When i run sudo pacman -Syyu i get the following error:
error: mesa: signature from “Laurent Carlier lordheavym@gmail.com ” is invalid
:: File /var/cache/pacman/pkg/mesa-21.0.3-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
I’ve tried changing mirrors and updating my system time. Neither worked
Delete the corrupted download with
sudo rm /var/cache/pacman/pkg/mesa-21.0.3-3-x86_64.pkg.tar.zst
Then try the update again.
I tried everything but sudo pacman -U /var/cache/pacman/pkg/mesa-21.0.3-3-x86_64.pkg.tar.zst it didn’t work
Delete the corrupted package /var/cache/pacman/pkg/mesa-21.0.3-3-x86_64.pkg.tar.zst, and then try the update again.
I’m experiencing the same. I have no archive to delete, pacman did that. Got new keys, but still the same error.
sudo pacman -Sy archlinux-keyring manjaro-keyring
sudo pacman-key --populate archlinux manjaro
sudo pacman-key --refresh-keys
sudo pacman -Syu
I just tested it on my end and it works. If you still have the issue you can do it like this:
wget https://archlinux.org/packages/extra/x86_64/mesa/download/
sudo pacman -U mesa*pkg*
sudo pacman -Syu
This worked for me. It must’ve been updated since yesterday
system
Closed
22 May 2021 15:12
11
