Cat /proc/acpi/wakeup system suspend instant wake
I have read all the threads on this subject but i have an odd entry in my ❱cat /proc/acpi/wakeup that im not sure how to deal with?
inxi
❱inxi --admin --verbosity=7 --filter --no-host
  Kernel: 6.4.16-5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
    root=UUID=bf297078-1dd9-4d39-b246-b500233c73bb rw quiet splash
    resume=UUID=fb0af894-f621-4b37-b39c-7b067e2f8904 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
  Type: Desktop System: Dell product: OptiPlex 7050 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 055H3G v: A01 serial: <superuser required> UEFI: Dell
    v: 1.26.0 date: 08/20/2023
  System RAM: total: 16 GiB available: 15.49 GiB used: 3.73 GiB (24.1%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF4
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 900 min/max: 800/3800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 27208
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    disabled
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1
    empty: DP-1, DP-2, DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
    chip-ID: 8086:5912 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: VA24D serial: <filter>
    built: 2022 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    device-ID: 8086:5912 memory: 15.12 GiB unified: yes
  API: Vulkan v: 1.3.264 layers: 1 device: 0 type: integrated-gpu name: Intel
    HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.1.9-manjaro1.1
    device-ID: 8086:5912 surfaces: xcb,xlib
  Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  API: ALSA v: k6.4.16-5-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 0.3.81 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0a2b
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 1.84 TiB used: 47.03 GiB (2.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KXG50ZNV1T02
    NVMe 1024GB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: AADA4101
    temp: 41.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-1: / raw-size: 944.77 GiB size: 928.86 GiB (98.32%)
    used: 47.03 GiB (5.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: bf297078-1dd9-4d39-b246-b500233c73bb
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: B79E-8ADE
  ID-3: /mnt/TRUENAS-cavern raw-size: N/A size: 5.79 TiB
    used: 242.42 GiB (4.1%) fs: cifs dev: /dev/cavern
  ID-4: /mnt/TRUENAS-home raw-size: N/A size: 5.58 TiB
    used: 24.79 GiB (0.4%) fs: cifs dev: /dev/home
  ID-5: /mnt/TRUENAS-manjaro-home raw-size: N/A size: 5.72 TiB
    used: 174.83 GiB (3.0%) fs: cifs dev: /dev/manjaro-home
  ID-6: /mnt/TRUENAS-media raw-size: N/A size: 5.88 TiB
    used: 330.67 GiB (5.5%) fs: cifs dev: /dev/media
  ID-7: /mnt/ssd raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 2 MiB (0.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: secondary
    uuid: 8eb90896-961b-47fc-a8c5-4b5ce1d3db5f
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: fb0af894-f621-4b37-b39c-7b067e2f8904
  Device-1: 1-3:2 info: SINO WEALTH USB KEYBOARD type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 258a:0135 class-ID: 0300
  Device-2: 1-7:3 info: Integrated Express HTX HID Device
    type: keyboard,mouse driver: hid-generic,hid-multitouch,usbhid interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 048d:8911 class-ID: 0301 serial: <filter>
  Device-3: 1-9:4 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  System Temperatures: cpu: 37.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 196 Uptime: 43m wakeups: 10 Init: systemd v: 254
  Packages: pm: pacman pkgs: 1375 libs: 399 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: yakuake
  inxi: 3.3.30
My system is doing the “imidiate wake on suspend” thing. Iv been tinkering. I already have a script from another system i have that does somthing very simmalar.
