Can't upgrade Manjaro Gnome
Hello there.
I can’t upgrade using neither pamac nor yay after upgrade on 30/07/2024; on pamac it appears the errors “failed to prepare transaction” and “failed to clone”. Those are some outputs:
inxi -Fza         ✔
  Kernel: 6.6.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=1e5801d9-20fe-4812-8965-fc5c0ec7fa11 rw quiet splash apparmor=1
  Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
    with: ulauncher tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: X456UA v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: X456UA v: 1.0 serial: <superuser required>
    part-nu: ASUS-NotebookSKU uuid: <superuser required>
    UEFI: American Megatrends v: X456UA.301 date: 04/18/2019
  ID-1: BAT0 charge: 3.0 Wh (83.3%) condition: 3.6/38.0 Wh (9.6%) volts: 7.6
    min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 1219
  Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
    status: discharging
  Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2700 min/max: 400/2800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 2700 2: 2700 3: 2700 4: 2700 bogomips: 19204
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
    active: DP-1,HDMI-A-2,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:1916 class-ID: 0300
  Device-2: Chicony USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 04f2:b52b
  Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1848 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 pos: top-left model: Dell P2422H serial: <filter>
    built: 2022 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: top-right model: HP V244h
    serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
  Monitor-3: eDP-1 pos: primary,bottom-c model: ChiMei InnoLux 0x14c4
    built: 2015 res: 1366x768 hz: 60 dpi: 112 gamma: 1.2
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1366x768
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 5.65 GiB unified: yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
    bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.6.41-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
    driver: rtl8821au type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-3.4:7 chip-ID: 2357:011e class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u3u4 state: up mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 0bda:b719
  Local Storage: total: 894.25 GiB used: 329.46 GiB (36.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT960BX500SSD1
    size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: R022 scheme: GPT
  ID-1: / raw-size: 668.47 GiB size: 656.9 GiB (98.27%)
    used: 329.43 GiB (50.1%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
    used: 26.7 MiB (27.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: file size: 24 GiB used: 2.67 GiB (11.1%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 66.0 C pch: 53.5 C mobo: N/A
  Fan Speeds (rpm): cpu: 4300
  Memory: total: 12 GiB available: 11.58 GiB used: 9.95 GiB (85.9%)
  Processes: 287 Power: uptime: 1h 18m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.62 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2078 libs: 454
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 Compilers: clang: 18.1.8
    gcc: 14.1.1 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.35
yay                                                              ✔
[sudo] password for user:
 core is up to date
 extra is up to date
 multilib is up to date
:: Searching AUR for updates...
:: Searching databases for updates...
 -> nano-syntax-highlighting: local (2020.10.10+10+g1aa64a8-2) is newer than extra (2020.10.10-2)
 -> Packages not in AUR: protonpass-bin
 -> Orphan (unmaintained) AUR Packages: libgda  libgda-postgres
 -> Flagged Out Of Date AUR Packages: gconf
 -> spectre-meltdown-checker: local (0.46+26+gbd0c7c9-1) is newer than AUR (0.46-1)
:: 4 packages to upgrade/install.
4  aur/positron-ide-devel-bin  2024.07.0.107-1 -> 2024.07.0.113-1
3  aur/r-bslib                 0.7.0-1         -> 0.8.0-1
2  aur/r-future                1.33.2-1        -> 1.34.0-1
1  aur/zoom                    6.1.5-1         -> 6.1.6-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
 -> Excluding packages may cause partial upgrades and break systems
AUR Explicit (2): zoom-6.1.6-1, positron-ide-devel-bin-2024.07.0.113-1
AUR Dependency (2): r-bslib-0.8.0-1, r-future-1.34.0-1
:: PKGBUILD up to date, skipping download: r-future
:: PKGBUILD up to date, skipping download: positron-ide-devel-bin
:: PKGBUILD up to date, skipping download: r-bslib
:: (1/1) Downloaded PKGBUILD: zoom
  4 r-bslib                                  (Installed) (Build Files Exist)
  3 r-future                                 (Installed) (Build Files Exist)
  2 zoom                                     (Installed) (Build Files Exist)
  1 positron-ide-devel-bin                   (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> a
:: Deleting (1/4): /home/user/.cache/yay/r-bslib
HEAD is now at c2509e0 [lilac] updated to 0.8.0-1
:: Deleting (2/4): /home/user/.cache/yay/r-future
HEAD is now at 09c965f [lilac] updated to 1.34.0-1
:: Deleting (3/4): /home/user/.cache/yay/zoom
HEAD is now at 4d23c6f upgpkg: zoom 6.1.6-1
Removing src/
Removing zoom-6.0.12-1-x86_64.pkg.tar.zst
Removing zoom-6.0.12.5501_orig_x86_64.pkg.tar.xz
:: Deleting (4/4): /home/user/.cache/yay/positron-ide-devel-bin
HEAD is now at ea8ef59 bump to 2024.07.0.113
==> Diffs to show?
==> n
==> ERROR: PKGBUILD contains CRLF characters and cannot be sourced.
