Can't update anydesk-bin
Hello,
When I try to update my system I get this error:
anydesk-7.0.2-amd64.tar.gz ... FAILED
==> ERROR: One or more files did not pass the validity check!
Error: Failed to build anydesk-bin
What can I do to fix it?
Thank you in advance,
Mauricio
I just built it successfully on my Testing branch system:
  -> Generating .PKGINFO file...
  -> Generating .BUILDINFO file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: anydesk-bin 7.0.2-1 (Tue 12 Aug 2025 09:18:45)
==> Cleaning up...
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Installing anydesk-bin (7.0.2-1)...
Reloading system manager configuration...
Arming ConditionNeedsUpdate...
Updating the desktop file MIME type cache...
Maybe try cleaning your build files first to remove a possibly corrupted source file:
pamac clean --build-files
and then reattempt the build:
pamac build anydesk-bin
Same story here - pamac install anydesk-bin worked, you got a failed valididty check, not sure how that works but clean it out and go again - maybe just a glitch.
Hey @scotty65,
My bad! I should have tried that before asking.
It turns out it was just a cache issue.
Thank you for your prompt help!
Regards,
Mauricio
