Hi there, this seems to be a very easy thing, but i cannot wrap my head arround ;(
I would like to change my keyboard configuration from german to spanish, while i can set up a spanish keyboard in the keyboard config, nothing changes, also after reboot. any idea? I was also reading in the forum and couldnt find a clue, but surely i am missing something easy here…
Hi @kalimerox,
Make sure the correct locale is installed:
https://wiki.manjaro.org/index.php/Locale
Other than that, I have no idea.
Edit:
I think you’ll have to enable it, regenerate your locale to install it, and then change it. But I only use the US layout, so I’m not even close to an expert and might be wrong…
Hi there,
somehow it worked by deleting the german layout completely! not sure if there is a nother way to switch back and forth if needed, but for now i am happy ![]()