 -> error downloading sources: /home/user/.cache/yay/r-future
	 context: error downloading sources: /home/user/.cache/yay/r-future
	 context: exit status 12
error downloading sources: /home/user/.cache/yay/zoom
	 context: error downloading sources: /home/user/.cache/yay/zoom
error downloading sources: /home/user/.cache/yay/positron-ide-devel-bin
	 context: error downloading sources: /home/user/.cache/yay/positron-ide-devel-bin
error downloading sources: /home/user/.cache/yay/r-bslib
	 context: error downloading sources: /home/user/.cache/yay/r-bslib
:: (1/4) Parsing SRCINFO: r-future
:: (2/4) Parsing SRCINFO: zoom
:: (3/4) Parsing SRCINFO: positron-ide-devel-bin
:: (4/4) Parsing SRCINFO: r-bslib
 -> error making: r-bslib-exit status 12
 -> error making: r-future-exit status 12
 -> error making: zoom-exit status 12
 -> error making: positron-ide-devel-bin-exit status 12
 -> Failed to install the following packages. Manual intervention is required:
r-bslib - exit status 12
r-future - exit status 12
zoom - exit status 12
positron-ide-devel-bin - exit status 12
This one was quite long, so I selected the latest
cat /var/log/pacman.log
[2024-07-29T06:50:57-0500] [PAMAC] synchronizing package lists
[2024-07-29T06:53:32-0500] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-07-29T06:53:32-0500] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2024-07-29T06:53:32-0500] [ALPM] running '60-mkinitcpio-remove.hook'...
[2024-07-29T06:53:58-0500] [ALPM] running '71-dkms-remove.hook'...
[2024-07-29T06:53:59-0500] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod 8821au/5.12.5.2.r230.g847c74b -k 6.6.40-1-MANJARO
[2024-07-29T06:53:59-0500] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod rtl8812au/5.13.6.r192.g8be3a1d -k 6.6.40-1-MANJARO
[2024-07-29T06:53:59-0500] [ALPM-SCRIPTLET] ==> depmod 6.6.40-1-MANJARO
[2024-07-29T06:54:04-0500] [ALPM] running 'firefox-pre.hook'...
[2024-07-29T06:54:04-0500] [ALPM] transaction started
[2024-07-29T06:54:05-0500] [ALPM] removed jq (1.7.1-2)
[2024-07-29T06:54:06-0500] [ALPM] removed yarn (1.22.22-2)
[2024-07-29T06:54:07-0500] [ALPM] removed gulp (4.0.2-4)
[2024-07-29T06:54:07-0500] [ALPM] removed git-lfs (3.5.1-1)
[2024-07-29T06:54:07-0500] [ALPM] removed python-distutils-extra (2.39-13)
[2024-07-29T06:54:07-0500] [ALPM] removed nvm (0.39.7-1)
[2024-07-29T06:54:07-0500] [ALPM-SCRIPTLET]
[2024-07-29T06:54:07-0500] [ALPM-SCRIPTLET] Don't forget to clean up any lines added to your shell's startup script!
[2024-07-29T06:54:07-0500] [ALPM-SCRIPTLET] For example, from your .bashrc (or .zshrc etc.), delete the line:
[2024-07-29T06:54:07-0500] [ALPM-SCRIPTLET] source /usr/share/nvm/init-nvm.sh
[2024-07-29T06:54:08-0500] [ALPM] upgraded linux-api-headers (6.8-1 -> 6.10-1)
[2024-07-29T06:54:08-0500] [ALPM] upgraded apache (2.4.61-1 -> 2.4.62-1)
[2024-07-29T06:54:08-0500] [ALPM] upgraded assimp (5.4.0-1 -> 5.4.2-1)
[2024-07-29T06:54:09-0500] [ALPM] upgraded perl (5.38.2-1 -> 5.38.2-2)
[2024-07-29T06:54:09-0500] [ALPM] upgraded automake (1.16.5-2 -> 1.17-1)
[2024-07-29T06:54:09-0500] [ALPM] upgraded libxml2 (2.13.2-1 -> 2.13.2-2)
[2024-07-29T06:54:10-0500] [ALPM] upgraded cmake (3.30.0-1 -> 3.30.1-1)
[2024-07-29T06:54:10-0500] [ALPM] upgraded cpupower (6.9-2 -> 6.10-1)
[2024-07-29T06:54:13-0500] [ALPM] upgraded jdk17-openjdk (17.0.11.u9-1 -> 17.0.12.u7-1)
[2024-07-29T06:54:15-0500] [ALPM] upgraded jre-openjdk (22.0.1.u8-1 -> 22.0.2.u9-1)
[2024-07-29T06:54:15-0500] [ALPM] upgraded gsettings-desktop-schemas (46.0-2 -> 46.1-1)
[2024-07-29T06:54:15-0500] [ALPM] upgraded device-mapper (2.03.24-1 -> 2.03.25-2)
[2024-07-29T06:54:16-0500] [ALPM] upgraded llvm-libs (18.1.8-3 -> 18.1.8-4)
[2024-07-29T06:54:16-0500] [ALPM] upgraded libproxy (0.5.7-1 -> 0.5.8-1)
[2024-07-29T06:54:16-0500] [ALPM] upgraded glib-networking (1:2.80.0-1 -> 1:2.80.0-2)
[2024-07-29T06:54:17-0500] [ALPM] upgraded dbeaver (24.1.1-1 -> 24.1.2-1)
[2024-07-29T06:54:19-0500] [ALPM] upgraded electron31 (31.2.0-1 -> 31.2.1-1)
[2024-07-29T06:54:19-0500] [ALPM] upgraded orc (0.4.38-1 -> 0.4.39-1)
