Cannot find option in Manjaro settings to change time display from 24-hour format to 12-hour (am/pm). I have 6.1.12-1-Manjaro and sfce ver 4.18. If it is not in the settings, is there a terminal command, or a file edit, to get to the %I format?>
There should the option in the panel settings for the clock.
Yes, I believe that applies to Xfce 4.5 and above, not my version 4.18. It looks like I would have to create a new directory and file, then code the file for the format change, and that is a remarkable amount of effort to simply change the time format. I am going to forget it because it isnât worth the trouble. Thanks anyway.
- right click on the clock applet in the panel (where what you want to change is currently displayed)
- chose
âPreferencesââPropertiesâ
There you can change the format of what is displayed.
A few pre set items and also an option to customize what is displayed how.
edit:
my system isnât in english - changed the name of the option according to what @6x12 said
In my Xfce 4.18 I can:
- rightclick on the clock in the panel bottom right
- pick âPropertiesâ
- in the opening window under âClock Optionsâ >> âFormatâ
- pick one of the AM/PM options.
