Hi All,
I changed the theme for the applications and the shell theme to gnome professional, however the shell theme is different in the login/lock screen. How can I change it. I found suggestions to use loginized but as far as I understand it is used only for the wallpaper on the lock screen and not for the shell theme on it.
Is there a way to change it to the same theme that I use in my session?
I changed my GDM to match session themes using gdm-tools from AUR. It was reasonably simple after reading through the git page.
