Changement de carte graphique , comment activer les drivers nivdia rtx 2080
Hello, how we put to update the cg, I novice, on manjaro ? I look on add and deleted, but i don’t know what choice. Please, thank you by advanced.
Please post in the forum for your native language.
Or:
Write your question in your native language and have it translated to english using translate.google.com or deepl.com
and then post that here.
Like it is now:
maybe someone understands what your issue is - I don’t. :man_shrugging:
bonjour, comment on fait pour connaître la version qu’on a de base, et comment après faire une mise à jour, plus récente ?
Sorry. Hello, how do we find out which version we have as standard, and how do we update to a more recent version?
Please, thank you by advanced, hoping it’s good
google translate sorry thank you.
Your question is still very much unclear.
Be verbose and precise - google can only translate well what you give to it …
It should be pretty good at french - I’m definitely not … :grin:
… pretend you explain your issue to a five year old child … :grinning:
Manjaro is a rolling release.
As long as you update, you will always be running the very latest, most current version.
No matter when you installed your system or what ISO you used to install it.
It will always be the latest, most current.
en faite, quand je lance unreal engine 5, on me demande de mettre a jour, ma carte graphique, et je ne sais pas quel version, je suis unreal me conseils d’être en version 535 et ca me dit à chaque fois que je lance unreal. La c’est ok ?
In fact, when I launch Unreal Engine 5, I am asked to update my graphics card, and I don’t know which version, I am Unreal advised to be in version 535 and it tells me every time I launch Unreal. Is that ok?
sorry for my english of google translate…
I gather that you have a (perceived) problem with some game or game engine.
That is nothing Manjaro specific.
I’m not a gamer.
I do not know anything about Steam or Proton or however else games are used and played these days.
The last game I played was Blue Shift, many, many years ago.
I’ll advise again to describe your issue in detail
and will leave you here,
hoping that other people understand you better and can be of help to you.
hello , can you please report
inxi -zv8
sudo mhwd-kernel -li
Note: I have moved this thread to #languages:francais, because the OP has a problem properly expressing themselves in English. It will probably be easier for them to communicate with the native French-speaking members. :wink:
Vous pouvez continuer en français d’ici. :wink:
Bonjour,
unreal est en aur, paquet pas maintenu depuis fin 2024 …
ou utilises-tu un flatpack ou autre ?
hello, i’m found. thank you. :wink:
@Denis, c’etait depuis le github, que j’ai pris unreal 5. Mais j’ai réussi à l’installer.
bonjour
Petit rappel, nous sommes en rolling ! normalement on n’installe que des paquets manjaro. Si on fait une install “à la main” d’une app, on risque d’avoir au mieux l’application cassée à une prochaine mise à jour, au pire, pas rare, de bloquer nos futures mises à jour ou de planter notre linux.
bonjour, okay, je ne savais pas, je ferais attention la prochaine fois merci, :wink:
Cordialement,
