Buenas gente, estoy intentando carcarg mi laptop via usb sin exito, me podran dar una mano?
[1374577.625539] usb 1-6: new full-speed USB device number 68 using xhci_hcd
[1374577.625780] usb 1-6: Device not responding to setup address.
[1374577.832753] usb 1-6: Device not responding to setup address.
[1374578.039038] usb 1-6: device not accepting address 68, error -71
[1374578.039200] usb usb1-port6: unable to enumerate USB device
Gracias!
Wollie
23 October 2021 15:35
2
Nunca he oído que esto sea posible…
Funciona mejor al revés
System: Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Console: pty pts/1 DM: GDM 40.1
Machine: Type: Laptop System: HP product: HP ProBook 440 G7 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 869D v: KBC Version 02.28.00 serial: <filter> UEFI: HP v: S71 Ver. 01.03.02 date: 03/25/2020
Battery: ID-1: BAT0 charge: 21.0 Wh (51.6%) condition: 40.7/40.7 Wh (100.0%) volts: 11.2 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Discharging
CPU: Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP arch: Kaby Lake note: check rev: C cache:
L1: 256 KiB L2: 8 MiB L3: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36812
Speed: 700 MHz min/max: 400/4900 MHz volts: 0.7 V ext-clock: 100 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 700
5: 700 6: 700 7: 700 8: 700
Message: Advanced graphics data unavailable in console for root.
Audio: Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:02f0
class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: br-6425867a37ac state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 149 state: up address: see --recommends
Drives: Local Storage: total: 704.24 GiB used: 243.91 GiB (34.6%)
ID-1: /dev/nvme0n1 vendor: LITE-ON model: CL1-8D256-HP size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: L182 temp: 31.9 C scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST500LM030-1RK17D size: 465.76 GiB speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: RTM2 scheme: GPT
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 38.0 C mobo: 0.0 C
Info: Processes: 341 Uptime: 32d 21h 42m wakeups: 324 Memory: 15.47 GiB used: 5.99 GiB (38.7%) Init: systemd v: 249
Compilers: gcc: 11.1.0 Packages: 1664 apt: 1 pacman: 1656 snap: 7 Shell: Bash (su) v: 5.1.8 running-in: pty pts/1
inxi: 3.3.08
Wollie
23 October 2021 15:49
4
Cargar un portátil a través de uno de los puertos USB-C solo funciona si realmente está diseñado para ello.
Bueno, realmente se refiere a un puerto USB-C y ese tipo de puertos si permite la carga del portatil, pero el portátil tiene que soportarlo y el cargador tiene que tener la potencia suficiente. Por otro lado, que yo sepa, no hace falta nada más por parte del sistema operativo para que funcione la carga. Es algo físico, así que @cgermanb tiene que revisar lo que he dicho: que su portatil lo soporte y usar un cargador adecuado (consultar con el fabricante)
