I’ve been trying to solve this for weeks now. Before I switched to Linux, I had wired AutoHotkey to replace the function of the Caps Lock key to become a modifier (e.g. caps + a
would run a certain application, etc). Now that I’m on Linux, I changed the behavior of caps from the system settings menu to become “make caps lock an additional hyper”. I then set a custom shortcut for caps + a
to run the command: rofi -show run
This only works half the time. When I restart the computer, the option is still checked but it doesn’t work at all. I have to unswitch it and switch it again, and that freezes the system for a minute and sometimes doesn’t even work. Also, even when it’s working, this supposed hyper key actually functions like a super key (windows key), opening the menu when pressed.
I use fcitx5, and I’ve tried to mess with xkb (specifically by adding caps:hyper
to /etc/default/keyboard
, which didn’t work at all.) I’ve tried resorting to the ArchWiki X Keyboard instructions, but they’re waaaay over my head.
P.S. I’m not sure if this is relevant, but sometimes fcitx5 shows 2 icons on the system icons toolbar, and restarting fcitx5 from the drop menu freezes the computer for approximately 10 seconds.
Thank you in advance.