[2024-07-29T06:54:19-0500] [ALPM] upgraded libassuan (2.5.7-2 -> 3.0.0-1)
[2024-07-29T06:54:19-0500] [ALPM] upgraded pinentry (1.3.1-2 -> 1.3.1-5)
[2024-07-29T06:54:19-0500] [ALPM] upgraded gnupg (2.4.5-1 -> 2.4.5-4)
[2024-07-29T06:54:19-0500] [ALPM] upgraded gpgme (1.23.2-4 -> 1.23.2-6)
[2024-07-29T06:54:20-0500] [ALPM] upgraded evince (46.3-1 -> 46.3.1-1)
[2024-07-29T06:54:20-0500] [ALPM] upgraded fastfetch (2.18.1-1 -> 2.19.0-1)
[2024-07-29T06:54:20-0500] [ALPM] upgraded ttf-bitstream-vera (1.10-15 -> 1.10-16)
[2024-07-29T06:54:20-0500] [ALPM] upgraded sdl2 (2.30.5-1 -> 2.30.5-2)
[2024-07-29T06:54:20-0500] [ALPM] upgraded rubberband (3.3.0-1 -> 3.3.0-2)
[2024-07-29T06:54:20-0500] [ALPM] upgraded speexdsp (1.2.1-1 -> 1.2.1-2)
[2024-07-29T06:54:20-0500] [ALPM] upgraded speex (1.2.1-1 -> 1.2.1-2)
[2024-07-29T06:54:20-0500] [ALPM] upgraded srt (1.5.3-1 -> 1.5.3-2)
[2024-07-29T06:54:20-0500] [ALPM] upgraded vid.stab (1.1.1-1 -> 1.1.1-2)
[2024-07-29T06:54:20-0500] [ALPM] upgraded xvidcore (1.3.7-2 -> 1.3.7-3)
[2024-07-29T06:54:20-0500] [ALPM] upgraded portaudio (1:19.7.0-2 -> 1:19.7.0-3)
[2024-07-29T06:54:22-0500] [ALPM] upgraded firefox (128.0-1 -> 128.0-2)
[2024-07-29T06:54:22-0500] [ALPM] upgraded fwupd (1.9.21-2 -> 1.9.21-3)
[2024-07-29T06:54:22-0500] [ALPM] upgraded xorg-xrdb (1.2.2-1 -> 1.2.2-2)
[2024-07-29T06:54:22-0500] [ALPM] upgraded sbc (2.0-1 -> 2.0-2)
[2024-07-29T06:54:23-0500] [ALPM] upgraded webrtc-audio-processing-1 (1.3-2 -> 1.3-3)
[2024-07-29T06:54:23-0500] [ALPM] upgraded gnome-settings-daemon (46.0-1 -> 46.0-2)
[2024-07-29T06:54:23-0500] [ALPM] upgraded hwinfo (23.2-1 -> 23.2-2)
[2024-07-29T06:54:23-0500] [ALPM] upgraded python-gobject (3.48.2-1 -> 3.48.2-2)
[2024-07-29T06:54:23-0500] [ALPM] upgraded libibus (1.5.30-2 -> 1.5.30-3)
[2024-07-29T06:54:24-0500] [ALPM] upgraded ibus (1.5.30-2 -> 1.5.30-3)
[2024-07-29T06:54:24-0500] [ALPM] upgraded imagemagick (7.1.1.34-1 -> 7.1.1.35-1)
[2024-07-29T06:54:24-0500] [ALPM] upgraded imlib2 (1.12.2-2 -> 1.12.3-1)
[2024-07-29T06:54:24-0500] [ALPM] upgraded libnftnl (1.2.6-1 -> 1.2.7-1)
[2024-07-29T06:54:25-0500] [ALPM] upgraded libnl (3.9.0-1 -> 3.10.0-1)
[2024-07-29T06:54:25-0500] [ALPM] upgraded iproute2 (6.9.0-2 -> 6.10.0-1)
[2024-07-29T06:54:29-0500] [ALPM] upgraded jdk11-openjdk (11.0.23.u9-1 -> 11.0.24.u8-1)
[2024-07-29T06:54:29-0500] [ALPM] upgraded xorg-xset (1.2.5-1 -> 1.2.5-2)
[2024-07-29T06:54:30-0500] [ALPM] upgraded kcoreaddons (6.3.0-1 -> 6.4.0-1)
[2024-07-29T06:54:30-0500] [ALPM] upgraded qt6-wayland (6.7.2-2 -> 6.7.2-4)
[2024-07-29T06:54:30-0500] [ALPM] upgraded kwindowsystem (6.3.0-1 -> 6.4.0-1)
[2024-07-29T06:54:30-0500] [ALPM] upgraded less (1:643-2 -> 1:661-1)
[2024-07-29T06:54:30-0500] [ALPM] upgraded lib32-libnl (3.9.0-1 -> 3.10.0-1)
[2024-07-29T06:54:30-0500] [ALPM] upgraded lib32-libxml2 (2.13.2-1 -> 2.13.2-2)
[2024-07-29T06:54:30-0500] [ALPM] upgraded libappindicator-gtk3 (12.10.0.r298-3 -> 12.10.0.r298-4)
[2024-07-29T06:54:30-0500] [ALPM] upgraded libfprint (1.94.7-2 -> 1.94.7-3)
[2024-07-29T06:54:30-0500] [ALPM] upgraded libinstpatch (1.1.6-2 -> 1.1.6-3)
[2024-07-29T06:54:30-0500] [ALPM] upgraded libmythes (1:1.2.5-1 -> 1:1.2.5-2)
[2024-07-29T06:54:30-0500] [ALPM] upgraded libupnp (1.14.19-2 -> 1.14.19-3)
[2024-07-29T06:54:34-0500] [ALPM] upgraded linux66 (6.6.40-1 -> 6.6.41-1)
[2024-07-29T06:54:42-0500] [ALPM] upgraded linux66-headers (6.6.40-1 -> 6.6.41-1)
[2024-07-29T06:54:42-0500] [ALPM] upgraded linux66-virtualbox-host-modules (7.0.18-13 -> 7.0.20-2)
[2024-07-29T06:54:43-0500] [ALPM] upgraded llvm (18.1.8-3 -> 18.1.8-4)
[2024-07-29T06:54:43-0500] [ALPM] upgraded logrotate (3.21.0-2 -> 3.22.0-1)
[2024-07-29T06:54:43-0500] [ALPM] upgraded thin-provisioning-tools (1.0.12-1 -> 1.0.13-1)
[2024-07-29T06:54:43-0500] [ALPM] upgraded lvm2 (2.03.24-1 -> 2.03.25-2)
[2024-07-29T06:54:43-0500] [ALPM] upgraded manjaro-printer (20220924-1 -> 20240718-1)
[2024-07-29T06:54:44-0500] [ALPM] upgraded manjaro-release (24.0.4-1 -> 24.0.5-1)
[2024-07-29T06:54:44-0500] [ALPM] upgraded ndctl (78-2 -> 79-1)
[2024-07-29T06:54:44-0500] [ALPM] upgraded nftables (1:1.0.9-3 -> 1:1.1.0-2)
