Can't update due to conflict between packages kpeople
Hi there.
No software will be installed due to a package conflict.
Linux Manjaro 6.1.49 is currently installed .When attempting to upgrade, the process will terminate due to a package conflict kpeople and kpeplevcard
:: Replace threadweaver with extra/threadweaver5? [Y/n] y
Resolving conflicts between files... Looking for conflicting packages...
Error: Transaction Preparation Failed (Dependencies Cannot Be Satisfied)
:: Removing kpeople will create a dependency conflict for the "kpeople" package on which kpeoplevcard depends
:: Removing kcontacts will create a dependency conflict for the "kcontacts" package on which kpeoplevcard depends
I will be very grateful for your help
Use search function. There is 100 same, solved topics already. Solution is also mentioned in every 2nd post of Stable announcements in the past 6 months.
The issue and a workaround is mentioned under kpeoplevcard update requires manual intervention and dates back to the [Stable Update] 2023-11-06 announcement.
Manjaro is a rolling release and requires attention to frequent updates.
Any issues are usually listed in the respective Update announcement, which I advise you always should check before performing any update. Cheers.
