Hi, I’m using Manjaro XFCE and I have a sshfs mounted on fstab, all ok, can be mounted from thunar when click on it, but the dialog is horrible.
I try to install other packages :
gnome-ssh-askpass2 (gtk2)
gnome-ssh-askpass3 (gtk3)
ssh-askpass-fullscreen (gtk2)
But with no luck, the dialog asking the pass not appear. So I had to re-install original X11-ssh-askpass
How can change ask password dialog to more pretty ?
why not just skip it asking password.
Thanks, kerry.
Yes, it is a possibility, but got it total access to production server… and if stolen notebook, sometimes I used at public sites and not encripted partition used.
I’m using SSH agent integrated into GPG agent, it’s only about adding one line into $HOME/.gnupg/gpg-agent.conf
https://wiki.archlinux.org/title/GnuPG#SSH_agent
And then you can choose pinentry
script by your preferences.