[2024-07-29T06:54:45-0500] [ALPM] upgraded nodejs (22.4.1-1 -> 22.5.1-1)
[2024-07-29T06:54:45-0500] [ALPM] upgraded openssl-1.1 (1.1.1.w-1 -> 1.1.1.w-2)
[2024-07-29T06:54:45-0500] [ALPM] upgraded openvpn (2.6.11-1 -> 2.6.12-1)
[2024-07-29T06:54:45-0500] [ALPM] upgraded powertop (2.15-1 -> 2.15-2)
[2024-07-29T06:54:45-0500] [ALPM] upgraded pybind11 (2.13.1-1 -> 2.13.1-2)
[2024-07-29T06:54:45-0500] [ALPM] upgraded python-coverage (7.5.1-1 -> 7.6.0-1)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-gmpy2 (2.2.0-1 -> 2.2.1-1)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-google-auth (2.30.0-1 -> 2.32.0-1)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-grpcio (1.64.2-2 -> 1.65.1-1)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-jaraco.text (3.12.1-1 -> 3.14.0-1)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-optree (0.11.0-2 -> 0.12.1-1)
[2024-07-29T06:54:46-0500] [ALPM] installed python-flexcache (0.3-2)
[2024-07-29T06:54:46-0500] [ALPM] installed python-flexparser (0.3.1-2)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-pint (0.23-2 -> 0.24.3-1)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-pure-eval (0.2.2-4 -> 0.2.3-1)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-pycurl (7.45.2-4 -> 7.45.3-1)
[2024-07-29T06:54:46-0500] [ALPM] upgraded python-pyqt5-sip (12.13.0-2 -> 12.15.0-1)
[2024-07-29T06:54:47-0500] [ALPM] upgraded qt5-base (5.15.14+kde+r141-1 -> 5.15.14+kde+r143-1)
[2024-07-29T06:54:48-0500] [ALPM] upgraded python-pyqt5 (5.15.10-2 -> 5.15.11-1)
[2024-07-29T06:54:48-0500] [ALPM] upgraded python-pyqt5-webengine (5.15.6-3 -> 5.15.7-1)
[2024-07-29T06:54:48-0500] [ALPM] upgraded python-pyqt6-sip (13.6.0-2 -> 13.8.0-1)
[2024-07-29T06:54:48-0500] [ALPM] upgraded python-pyqt6 (6.7.0-4 -> 6.7.1-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded python-sympy (1.13.0-1 -> 1.13.1-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded python-tomlkit (0.12.5-1 -> 0.13.0-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded python-tornado (6.4.0-2 -> 6.4.1-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded python-trove-classifiers (2024.5.22-1 -> 2024.7.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded python-urllib3 (1.26.18-3 -> 1.26.19-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-common (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-audio-alsa (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-audio-dbus (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-audio-jack (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-audio-oss (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-audio-pa (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-audio-pipewire (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-audio-sdl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-ui-opengl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-ui-spice-core (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:49-0500] [ALPM] upgraded qemu-audio-spice (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-img (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-system-x86-firmware (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded wolfssl (5.7.0-1 -> 5.7.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-system-x86 (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded virtiofsd (1.11.0-1 -> 1.11.1-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-base (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-block-curl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-block-dmg (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-block-nfs (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-block-ssh (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-chardev-spice (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-display-qxl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-display-virtio-gpu (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-display-virtio-gpu-gl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci-gl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-display-virtio-vga (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-display-virtio-vga-gl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-usb-host (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-usb-redirect (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-hw-usb-smartcard (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-ui-curses (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-ui-dbus (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-ui-egl-headless (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-ui-gtk (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-ui-sdl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-ui-spice-app (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-vhost-user-gpu (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qemu-desktop (9.0.1-1 -> 9.0.2-1)
[2024-07-29T06:54:50-0500] [ALPM] upgraded qqwing (1.3.4-6 -> 1.3.4-7)
[2024-07-29T06:54:50-0500] [ALPM] upgraded re2c (3.1-1 -> 3.1-2)
[2024-07-29T06:54:50-0500] [ALPM] upgraded rtkit (0.13-2 -> 0.13-3)
[2024-07-29T06:54:50-0500] [ALPM] upgraded semver (7.6.2-1 -> 7.6.3-1)
[2024-07-29T06:54:51-0500] [ALPM] upgraded sof-firmware (2024.03-1 -> 2024.06-1)
[2024-07-29T06:54:51-0500] [ALPM] upgraded sstp-client (1:1.0.19-1 -> 1:1.0.19-2)
[2024-07-29T06:54:51-0500] [ALPM] upgraded stress (1.0.6-1 -> 1.0.7-2)
[2024-07-29T06:54:51-0500] [ALPM] upgraded strongswan (5.9.13-2 -> 5.9.14-1)
[2024-07-29T06:54:52-0500] [ALPM] upgraded sudo (1.9.15.p5-1 -> 1.9.15.p5-2)
[2024-07-29T06:54:52-0500] [ALPM] upgraded suitesparse (7.7.0-1 -> 7.7.0-2)
[2024-07-29T06:54:52-0500] [ALPM] upgraded timeshift (24.06.2-1 -> 24.06.3-1)
[2024-07-29T06:54:52-0500] [ALPM-SCRIPTLET] TimeShift scheduled backups require the cronie.service to be running.
[2024-07-29T06:54:52-0500] [ALPM-SCRIPTLET] Try:
[2024-07-29T06:54:52-0500] [ALPM-SCRIPTLET]   systemctl enable --now cronie.service
[2024-07-29T06:54:52-0500] [ALPM] upgraded ttf-font-awesome (6.5.2-1 -> 6.6.0-1)
[2024-07-29T06:54:52-0500] [ALPM] upgraded ttf-hack (3.003-6 -> 3.003-7)
[2024-07-29T06:54:52-0500] [ALPM] upgraded uchardet (0.0.8-2 -> 0.0.8-3)
[2024-07-29T06:54:52-0500] [ALPM] upgraded usb_modeswitch (2.6.1-3 -> 2.6.1-4)
[2024-07-29T06:54:53-0500] [ALPM] upgraded virtualbox (7.0.18-1 -> 7.0.20-1)
[2024-07-29T06:54:53-0500] [ALPM] upgraded xorg-xrandr (1.5.2-1 -> 1.5.2-2)
[2024-07-29T06:54:53-0500] [ALPM] upgraded virtualbox-guest-utils (7.0.18-1 -> 7.0.20-1)
[2024-07-29T06:54:53-0500] [ALPM] upgraded webapp-manager (1.3.6-1 -> 1.3.7-1)
[2024-07-29T06:54:57-0500] [ALPM] upgraded wine (9.12-1 -> 9.13-1)
[2024-07-29T06:54:57-0500] [ALPM] upgraded wpebackend-fdo (1.14.2-1 -> 1.14.2-2)
[2024-07-29T06:54:57-0500] [ALPM] upgraded xdg-dbus-proxy (0.1.5-1 -> 0.1.5-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded xdg-user-dirs (0.18-1 -> 0.18-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded xdg-user-dirs-gtk (0.11-2 -> 0.11-3)
[2024-07-29T06:54:58-0500] [ALPM] upgraded xf86-input-void (1.4.2-1 -> 1.4.2-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded xorg-setxkbmap (1.3.4-1 -> 1.3.4-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded xorg-xhost (1.0.9-1 -> 1.0.9-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded xorg-xmodmap (1.0.11-1 -> 1.0.11-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded xorg-xinit (1.4.2-1 -> 1.4.2-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded xsel (1.2.1-1 -> 1.2.1-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded yelp-xsl (42.1-1 -> 42.1-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded zsh-autosuggestions (0.7.0-2 -> 0.7.0-3)
[2024-07-29T06:54:58-0500] [ALPM] upgraded zsh-completions (0.35.0-1 -> 0.35.0-2)
[2024-07-29T06:54:58-0500] [ALPM] upgraded zsh-history-substring-search (1.1.0-1 -> 1.1.0-2)
[2024-07-29T06:54:58-0500] [ALPM] installed asar (3.2.8-1)
[2024-07-29T06:54:58-0500] [ALPM] installed icoutils (0.32.3-3)
[2024-07-29T06:54:59-0500] [ALPM] transaction completed
[2024-07-29T06:55:04-0500] [ALPM] running '20-systemd-sysusers.hook'...