The thing iv got a problem with is the ❱cat /proc/acpi/wakeup
⎼⎼⎼⎼⎼⎼⎼⎼⎼⎼ /home/greg ⎼⎼⎼⎼⎼⎼⎼⎼⎼⎼
Device  S-state   Status   Sysfs node
PEG0      S4    *disabled
PEGP      S4    *disabled
PEG1      S4    *disabled
PEGP      S4    *disabled
PEG2      S4    *disabled
PEGP      S4    *disabled
RP09      S4    *disabled
PXSX      S4    *disabled
RP10      S4    *disabled
PXSX      S4    *disabled
RP11      S4    *disabled
PXSX      S4    *disabled
RP12      S4    *disabled
PXSX      S4    *disabled
RP13      S4    *disabled
PXSX      S4    *disabled
RP01      S4    *disabled
PXSX      S4    *disabled
RP02      S4    *disabled
PXSX      S4    *disabled
RP03      S4    *disabled
PXSX      S4    *disabled
RP04      S4    *disabled
PXSX      S4    *disabled
RP05      S4    *disabled
PXSX      S4    *disabled
RP06      S4    *disabled
PXSX      S4    *disabled
RP07      S4    *disabled
PXSX      S4    *disabled
RP08      S4    *disabled  pci:0000:00:1c.0
PXSX      S4    *disabled  pci:0000:02:00.0
RP17      S4    *disabled  pci:0000:00:1b.0
PXSX      S4    *disabled  pci:0000:01:00.0
RP18      S4    *disabled
PXSX      S4    *disabled
RP19      S4    *disabled
PXSX      S4    *disabled
RP20      S4    *disabled
PXSX      S4    *disabled
RP21      S4    *disabled
PXSX      S4    *disabled
RP22      S4    *disabled
PXSX      S4    *disabled
RP23      S4    *disabled
PXSX      S4    *disabled
RP24      S4    *disabled
PXSX      S4    *disabled
RP14      S4    *disabled
PXSX      S4    *disabled
RP15      S4    *disabled
PXSX      S4    *disabled
RP16      S4    *disabled
PXSX      S4    *disabled
PS2K      S3    *disabled  pnp:00:02
                *enabled   serio:serio0
PS2M      S3    *disabled  pnp:00:03
GLAN      S4    *enabled   pci:0000:00:1f.6
XHC       S0    *enabled   pci:0000:00:14.0
XDCI      S4    *disabled
HDAS      S4    *disabled  pci:0000:00:1f.3
What is this "blank" "blank" *enabled serio:serio0 entry at the bottom that is *enabled?
How do disable it since it has no name? What is it?
The system start out after boot with this entry disabled but after a sleep cycle it is enabled again. Im not 100% sure it is the cause but iv disabled everything that i can and still be able to wake the system via keyboard. These are the last 3 things im left with.
❱cat /proc/acpi/wakeup | grep -i enabl
It’s something to do with serial i/o. Do you have some kind of serial input device attached?
https://wiki.archlinux.org/title/Serial_input_device_to_kernel_input
Nop, all iv got is USB trackpad and KB. It has wifi & BT on an M.2. A M.2 NVME ssd & a SATA ssd
Cant think of anything else, Certainly nothing else plugged into it from the outside so to speak.
❱lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04)
00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
00:14.2 Signal processing controller: Intel Corporation 200 Series PCH Thermal Subsystem
00:15.0 Signal processing controller: Intel Corporation 200 Series PCH Serial IO I2C Controller #0
00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1
00:16.3 Serial controller: Intel Corporation Device a2bd
00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
00:1b.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #17 (rev f0)
00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #8 (rev f0)
00:1f.0 ISA bridge: Intel Corporation 200 Series PCH LPC Controller (Q270)
00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio
00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (5) I219-LM
01:00.0 Non-Volatile memory controller: Toshiba Corporation XG5 NVMe SSD Controller
02:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
❱lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 003: ID 048d:8911 Integrated Technology Express, Inc. HTX HID Device
Bus 001 Device 002: ID 258a:0135 SINO WEALTH USB KEYBOARD
Try looking in other wakeup trigger interfaces - Power management/Wakeup triggers - ArchWiki
Maybe /sys/bus/serial/devices/ will contain a device with the power/wakeup file as described there.
/sys/bus/serial/devices/ is empty. I have tried to read the wiki but i dont understand.
⎼⎼⎼⎼⎼⎼⎼⎼⎼⎼ /sys/bus/serial/devices ⎼⎼⎼⎼⎼⎼⎼⎼⎼⎼
❱exa -aal --icons --group-directories-first --group --header -Um
Permissions Size User Group Date Modified Date Created Name
drwxr-xr-x     - root root  26 Oct 20:28  -             .
drwxr-xr-x     - root root  26 Oct 20:28  -             ..
