Change menu colors layout
Hi, how can I change this from green to blue?
Thank y
Gnome manjaro uses the package gnome-shell-maia (that is the green accent)
replacing this with gnome-shell will use the default blue.
gdm uses the manjaro-gdm-branding package to style the login screen in the green accent color.
Source:
Thank you @Hanzel so much!
Are you sure? :wink:
