Changes needed to make buildiso work
add after line 53 in “/usr./bin/buildiso” this allows “enable_systemd_timers” to work.
msg2 "enable_systemd_timers: %s" "${enable_systemd_timers[*]}"
remove “community” 3 lines this removes community from buildiso.
/usr/share/manjaro-tools/pacman-multilib.conf
remove “community” 3 lines this is needed if multilib not used
/usr/share/manjaro-tools/pacman-default.conf
I will make a patch if everyone agrees to the above?
I moved your post from Unstable Updates to Dev Tools as the former category has nothing to do with the subject.
Please see: Sending a PR to manjaro gitlab from github
I’ve cloned and changed only multilib.conf in the data folder and pacman-default.conf also in the data folder
Simply removed the community repo’s
The buildiso changes are already in (Not pushed yet)
the repo is @ GitHub - robin0800/manjaro-tools
