Hello! Could you please tell me how to set up hibernation in Manjaro KDE.
The laptop has 16 GB of RAM. I’ve created a 20GB swap, a hibernation button appeared. When I press this button (or execute the systemctl hibernate command in the console), the system seems to go into hibernation. The power turns off completely. However, after switching it on and logging into system accout there are no open applications.
Tried installing pm-utils 1.4.1-8 from AUR using pamac.
Do I need to register swap_device_uuid somewhere and/or edit the GRUB config?
(I have a dual boot, and when turning laptop on, I first select manjaro from the list)
The output of the swapon command is now:
NAME TYPE SIZE USED PRIO
/swapfile file 20G 0B -2
htop shows that swap is used when the RAM is almost full,.
Thanks in advance!
My system is like this:
Manjaro Linux 23.0.4 Uranos
KDE Plasma 5.27.8
KDE Frameworks 5.110.0
Qt Version 5.15.11
Kernel Version 6.1.55-1-MANJARO (64-bit)
Graphics Platform X11
Hardware:
Processors: 12 × Intel® Core™ i7-9750H CPU @ 2.60GHz
So you have no access to a search engine and you did not even found the search function here in the forum? Try to help yourself first, before wasting our time, sorry to say this so frankly.
Thank you for advices!
Used findmnt -no UUID -T /swapfile to find UUID and filefrag -v /swapfile | awk '$1=="0:" {print substr($4, 1, length($4)-2)}' to find resume_offset. Then added it to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub. Also added resume word to HOOKS in /etc/mkinitcpio.conf and it works like a charm!