❱cd /sys/class/wakeup/
⎼⎼⎼⎼⎼⎼⎼⎼⎼⎼ /sys/class/wakeup ⎼⎼⎼⎼⎼⎼⎼⎼⎼⎼
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup0 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/wakeup/wakeup0
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup1 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:4c/wakeup/wakeup1
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup2 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:77/wakeup/wakeup2
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup3 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:7a/wakeup/wakeup3
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup4 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:6a/wakeup/wakeup4
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup5 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:32/wakeup/wakeup5
lrwxrwxrwx     - root root  27 Oct 10:01  -             wakeup6 -> ../../devices/platform/i8042/serio0/wakeup/wakeup6
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup7 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:30/wakeup/wakeup7
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup9 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:48/wakeup/wakeup9
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup10 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:49/wakeup/wakeup10
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup11 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:69/wakeup/wakeup11
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup12 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:4a/wakeup/wakeup12
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup13 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:4b/wakeup/wakeup13
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup14 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:32/device:33/wakeup/wakeup14
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup15 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:30/device:31/wakeup/wakeup15
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup16 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/wakeup/wakeup16
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup17 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/INT3451:00/wakeup/wakeup17
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup18 -> ../../devices/LNXSYSTM:00/LNXPWRBN:00/wakeup/wakeup18
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup19 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/wakeup/wakeup19
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup20 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/wakeup/wakeup20
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup21 -> ../../devices/pnp0/00:06/wakeup/wakeup21
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup22 -> ../../devices/pnp0/00:06/rtc/rtc0/alarmtimer.0.auto/wakeup/wakeup22
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup23 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33A1:00/wakeup/wakeup23
lrwxrwxrwx     - root root  26 Oct 20:28  -             wakeup24 -> ../../devices/pci0000:00/0000:00:14.0/wakeup/wakeup24
lrwxrwxrwx     - root root  27 Oct 10:01  -             wakeup25 -> ../../devices/LNXSYSTM:00/PNP0C14:00/wakeup/wakeup25
lrwxrwxrwx     - root root  27 Oct 10:01  -             wakeup26 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C14:01/wakeup/wakeup26
lrwxrwxrwx     - root root  27 Oct 10:01  -             wakeup27 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C14:02/wakeup/wakeup27
lrwxrwxrwx     - root root  27 Oct 10:01  -             wakeup29 -> ../../devices/pci0000:00/0000:00:1f.6/wakeup/wakeup29
lrwxrwxrwx     - root root  27 Oct 10:01  -             wakeup30 -> ../../devices/pci0000:00/0000:00:14.0/usb1/1-3/wakeup/wakeup30
lrwxrwxrwx     - root root  27 Oct 10:01  -             wakeup31 -> ../../devices/pci0000:00/0000:00:14.0/usb1/1-7/wakeup/wakeup31
I just wanted to know how to disable that entry that has no name in the /proc/acpi/wakeup?
what is iv - if it is a self invented abbreviation - please don’t do that - it disturbs the meaning completely
A sincere effort to use modest and proper language and grammar is a sign of respect toward the community that will certainly be appreciated and is quite likely to elicit positive responses. Please refrain from using so-called “textspeak”, “netspeak”, “leetspeak” and all other forms of internet slang.
– Forum Rules - Manjaro
ehh? iv , sorry dyslexic from birth, if it was not for the 3 spell-checkers i have running continually you would not be able to read anything i wrote.
is it supposed to be i’v ? your complaining because of a missed hyphen? (if thats what its called).
How about NOT shaming people for a disability?
I also saw that and my IMMEDIATE reaction was internally giggling because I recognized it from doing exactly the same with my dyslexia.
There is a good motto to follow, even Ted Lasso used it.
“Don’t be judgmental, be curious and ask questions”.
Where do you get that from?
Please read the comments in correct order …
@jackdinn
I asked because I didn’t understand the phrase - I am not native english speaking - but a native dane.
