It’s unclear to me what the exact procedure to change the swap file on BTRFS.
According to wiki - Swap - Manjaro - it says I need to run
sudo truncate -s 0 /swapfile
sudo chattr +C /swapfile
sudo btrfs property set /swapfile compression none
before the sudo dd if=/dev/zero of=/swapfile bs=1M count=4096 status=progress
But the file location is under /swap
Or is it intentional in order to not mess with the original swapfile?
Also, do I need to disable the swapfile before running this?
What exactly are the commands and in what order they need to be executed in order to change the swapfile?
That doesn’t help me at all
It probably should, as all the information needed seems to be there, or linked to from the link @mithrial gave.
Firstly, I should state that I don’t use BTRFS
and probably don’t understand it fully. However, I do know for example that BTRFS
has sub volumes that must also be mounted. You will no doubt see the relevance of that as you work through the documentation.
Keep in mind that nobody is here to hand out step-by-step procedures for convenience, however, that too happens sometimes. It is expected that you read and understand information linked to, in order to scertain how it applies to your situation.
From what I can see, the information linked to is entirely relevant.
Cheers.
Swapfile can whenever you want, but you should keep it in separate subvolume from main one, because you cannot snapshot a swapfile.
Two people have already posted this link.
separate subvolume because a swap file cannot be snapshotted and a subvolume is easy to exclude
and yes:
swapoff the present swap file before you create a new one or change the existing one
It does not get less hard than that.
