Hi. I am trying to change a system shortcut in my Manjaro Linux. shortcut to delete a file/Folder is “del” key on keyboard. I want to change it to “ctrl + d”. I don’t know the command to set in keyboard shortcuts. I really wanna change this shortcut. Kindly Help mein with that.
So if you want to do it system wide, check out this solution:
https://superuser.com/questions/469004/remap-superarrow-key-to-home-end
Welcome to the Forum!
If you want this functionality in Thunar file manager (default in Xfce), open the file ~/.config/Thunar/accels.scm, find this line
; (gtk_accel_path "<Actions>/ThunarLauncher/trash-delete" "Delete")
and change it to
(gtk_accel_path "<Actions>/ThunarLauncher/trash-delete" "<Primary>d")
You might have to logout/login in order for the shortcut to change in the file manager.
In addition to the above:
