Hello,
I want to change the Prompt from Gnome Terminal and i don’t know how.
I want instead of these arrows (~ >>>) a prompt like the Ubuntu-Terminal (user@host:~$). And I search a function to set the transparency of my Terminal background.
I hope anyone can help me to solve this.
cscs
22 December 2020 21:30
2
While you can edit the prompt …
What you are actually showing (in their default states) is the difference between zsh
and bash
(I too prefer bash)
xabbu
22 December 2020 21:34
3
The Gnome Developers decided to remove this function from Gnome Terminal. You can’t use a transparent background with the normal Gnome Terminal.
You need to switch to a different Terminal or install packages like gnome-terminal-fedora
or gnome-terminal-transparency
Comment out your current prompt from your ~/,zshrc and use this instead:
PROMPT="%(!.%{$fg[red]%}[%n@%m %1~]%{$reset_color%}# .%{$fg[green]%}[%n@%m %1~]%{$reset_color%}$ "
nate_x
23 December 2020 00:29
5
Here, have some fun with this: http://bashrcgenerator.com/
Or if you’re using zsh you can search for themes for it.
You could simply switch the shell from zsh to bash
chsh -s /usr/bin/bash
Switching to bash you will loose all the cool functionality of zsh.
