Merhabalar, birkaç gün önce Manjaro KDE versiyonunu yükledim. Fn keylerimin F1den F12ye kadar kusursuz çalışmakta ancak Fn+Esc çalışmıyor. Nasıl çözebilirim?
Aşağıya Fn+Esc tuşunun verdiği xev ve evtest sonuçlarını paylaşıyorum.
EVTEST FN+ESC ÇIKTISI
Event: time 1621502072.619541, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 1
Event: time 1621502072.619541, -------------- SYN_REPORT ------------
Event: time 1621502072.621581, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1621502072.621581, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1621502072.621581, -------------- SYN_REPORT ------------
Event: time 1621502072.624818, type 4 (EV_MSC), code 4 (MSC_SCAN), value 76
Event: time 1621502072.624818, type 1 (EV_KEY), code 85 (KEY_ZENKAKUHANKAKU), value 1
Event: time 1621502072.624818, -------------- SYN_REPORT ------------
Event: time 1621502072.629640, type 4 (EV_MSC), code 4 (MSC_SCAN), value 76
Event: time 1621502072.629640, type 1 (EV_KEY), code 85 (KEY_ZENKAKUHANKAKU), value 0
Event: time 1621502072.629640, -------------- SYN_REPORT ------------
Event: time 1621502072.634775, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1621502072.634775, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 0
Event: time 1621502072.634775, -------------- SYN_REPORT ------------
Event: time 1621502072.641541, type 4 (EV_MSC), code 4 (MSC_SCAN), value db
Event: time 1621502072.641541, type 1 (EV_KEY), code 125 (KEY_LEFTMETA), value 0
Event: time 1621502072.641541, -------------- SYN_REPORT ------------
XEV FN+ESC ÇIKTISI
KeyPress event, serial 40, synthetic NO, window 0x6a00001,
root 0x938, subw 0x0, time 2965375, (321,1050), root:(321,1079),
state 0x10, keycode 133 (keysym 0xffeb, Super_L), same_screen YES,
XLookupString gives 0 bytes:
XmbLookupString gives 0 bytes:
XFilterEvent returns: False
root 0x938, subw 0x0, time 2965377, (321,1050), root:(321,1079),
state 0x50, keycode 37 (keysym 0xffe3, Control_L), same_screen YES,
root 0x938, subw 0x0, time 2965380, (321,1050), root:(321,1079),
state 0x54, keycode 93 (keysym 0x0, NoSymbol), same_screen YES,
KeyRelease event, serial 40, synthetic NO, window 0x6a00001,
root 0x938, subw 0x0, time 2965385, (321,1050), root:(321,1079),
root 0x938, subw 0x0, time 2965390, (321,1050), root:(321,1079),
state 0x54, keycode 37 (keysym 0xffe3, Control_L), same_screen YES,
root 0x938, subw 0x0, time 2965397, (321,1050), root:(321,1079),
state 0x50, keycode 133 (keysym 0xffeb, Super_L), same_screen YES,
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
