I install on Manjaro Gnome with minimal image on my Schenker Via 14 Pro (which is a twin of the TUXEDO Pulse 14 - Gen3).
As I usally do I install some stuff afterwards to get everything work, like the power-profile-daemon to use the Gnome Power Profile selection. But it does not work. The profile is set to energy saving and I’m not able to change it. At GUI I simply get no response. On shell I get following:
Failed to communicate with power-profiles-daemon: g-io-error-quark: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._g_2dio_2derror_2dquark.Code15: Failed to activate CPU driver 'amd_pstate': Error writing '/sys/devices/system/cpu/cpufreq/policy6/boost': Die Operation wird nicht unterstützt (15)
I have no idea what is wrong and why amd_pstate is not working. I also don’t know why he wants to use amd_pstate because I read at web it is not the default pstate driver?
So hopefully I just miss something that have to be installed to get it working.
Thanks in advance!
Information about my system:
inxi -zv8
Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.14-x86_64
root=UUID=e5833a69-c6ed-44a3-8478-beb816f90a65 rw quiet
cryptdevice=UUID=9f07505f-66aa-4721-b21c-5de6e89a3fed:luks-9f07505f-66aa-4721-b21c-5de6e89a3fed
root=/dev/mapper/luks-9f07505f-66aa-4721-b21c-5de6e89a3fed splash
udev.log_priority=3
Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Laptop System: SchenkerGmbH product: SCHENKER VIA 14 Pro (L23)
v: Version 1.0 serial: <superuser required> Chassis: type: 10
Mobo: NB05 model: R14FA1 v: Version 1.0 serial: <superuser required>
part-nu: SVI14PL23 uuid: <superuser required> UEFI: American Megatrends LLC.
v: 8.17 date: 12/25/2024
ID-1: BAT0 charge: 51.1 Wh (87.4%) condition: 58.5/61.4 Wh (95.4%)
volts: 12.4 min: 11.8 model: Standard SR Real Battery type: Li-ion
serial: <filter> status: discharging
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 23.27 GiB used: 3.9 GiB (16.8%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: spec: 7500 MT/s actual: 6400 MT/s volts:
curr: 0.5 min: 0.5 max: 0.5 width (bits): data: 32 total: 32
manufacturer: Micron Technology part-no: MT62F2G32D4DS-026 WT serial: N/A
Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64 type: MCP
arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x74 (116) stepping: 1 microcode: 0xA70410A
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/5137 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 bogomips: 60686
apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: IP3 Tech
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1
bus-ID: 04:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 32.0 C
Device-2: Microdia USB 2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 0c45:636c
class-ID: 0e02
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: TL140ADXP24-0 built: 2023 res: 2880x1800 dpi: 244
gamma: 1.2 chroma: red: x: 0.639 y: 0.322 green: x: 0.298 y: 0.600 blue:
x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 300x190mm (11.81x7.48")
diag: 355mm (14") ratio: 16:10 modes: 2880x1800, 1920x1200, 1920x1080,
1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
800x600, 640x480
EDID-Warnings: 1: parse_edid: unknown flag 16 2: parse_edid: unknown tag
112
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi phoenix
LLVM 19.1.7 DRM 3.61 6.14.0-1-MANJARO) device-ID: 1002:15bf
memory: 7.81 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.309 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV PHOENIX) driver: N/A device-ID: 1002:15bf
surfaces: xcb,xlib,wayland
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: lact x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Conexant Systems driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.0-1-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:2725 class-ID: 0280
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 8087:0032
class-ID: e001
Device-1: luks-9f07505f-66aa-4721-b21c-5de6e89a3fed maj-min: 253:0
type: LUKS dm: dm-0 size: 930.01 GiB
Components:
p-1: nvme1n1p3 maj-min: 259:8 size: 930.01 GiB
Local Storage: total: 4.55 TiB used: 45.96 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 30.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 26.9 C
scheme: GPT
ID-1: / raw-size: 930.01 GiB size: 914.34 GiB (98.31%)
used: 45.39 GiB (5.0%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0
mapped: luks-9f07505f-66aa-4721-b21c-5de6e89a3fed label: N/A
uuid: e5833a69-c6ed-44a3-8478-beb816f90a65
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 581 MiB (59.7%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7 label: N/A
uuid: 37c08d40-2d0d-4cd8-8ef7-0408c1199a73
ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6 label: N/A
uuid: E541-2722