[2024-07-29T06:55:04-0500] [ALPM] running '30-systemd-binfmt.hook'...
[2024-07-29T06:55:05-0500] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-07-29T06:55:06-0500] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-07-29T06:55:06-0500] [ALPM] running '30-systemd-hwdb.hook'...
[2024-07-29T06:55:07-0500] [ALPM] running '30-systemd-tmpfiles.hook'...
[2024-07-29T06:55:08-0500] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-07-29T06:55:10-0500] [ALPM] running '30-systemd-update.hook'...
[2024-07-29T06:55:10-0500] [ALPM] running '30-update-mime-database.hook'...
[2024-07-29T06:55:11-0500] [ALPM] running '60-depmod.hook'...
[2024-07-29T06:55:17-0500] [ALPM] running '70-dkms-install.hook'...
[2024-07-29T06:55:17-0500] [ALPM-SCRIPTLET] ==> dkms install --no-depmod rtl8812au/5.13.6.r192.g8be3a1d -k 6.6.41-1-MANJARO
[2024-07-29T06:57:37-0500] [ALPM-SCRIPTLET] ==> dkms install --no-depmod 8821au/5.12.5.2.r230.g847c74b -k 6.6.41-1-MANJARO
[2024-07-29T07:00:04-0500] [ALPM-SCRIPTLET] ==> depmod 6.6.41-1-MANJARO
[2024-07-29T07:00:07-0500] [ALPM] running '90-mkinitcpio-install.hook'...
[2024-07-29T07:00:09-0500] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2024-07-29T07:00:09-0500] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2024-07-29T07:00:09-0500] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2024-07-29T07:00:09-0500] [ALPM-SCRIPTLET] ==> Starting build: '6.6.41-1-MANJARO'
[2024-07-29T07:00:09-0500] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2024-07-29T07:00:10-0500] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2024-07-29T07:00:10-0500] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2024-07-29T07:00:10-0500] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2024-07-29T07:00:12-0500] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2024-07-29T07:00:12-0500] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2024-07-29T07:00:12-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2024-07-29T07:00:13-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2024-07-29T07:00:14-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2024-07-29T07:00:14-0500] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2024-07-29T07:00:14-0500] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2024-07-29T07:00:14-0500] [ALPM-SCRIPTLET]   -> Running build hook: [plymouth]
[2024-07-29T07:00:16-0500] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2024-07-29T07:00:16-0500] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2024-07-29T07:00:16-0500] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-07-29T07:00:16-0500] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2024-07-29T07:00:17-0500] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2024-07-29T07:00:17-0500] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2024-07-29T07:00:17-0500] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
[2024-07-29T07:00:17-0500] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2024-07-29T07:00:17-0500] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
[2024-07-29T07:00:18-0500] [ALPM-SCRIPTLET] ==> Starting build: '6.6.41-1-MANJARO'
[2024-07-29T07:00:18-0500] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2024-07-29T07:00:18-0500] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2024-07-29T07:00:18-0500] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2024-07-29T07:00:28-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2024-07-29T07:00:28-0500] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2024-07-29T07:00:28-0500] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2024-07-29T07:00:30-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2024-07-29T07:00:30-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2024-07-29T07:00:30-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2024-07-29T07:00:30-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2024-07-29T07:00:31-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2024-07-29T07:00:31-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2024-07-29T07:00:31-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2024-07-29T07:00:34-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2024-07-29T07:00:36-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2024-07-29T07:00:36-0500] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2024-07-29T07:00:36-0500] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2024-07-29T07:00:36-0500] [ALPM-SCRIPTLET]   -> Running build hook: [plymouth]
[2024-07-29T07:00:38-0500] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2024-07-29T07:00:40-0500] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2024-07-29T07:00:43-0500] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-07-29T07:00:44-0500] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
[2024-07-29T07:00:45-0500] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2024-07-29T07:00:47-0500] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2024-07-29T07:00:47-0500] [ALPM] running '99-update-grub.hook'...
