 045e:0772
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 class-ID: 0300
chip-ID: 8086:7ad0 class-ID: 0403
Device-3: Sony PS-HX500 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-3:14 chip-ID: 054c:0baa class-ID: 0300
Device-4: Cambridge Audio CA CXA61 2.0 type: USB driver: snd-usb-audio
bus-ID: 1-9:8 chip-ID: 22e8:170b class-ID: 0102
Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 04:42:1a:e9:5a:c5
IP v4: 192.168.68.102/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.68.255
IP v6: fe80::d7b8:7c76:1a7a:4644/64 type: noprefixroute scope: link
WAN IP: 77.100.90.133
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 9.1 TiB used: 2.81 TiB (30.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: S5GYNX0T101140X rev: 5B2QGXA7 temp: 39.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: S5GXNS0RC48348R rev: 5B2QGXA7 temp: 39.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD40EZRZ-22GXCB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: WD-WCC7K0FSK29H
rev: 0A80 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD40EZRZ-00GXCB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: WD-WCC7K7CKD7R1
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: S3R3NF0J947780K rev: 3B6Q scheme: GPT
ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
used: 240.89 GiB (51.8%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:2
label: Manjaro KDE uuid: 656d8930-a03a-4850-a10b-696abf952cd4
used: 612 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 048C-6C0A
ID-3: /cloud raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 2.44 TiB (68.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: Cloud Linux uuid: 9d44b0e8-08c3-44d3-a2de-ab7df0f4492e
ID-4: /home raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-5: /scratch raw-size: 327.63 GiB size: 327.63 GiB (100.00%)
used: 135.57 GiB (41.4%) fs: ntfs dev: /dev/sdc4 maj-min: 8:36
label: Scratch uuid: 082A54672A545432
ID-6: /var/cache raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-7: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-1: swap-1 type: partition size: 71.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: manjaro-kde-swp
uuid: 69d6ae51-cbaf-452e-949a-c6245159764a
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 200 MiB fs: vfat label: N/A
uuid: C459-1F93
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 668.12 GiB fs: ntfs
label: Windows uuid: 28FE59B8FE597ECE
ID-4: /dev/nvme1n1p4 maj-min: 259:7 size: 823 MiB fs: ntfs label: N/A
uuid: 603A302D3A300298
ID-5: /dev/nvme1n1p5 maj-min: 259:8 size: 169.12 GiB fs: ext4
label: Timeshift Gnome uuid: 619ad6a1-afea-4b4b-9936-6076bed02705
ID-6: /dev/sdb1 maj-min: 8:17 size: 3.57 TiB fs: ntfs label: Cloud Windows
uuid: 01D59F5766495230
ID-7: /dev/sdc1 maj-min: 8:33 size: 600 MiB fs: vfat label: N/A
uuid: 3D66-94F4
ID-8: /dev/sdc2 maj-min: 8:34 size: 137.55 GiB fs: ext4
label: Manjaro Gnome uuid: 5fe8aabe-45b7-490a-a64a-bf255650c1d0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 3 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-1.1:4 info: Microsoft LifeCam Studio type: Video,Audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 5 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 045e:0772 class-ID: 0300
Device-2: 1-1.3:6 info: LG USA USB Controls
type: HID,Abstract (modem),CDC-Data driver: cdc_acm,hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip-ID: 043e:9a39 class-ID: 0a00
serial: 205NTGY2Y167
Device-3: 1-2:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:19af class-ID: 0300 serial: 9876543210
Device-4: 1-3:14 info: Sony PS-HX500 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 480 Mb/s power: 10mA chip-ID: 054c:0baa class-ID: 0300
Device-5: 1-9:8 info: Cambridge Audio CA CXA61 2.0 type: Audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
Device-6: 1-11:9 info: Dell Universal Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 413c:301c class-ID: 0300
Device-7: 1-12:10 info: MosArt Wireless Keyboard/Mouse
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 062a:4101 class-ID: 0301
Hub-3: 1-13:11 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 058f:6254 class-ID: 0900
Hub-4: 2-0:1 info: Super-speed hub ports: 9 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A
Packages: 1895 pm: pacman pkgs: 1866 libs: 524 tools: pamac,yay pm: flatpak
pkgs: 29
1: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
2: https://mirror.23m.com/manjaro/stable/$repo/$arch
3: https://mirror.cyberhost.uk/sites/manjaro/stable/$repo/$arch
4: https://mirror.easyname.at/manjaro/stable/$repo/$arch
5: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
6: https://repo.skni.umcs.pl/manjaro/stable/$repo/$arch
7: http://mirror.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 382
1: cpu: 26.4% command: msedge pid: 3342 mem: 214.1 MiB (0.6%)
2: cpu: 6.5% command: msedge pid: 3283 mem: 216.8 MiB (0.6%)
3: cpu: 5.1% command: msedge pid: 12250 mem: 238.0 MiB (0.7%)
4: cpu: 3.3% command: kwin_x11 pid: 1275 mem: 164.4 MiB (0.5%)
5: cpu: 2.3% command: systemd-journald pid: 391 mem: 16.6 MiB (0.0%)
Memory top: 5 of 382
1: mem: 1255.1 MiB (3.9%) command: sqlservr pid: 541 cpu: 1.6%
2: mem: 625.7 MiB (1.9%) command: soffice.bin pid: 10413 cpu: 0.8%
3: mem: 565.3 MiB (1.7%) command: /newerversion started by: dropbox
pid: 2737 cpu: 0.4%
4: mem: 496.8 MiB (1.5%) command: plasmashell pid: 1352 cpu: 0.9%
5: mem: 449.1 MiB (1.4%) command: insync pid: 1904 cpu: 1.4%
Processes: 382 Uptime: 1h 26m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
This is the device that’s causing the headaches…