The correct language would be I have but when spoken it is often pronouced I’ve
And no I am not displeased - I have been around so long that I have seen a lot of self-invented abbreviations - most often called text speak - inherited from sms.
And I did see all the other times - there is not any need to quote them all - one is enough
I was giggling because for some reason the first 2 or 3 times I wrote “iv” he didn’t mind, but the 4th time I used it, it offended him ^^
(I even spent the extra time to put the correct comma’s and capitals in this comment. Hope it pleases :slight_smile: )
Don’t worry about it, I am impossible to offend. I am also likely older than you and “text speak” is the absolute last thing id (opps sorry, I would) ever use because I hate it too. In this case, it’s just my bad spelling.
What is this device? Some kind of touchpad? Does your problem go away if you unplug it?
It doesn’t have a sysfs id there for whatever reason so you can’t disable it through /proc/acpi/wakeup.
This seems to be the source of the serio wakeup;
so there should be a file /sys/devices/platform/i8042/serio0/power/wakeup. You can disable it using that file as described in the Arch Wiki article;
echo "disabled" > /sys/devices/platform/i8042/serio0/power/wakeup
Yea its a USB touchpad, it does not cure the problem when i unplug it.
However,
❱su -c 'echo "disabled" > /sys/devices/platform/i8042/serio0/power/wakeup'
works, the device is gone now.
Also, I can probably disable the touchpad and just leave the keyboard via one of these
❱grep . /sys/bus/usb/devices/*/power/wakeup | grep enabled
/sys/bus/usb/devices/1-3/power/wakeup:enabled
/sys/bus/usb/devices/1-7/power/wakeup:enabled
It seems that it has now become an intermittent fault, sometimes it works others not, so it’ll take a little while to be sure. I should be able to figure it now though.
Thx all.
Is it a serial port that is missing a driver to be recognised as COM1 ?
Device can be found on many systems (288) using Vendor ID for Intel (8086) and Product ID (a2bd)
linux-hardware.org - pci:8086-a2bd - Device ‘Intel 200 Series Chipset Family KT Redirection’
None of the systems have a driver for a serial port
I suggest check motherboard BIOS settings to see if there is a serial port that can be disabled
I think that device might be something to do with Intel ME/AMT, but I’m not an Intel user so don’t know much about that stuff. KT means Keyboard and Text, so KT Redirection = something to do with remote management?
Hardware scan for Optiplex 7050 shows serial driver loaded for this device
https://linux-hardware.org/?probe=a35a9d7d8a&log=lspci_all
00:16.3 Serial controller [0700]: Intel Corporation Device [8086:a2bd] (prog-if 02 [16550])
Subsystem: Dell Device [1028:07a1]
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Interrupt: pin D routed to IRQ 20
Region 0: I/O ports at f0a0 [size=8]
Region 1: Memory at ef14d000 (32-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: serial
p38 of user manual shows that serial port is usually set to COM1 but can be disabled in BIOS
https://dl.dell.com/content/manual65979904-optiplex-7050-micro-owner-s-manual.pdf?language=en-us
i had a look in the bios but the entry for serial port under system configuration does not exit. (This BIOS is fully updated)
No worries though as i believe i have disabled it when it suspends with su -c 'echo "disabled" > /sys/devices/platform/i8042/serio0/power/wakeup' added to my suspend script.
I am beginning to get the bigger picture now.
You are using a thin client as workstation.
Thin clients is usually parts of a larger corporate network and centrally managed by an IT department.
This requires some capabilities on firmware level.
Thus I would look at disabling wake-on-lan and network boot.
Also disable Intel ME if possible - although it is not possible for all systems - which has raised some concerns over the years - as it could be considered a backdoor into the system in question.
Yep, i am using a micro (thin client) as a workstation.
I have disabled all wake-on-lan and network boot settings already. I even disabled the wake-on-usb, although it still does wake on usb when on linux, not sure about windows.
I have looked into the MEBx briefly but did not want to touch anything as i did not know what i was doing. I assume this Intel ME is in there.
I shall leave it for now, though. As i say, i have been able to disable the entry that i originally was curious about.
