I remember we used to have bad verbage on the notifications - so users thought they Must install new kernel whenever one was released, even if it was a non-recommended kernel and user was running a supported LTS, etc.
… did that get ‘fixed’ by unselecting the notification by default?
Yes, KDE.
BTW, does MSM has different default options on different DEs?
Oh, that’s how it could be. OK. Probably my idea is not for everybody. Hm, or it is just description-related lack which makes users to understand some notification texts incorrectly.
But OK, it is just my raw suggestion, may be too raw.
How unselecting as action could be in a row with default. default - it is what I got from somewhere, action - is doing of changing. Now combining: unselecting by default. On that “line” my interpreter got a “BSOD” here and was restarted (I am not an English-native speaker).
As I understand the text labels of MSM settings, the settings selection on the screenshot in initial post are the most informative setting selection of all possible: notifications will be in whole bunch of event: not limiting by the only cases, so all cases (all only unchecked).
Last use case that simple kernel update from EoL to supported one fixes an issue: 4K,60hz的刷新率,经常掉帧