[2024-07-29T07:00:48-0500] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2024-07-29T07:00:48-0500] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2024-07-29T07:00:48-0500] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.6-x86_64
[2024-07-29T07:00:48-0500] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
[2024-07-29T07:00:48-0500] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
[2024-07-29T07:00:49-0500] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2024-07-29T07:00:49-0500] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2024-07-29T07:00:50-0500] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/sda1@/EFI/Microsoft/Boot/bootmgfw.efi
[2024-07-29T07:00:51-0500] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2024-07-29T07:00:51-0500] [ALPM-SCRIPTLET] Root filesystem isn't btrfs
[2024-07-29T07:00:51-0500] [ALPM-SCRIPTLET] If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
[2024-07-29T07:00:51-0500] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2024-07-29T07:00:51-0500] [ALPM-SCRIPTLET] Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
[2024-07-29T07:00:51-0500] [ALPM-SCRIPTLET] done
[2024-07-29T07:00:51-0500] [ALPM] running 'dbeaver.hook'...
[2024-07-29T07:00:51-0500] [ALPM] running 'dbus-reload.hook'...
[2024-07-29T07:00:51-0500] [ALPM] running 'dconf-update.hook'...
[2024-07-29T07:00:52-0500] [ALPM] running 'detect-old-perl-modules.hook'...
[2024-07-29T07:00:52-0500] [ALPM] running 'firefox-post.hook'...
[2024-07-29T07:00:53-0500] [ALPM] running 'fontconfig.hook'...
[2024-07-29T07:00:53-0500] [ALPM] running 'fontconfig-32.hook'...
[2024-07-29T07:00:53-0500] [ALPM] running 'gio-querymodules.hook'...
[2024-07-29T07:00:54-0500] [ALPM] running 'glib-compile-schemas.hook'...
[2024-07-29T07:00:54-0500] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2024-07-29T07:00:55-0500] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-07-29T07:00:55-0500] [ALPM] running 'gtk4-querymodules.hook'...
[2024-07-29T07:00:55-0500] [ALPM] running 'texinfo-install.hook'...
[2024-07-29T07:00:56-0500] [ALPM] running 'update-desktop-database.hook'...
[2024-07-29T07:05:19-0500] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-07-29T07:05:19-0500] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2024-07-29T07:05:19-0500] [ALPM] transaction started
[2024-07-29T07:05:21-0500] [ALPM] upgraded positron-ide-devel-bin (2024.07.0.100-1 -> 2024.07.0.107-1)
[2024-07-29T07:05:25-0500] [ALPM] upgraded mendeley-reference-manager (2.115.0-1 -> 2.119.0-1)
[2024-07-29T07:05:25-0500] [ALPM] upgraded notion-app-electron (3.10.0-1 -> 3.11.0-1)
[2024-07-29T07:05:26-0500] [ALPM] transaction completed
[2024-07-29T07:05:27-0500] [ALPM] running '30-systemd-update.hook'...
[2024-07-29T07:05:27-0500] [ALPM] running '30-update-mime-database.hook'...
[2024-07-29T07:05:28-0500] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-07-29T07:05:28-0500] [ALPM] running 'update-desktop-database.hook'...
[2024-07-29T17:55:20-0500] [ALPM] transaction started
[2024-07-29T17:55:21-0500] [ALPM] removed gitg (2:44-2)
[2024-07-29T17:55:21-0500] [ALPM] installed dpkg (1.22.6-1)
[2024-07-29T17:55:21-0500] [ALPM-SCRIPTLET]     dpkg installs Debian package manager.
[2024-07-29T17:55:21-0500] [ALPM-SCRIPTLET]     This is useful for those who want to create/modify DEB files.
[2024-07-29T17:55:21-0500] [ALPM-SCRIPTLET]     However, *do not* use dpkg to install Debian packages in your ArchLinux machine.
[2024-07-29T17:55:21-0500] [ALPM-SCRIPTLET]     This will break your system!
[2024-07-29T17:55:21-0500] [ALPM-SCRIPTLET]     You will need to go back to Arch wiki and read the installation guide again.
[2024-07-29T17:55:21-0500] [ALPM-SCRIPTLET]     You've been warned!
[2024-07-29T17:55:22-0500] [ALPM] installed netstandard-targeting-pack (8.0.6.sdk106-1)
[2024-07-29T17:55:22-0500] [ALPM] installed dotnet-targeting-pack (8.0.6.sdk106-1)
[2024-07-29T17:55:22-0500] [ALPM] installed dotnet-host (8.0.6.sdk106-1)
[2024-07-29T17:55:22-0500] [ALPM] installed dotnet-runtime (8.0.6.sdk106-1)
[2024-07-29T17:55:24-0500] [ALPM] installed dotnet-sdk (8.0.6.sdk106-1)
[2024-07-29T17:55:24-0500] [ALPM] transaction completed
[2024-07-29T17:55:24-0500] [ALPM] running '30-systemd-update.hook'...
[2024-07-29T17:55:25-0500] [ALPM] running 'glib-compile-schemas.hook'...
[2024-07-29T17:55:25-0500] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-07-29T17:55:25-0500] [ALPM] running 'update-desktop-database.hook'...