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 5EBE-9C96
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 3.64 TiB fs: bitlocker
label: DESKTOP-9TASKC6 System 24.02.2025
uuid: c627a081-91cf-424e-a763-7dcfc6904540
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 659 MiB fs: ntfs label: N/A
uuid: DC1215D81215B90A
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
Device-1: 1-2:5 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:2 info: Microdia USB 2.0 Camera type: video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0c45:636c class-ID: 0e02
Device-3: 1-5:4 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-4: 3-1:2 info: USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 34d1:0608 class-ID: 0900
Hub-5: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-7: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-9: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 34.6 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): N/A
Packages: 1114 pm: pacman pkgs: 1107 libs: 440
tools: gnome-software,pamac,yay pm: flatpak pkgs: 7
1: https://mirror.23m.com/manjaro/stable/$repo/$arch
2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
3: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
4: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
5: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
6: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
7: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
8: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
9: https://manjaro.kurdy.org/stable/$repo/$arch
Processes:
CPU top: 5 of 325
1: cpu: 16.6% command: firefox pid: 4089 mem: 699.0 MiB (2.9%)
2: cpu: 15.3% command: gnome-shell pid: 1474 mem: 585.6 MiB (2.4%)
3: cpu: 8.8% command: firefox pid: 4398 mem: 374.8 MiB (1.5%)
4: cpu: 3.8% command: resources-processes pid: 2780 mem: 5.86 MiB (0.0%)
5: cpu: 1.9% command: resources pid: 2751 mem: 131.0 MiB (0.5%)
Memory top: 5 of 325
1: mem: 1021.2 MiB (4.2%) command: pamac-manager pid: 5349 cpu: 1.3%
2: mem: 699.0 MiB (2.9%) command: firefox pid: 4089 cpu: 16.6%
3: mem: 585.6 MiB (2.4%) command: gnome-shell pid: 1474 cpu: 15.3%
4: mem: 374.8 MiB (1.5%) command: firefox pid: 4398 cpu: 8.8%
5: mem: 268.6 MiB (1.1%) command: firefox pid: 4860 cpu: 1.3%
Processes: 325 Power: uptime: 34m states: freeze,mem,disk suspend: s2idle
image: 9.29 GiB services: gsd-power, power-profiles-daemon, upowerd
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.37
LANG=C lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics
CPU family: 25
Model: 116
Thread(s) per core: 1
Core(s) per socket: 8
Socket(s): 1
Stepping: 1
Frequency boost: enabled
CPU(s) scaling MHz: 46%
CPU max MHz: 5137,0000
CPU min MHz: 400,0000
BogoMIPS: 7585,81
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse3
6 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdts
cp lm constant_tsc rep_good amd_lbr_v2 nopl xtopology nonstop_tsc cpui
d extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse
4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_l
egacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw
ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc m
waitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba perfmon_v2 ibrs ibpb stibp
ibrs_enhanced vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rd
t_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb avx512
cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm
_occup_llc cqm_mbm_total cqm_mbm_local user_shstk avx512_bf16 clzero i
rperf xsaveerptr rdpru wbnoinvd cppc arat npt lbrv svm_lock nrip_save
tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold
vgif x2avic v_spec_ctrl vnmi avx512vbmi umip pku ospke avx512_vbmi2 g
fni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid o
verflow_recov succor smca fsrm flush_l1d amd_lbr_pmc_freeze
Virtualization features:
Virtualization: AMD-V
Caches (sum of all):
L1d: 256 KiB (8 instances)
L1i: 256 KiB (8 instances)
L2: 8 MiB (8 instances)
L3: 16 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-7
Gather data sampling: Not affected
Ghostwrite: Not affected
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Reg file data sampling: Not affected
Retbleed: Not affected
Spec rstack overflow: Mitigation; Safe RET
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; Enhanced / Automatic IBRS; IBPB conditional; STIBP disable
d; RSB filling; PBRSB-eIBRS Not affected; BHI Not affected
Srbds: Not affected
Tsx async abort: Not affected
Driver
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
Kernels
Currently running: 6.14.0-1-MANJARO (linux614)
* linux612
* linux613
* linux614
Manjaro Version
ManjaroLinux 25.0.0 Zetar
If I miss some important information, please let me know.
