Can't update on pamac because of authorization problems
Hi guys,
when I’m trying to update my software from pamac im getting authentication failures.
When updating via the GUI its just closing the authentication window and pamac freezes.
When updating via the CLI its showing:
Authenticating as: jimdoesntcarry
Password:
Cancelled
==== AUTHENTICATION FAILED ====
and the terminal freezes.
Here is the output of my polkit service:
● polkit.service - Authorization Manager
     Loaded: loaded (/usr/lib/systemd/system/polkit.service; static)
     Active: active (running) since Fri 2024-06-28 19:22:58 CEST; 16min ago
       Docs: man:polkit(8)
   Main PID: 817 (polkitd)
      Tasks: 4 (limit: 38386)
     Memory: 8.1M (peak: 9.4M)
        CPU: 846ms
     CGroup: /system.slice/polkit.service
             └─817 /usr/lib/polkit-1/polkitd --no-debug
Jun 28 19:22:58 PC polkitd[817]: Finished loading, compiling and executing 12 rules
Jun 28 19:22:58 PC polkitd[817]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 28 19:22:58 PC systemd[1]: Started Authorization Manager.
Jun 28 19:23:04 PC polkitd[817]: Registered Authentication Agent for unix-session:1 (system bus name :1.21 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Jun 28 19:24:29 PC polkitd[817]: Registered Authentication Agent for unix-session:3 (system bus name :1.87 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Jun 28 19:24:31 PC polkitd[817]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.21, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected from bus)
Jun 28 19:27:07 PC polkitd[817]: Registered Authentication Agent for unix-process:3477:25634 (system bus name :1.179 [pkttyagent], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Jun 28 19:27:18 PC polkitd[817]: Unregistered Authentication Agent for unix-process:3477:25634 (system bus name :1.179, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected from bus)
Jun 28 19:27:18 PC polkitd[817]: Operator of unix-process:3477:25634 FAILED to authenticate to gain authorization for action org.manjaro.pamac.commit for system-bus-name::1.177 [pamac update] (owned by unix-user:jimdoesntcarry)
Jun 28 19:31:03 PC polkitd[817]: Operator of unix-session:3 FAILED to authenticate to gain authorization for action org.manjaro.pamac.commit for system-bus-name::1.264 [/usr/bin/pamac-manager --gapplication-service] (owned by unix-user:jimdoesntcarry)
I hope somebody can help me.
Thanks in advance.
Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro
base: Arch Linux
Processes: 430 Power: uptime: 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.5 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.34
you’re asked to input your password to proceed. didn’t you ?
Is your username really spelled in camelcase? Normally, UNIX usernames have to be in all-lowercase.
Yes I did enter it, but no matter what I enter-> cancelled
I just changed it for my post and didn’t think about that ^^
Please never change any of the data that you are sharing with us with respect to what it is really like on your system. Doing so will make it very hard for us to diagnose what the problem is, and as they say, the devil is in the details.
Understandable! I’m sorry for the inconvinience!
