hello after installing manjado without entering any password I was able to install, but after using the system and needing to use certain functions that require admin access, I can’t access … o what can I do to manually adjust the password or update it from null, empty … because I didn’t put any when installing …
Hi @marmmc, and welcome!
We don’t support this “manjado” here. This is the Manjaro forums.
However, for Manjaro you can try:
sudo passwd -d root
and if it asks for a password, provide your user’s password. Upon a prompt for the new password for root, provide the new wished password for root, a.k.a. the administrator.
Hope this helps!
Don’t do it again next time, and there’ll bee a next time. There always is…
ROOT-Passwort setzen is Simple:
open terminal and type this two commands, one after the other, not vice versa!:
sudo su
passwd
(root-password, for example: passwd secret42
okay brothers…
i am test, returned in the last moment…
