Can't use both front and rear out (Tuf B450 Plus) (ALC887/897)
I have a pair of headphones connected to my front out via 3.5mm and my 5.1 connected to the rear out via 3.5mm. While the headphones are disconnected, the 5.1 works via the “Line Out” option, but as soon as the headphones are plugged in, the 5.1 starts generating a static noise. And, if the audio is set to “Line Out” between “Headphones” and “Line Out” then nothing is audible through the 5.1. In Windows, Realtek Audio Console shows an option of seperating these devices, or combining them. If they’re combined, you can play the same audio back on both the line out and the headphone out, and if they’re seperate, you can use either, with both of the devices connected via 3.5mm. Please help. I don’t want wear on my headphone jack/cable because I’m using fairly good headphones and I want them, and the system too, to last as long as possible. I’m regularly switching between the headphones and the system, so unplugging and plugging in the headphones isn’t a permanent solution.
  Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=ea140b11-0f4a-401b-b0f5-7ee5983c3a59 rw quiet splash apparmor=1
  security=apparmor resume=UUID=415c3c19-eede-4920-8715-d6bb5903a297
  udev.log_priority=3
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop Mobo: ASUSTeK model: TUF B450-PLUS GAMING v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 3202 date: 06/16/2021
  RAM: total: 5.77 GiB used: 2.89 GiB (50.0%)
  Info: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64
  type: MCP arch: Zen family: 17 (23) model-id: 11 (17) stepping: 0
  microcode: 8101016 cache: L2: 2 MiB bogomips: 29614
  Speed: 3686 MHz min/max: 1600/3700 MHz boost: disabled Core speeds (MHz):
  1: 3686 2: 3686 3: 3655 4: 3555
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
  smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
  topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
  disabled, RSB filling
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
  vendor: ASUSTeK PRIME driver: amdgpu v: kernel bus-ID: 08:00.0
  chip-ID: 1002:15dd class-ID: 0300
  Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-1:2 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
  5.10.60-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.1 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
  vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel
  bus-ID: 08:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.33 running: yes
  vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
  bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: TP-Link 802.11ac WLAN Adapter type: USB driver: rtl88XXau
  bus-ID: 1-2:3 chip-ID: 2357:011f class-ID: 0000 serial: <filter>
  IF: wlp1s0f0u2 state: down mac: <filter>
  driver: btusb v: 0.8 bus-ID: 1-3:4 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 1.14 TiB used: 776.76 GiB (66.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2KW256G8
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 004C scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04ABF100
  type: HDD rpm: 5400 serial: <filter> rev: 0A scheme: GPT
  ID-1: / raw-size: 93.13 GiB size: 90.67 GiB (97.35%) used: 22.61 GiB (24.9%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: ea140b11-0f4a-401b-b0f5-7ee5983c3a59
  used: 25.5 MiB (8.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: 4D8D-221A
  ID-3: /mnt/AcerHDD raw-size: 831.5 GiB size: 831.5 GiB (100.00%)
  used: 742.74 GiB (89.3%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
  label: AcerHDD uuid: 8AA20B1EA20B0E7F
  ID-4: /mnt/SSD raw-size: 136.24 GiB size: 136.24 GiB (100.00%)
  used: 11.39 GiB (8.4%) fs: ntfs dev: /dev/sda4 maj-min: 8:4 label: SSD
  uuid: 51BFBB3A638BA693
  dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: 415c3c19-eede-4920-8715-d6bb5903a297
  ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/sdb3 maj-min: 8:19 size: 100 GiB fs: ntfs label: N/A
  uuid: 8A6AD8276AD81235
  Device-1: 1-1:2 info: Logitech Webcam C270 type: Video,Audio
  power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Device-2: 1-2:3 info: TP-Link 802.11ac WLAN Adapter type: Network
  driver: rtl88XXau interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
  Device-3: 1-3:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  Device-4: 1-7:7 info: Microsoft Xbox360 Controller type: <vendor specific>
  driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
  chip-ID: 045e:028e class-ID: ff00
  Device-5: 1-10:6 info: Logitech G203 LIGHTSYNC Gaming Mouse type: Mouse,HID
  power: 300mA chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-4:2 info: China Resource Semico USB Keyboard
  type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4d7e class-ID: 0301
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 53.9 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Processes: 260 Uptime: 6m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1240 pacman: 1232 lib: 309 flatpak: 8
  Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
https://wiki.archlinux.org/title/PulseAudio/Examples#Having_both_speakers_and_headphones_plugged_in_and_switching_in_software_on-the-fly
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
