I was having trouble with my Bluetooth headset, it wasn’t applying A2DP just HSP. After I unplugged and replugged it worked as for now. But interesting thing, it says its intended use is for the phone profile which I think is the HSP mode. Is there a way to change this?
I installed pulseaudio-modules-bt trying to fix it before so don’t know if after 2 reboots it worked that out.
I also did this
/etc/bluetooth/audio.conf
[General]
Disable=Headset
pacmd list-cards:
index: 4
driver: <module-bluez5-device.c>
owner module: 35
properties:
device.description = "Avantree NB16"
device.string = "00:1D:DF:1C:7B:AB"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_00_1D_DF_1C_7B_AB"
bluez.class = "0x240404"
bluez.alias = "Avantree NB16"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
profiles:
headset_head_unit: Headset Head Unit (HSP/HFP) (priority 30, available: no)
a2dp_sink_sbc: High Fidelity Playback (A2DP Sink: SBC) (priority 40, available: unknown)
a2dp_sink_aac: High Fidelity Playback (A2DP Sink: AAC) (priority 40, available: yes)
a2dp_sink_aptx: High Fidelity Playback (A2DP Sink: aptX) (priority 40, available: no)
a2dp_sink_aptx_hd: High Fidelity Playback (A2DP Sink: aptX HD) (priority 40, available: no)
a2dp_sink_ldac: High Fidelity Playback (A2DP Sink: LDAC) (priority 40, available: no)
off: Off (priority 0, available: yes)
active profile: <a2dp_sink_aac>
sinks:
bluez_sink.00_1D_DF_1C_7B_AB.a2dp_sink/#5: Avantree NB16
sources:
bluez_sink.00_1D_DF_1C_7B_AB.a2dp_sink.monitor/#7: Monitor of Avantree NB16
ports:
headset-output: Headset (priority 0, latency offset 0 usec, available: yes)
properties:
headset-input: Headset (priority 0, latency offset 0 usec, available: no)
properties:
