Change keyboard layout on Wayland
Hi, I don’t understand how to change my keyboard layout on Wayland. I use the QWERTY Lafayette layout, it’s a qwerty adapted for french people.
On the official site qwerty-lafayette . org there is the procedure for xorg, it works well. But it does not work on Wayland. I then tried via the graphical tool of Manjaro, it finds well the installed keyboard but nothing happens when I apply it, it does not work.
I did a fresh install of Manjaro Sway yesterday, but I want to use Qtile (So avoid a single procedure to Sway). The only manipulation I did was to modify /etc/vconsole.conf to have a qwerty login (following a bug that put me in azerty although I chose QWERTY at the installation).
Thank you
Seems for Qtile you need to add/create a config for such things.
Here’s the doc for it:
http://docs.qtile.org/en/latest/manual/wayland.html#inputconfig