[2024-07-29T18:00:27-0500] [ALPM] transaction started
[2024-07-29T18:00:27-0500] [ALPM] installed git-credential-manager (2.5.1-1)
[2024-07-29T18:00:27-0500] [ALPM-SCRIPTLET] Configure Git to use Git Credential Manager via:
[2024-07-29T18:00:27-0500] [ALPM-SCRIPTLET]     git-credential-manager configure
[2024-07-29T18:00:27-0500] [ALPM-SCRIPTLET] Additionally, follow the guide here:
[2024-07-29T18:00:27-0500] [ALPM-SCRIPTLET] https://aka.ms/gcmcore-linuxcredstores
[2024-07-29T18:00:28-0500] [ALPM] transaction completed
[2024-07-29T18:00:28-0500] [ALPM] running '30-systemd-update.hook'...
[2024-07-29T18:00:39-0500] [ALPM] transaction started
[2024-07-29T18:00:39-0500] [ALPM] installed sourcegit-bin (8.23-1)
[2024-07-29T18:00:39-0500] [ALPM] transaction completed
[2024-07-29T18:00:40-0500] [ALPM] running '30-systemd-update.hook'...
[2024-07-29T18:00:40-0500] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-07-29T18:00:40-0500] [ALPM] running 'update-desktop-database.hook'...
[2024-07-30T03:10:29-0500] [PAMAC] synchronizing package lists
[2024-07-30T03:10:40-0500] [PAMAC] synchronizing package lists
[2024-07-30T10:36:13-0500] [PAMAC] synchronizing package lists
[2024-07-30T10:36:32-0500] [PAMAC] synchronizing package lists
[2024-07-30T10:36:49-0500] [PAMAC] synchronizing package lists
[2024-07-30T16:12:12-0500] [PAMAC] synchronizing package lists
[2024-07-30T16:13:03-0500] [PACMAN] Running 'pacman -S -y --config /etc/pacman.conf --'
[2024-07-30T16:13:03-0500] [PACMAN] synchronizing package lists
[2024-07-30T16:13:16-0500] [PACMAN] Running 'pacman -S -y -u --config /etc/pacman.conf --'
[2024-07-30T16:13:16-0500] [PACMAN] synchronizing package lists
[2024-07-30T16:13:16-0500] [PACMAN] starting full system upgrade
[2024-07-30T16:13:22-0500] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-07-30T16:13:22-0500] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2024-07-30T16:13:22-0500] [ALPM] transaction started
[2024-07-30T16:13:22-0500] [ALPM] upgraded gnome-shell-extension-arc-menu (57-1 -> 58-1)
[2024-07-30T16:13:22-0500] [ALPM] upgraded gnome-shell-extension-gtk4-desktop-icons-ng (1:78-1 -> 1:79-1)
[2024-07-30T16:13:23-0500] [ALPM] transaction completed
[2024-07-30T16:13:23-0500] [ALPM] running '30-systemd-update.hook'...
[2024-07-30T16:13:23-0500] [ALPM] running 'glib-compile-schemas.hook'...
[2024-07-30T20:52:16-0500] [PAMAC] synchronizing package lists
[2024-07-31T09:19:35-0500] [PAMAC] synchronizing package lists
[2024-07-31T09:20:26-0500] [PAMAC] synchronizing package lists
Thank you.
Hello,
btw about forum tags this isn’t neither a kde issues and neither a gnome issue
Do you really need gconf?
The problems are these AUR pkgbuilds or maybe something in your environment is interfering
Use pacman instead.
sudo pacman -Syu
In order to update the base system - disregard everything AUR
You can - if you must - also use yay or pamac, but instruct it to ignore AUR at first.
Deal wit AUR later - even uninstall anything AUR which might be blocking your update.
You can reinstall it later.
Those will need to be reinstalled/rebuilt anyway.
mumuh does exactly this on every update for you:
mkay - another layer of “complexity” -
of which I didn’t know
I just do it myself. :wink:
Yeah.
I realize that. It was a shameless plug for mumuh, the script I built to handle updates and if something goes wrong, prepare and provide a formatted forum post, ready to be used.
:wink:
nice! :ok_hand:
I think so too.
This means that somebody’s been writing and/or editing the PKGBUILD on a Windows system.
Windows uses the CP/M- and DOS-derived combination of a carriage return character and a newline character as the end-of-line marker, while UNIX uses only a newline character.
The way around it would be to download the PKGBUILD file, open it with an editor and remove the carriage return characters at the end of each line — most UNIX editors will display those characters as . And then you can use makepkg to build the package — see the man page.
Another option to clean the file would be to install dos2unix from the repository and run that command against the corrupt PKGBUILD file.
Notepadd ++ for winboze or notepadqq for linux can convert line endings between the two formats. In the edit menu i think.
Thank you to everyone, I searched on CRLF errors on linux and I found the solution on https://github.com/Jguer/yay/issues/1024 , the problem was git and this is the solution:
git config --global core.autocrlf false
rm -r ~/.cache/yay
