Do you recommend an app that works well to burn audio CDs? (Manjaro Gnome)
I tried Brasero but it stops responding after clicking BURN.
k3b
has a very good reputation, but it’s not a GNOME application. It’s a KDE application, and thus it may pull in a lot of KDE packages as dependencies, which you may or may not want.
I myself am a Plasma user and I’ve always used k3b
. The only failures I’ve ever had were due to bad-quality disks and a failing DVD burner.
Your mileage may vary.
Maybe look at this:
Brasero fails to normalize audio CD
If you try to burn it may stop at the first step called Normalization.
As a workaround you can disable the normalization plugin using the Edit > Plugins menu
kb3 seems to work ok, thanks.
It did error on the 2nd disc, but then was able to complete on another try.
I’ve marked a different post as the solution for posterity.
I’ve changed it back because the normalisation fix does not work, Brasero still locks up.
