because there are no libraries
T+ = See youlate
You are for long using Manjaro and you should know already there is no *-dev
package in Arch Linux and distributions based on it.
What you probably need is AUR (en) - libcurl-openssl-1.0
Changed the title of the topic
Have you tried the .appimage that is available from their website?
I always used it since its first version 0.8.XX, but I’m not as smart as you are, thank you.
@jrichard326 Yes, it’s the one I tried to open and it doesn’t work
T+ = See you later
