I have 5.10-5.11-and 5.12 installed on my system.
5.10 is 1st on booting order and this is display on
uname-r
Which file do i have to edit to change this order?
I know how to change from grub start-up on advance option but i want a permanent solution.
Thanks in advance!
I’m not sure what you wish to accomplish. GRUB orders the kernels in the menu along their version, and if you have…
GRUB_DEFAULT=saved
… in your /etc/default/grub, then GRUB will remember the last kernel you booted with, and will use that kernel for the next boot if you didn’t select anything else.
Yes, that is correct. GRUB always uses the last kernel that you booted with as the default for the next boot, unless you manually select another kernel, and then that one will in turn be remembered.
Something is missing!
On startup change the kernel manually to start from 5.12 also use
#update-grub
and
grub-mkconfig -o /boot/grub/grub.cfg
but on next boot the kernel is 5.10!
also the
pacman -Syu grub
found grub outdated and update the latest ver but the 5.10 still here!
does it remind me of being a stable character?
I found this on grub
GRUB_SAVEDEFAULT=“false”
now i put # on start and try again!
Νο did not help !
My /etc/default/grub is:
GRUB_DEFAULT=saved
GRUB_TIMEOUT="10"
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT="false"
#GRUB_ENABLE_CRYPTODISK="y"
GRUB_TERMINAL_INPUT="console"
#GRUB_TERMINAL_OUTPUT="console"
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX="keep"
#GRUB_DISABLE_LINUX_UUID="true"
GRUB_DISABLE_RECOVERY="true"
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
GRUB_DISABLE_OS_PROBER="false"
GRUB_DISABLE_LINUX_RECOVERY="true"
Putting GRUB_DEFAULT=1>2 i think will start with 5.12 (count 0-1-2-3…)
No still 5.10 I’m sure I made some changes but I do not remember which one! andreas85 ρε μπας και εισαι και απο Ελλαδα μερια ?
Have a look at /boot/grub/grub.cfg. If you did all right, there will be the new line with GRUB_DEFAULT=1>2
Sorry i had to look where it was in my filesystem. I do have btrfs, so savedefault will not work with grub and btrfs. So i had to disable savedefault:
#akf
GRUB_SAVEDEFAULT=false
But it is possible to save an default into /boot/grub/grubenv where grub would store its saved state. # WARNING: Do not edit this file by tools other than grub-editenv!!!
cat /boot/grub/grubenv
# GRUB Environment Block
menu_auto_hide=1
boot_success=1
saved_entry=1>2
So here i stored saved_entry=1>2 and since then it does start the second kernel by default
