Hello again I installed Easy Effects via Discover and when I now hit the “Remove” button in discover it says: Dependency resolution failed (Translated with Google Translate)
sudo pacman -Rss easyeffects
Worked! Ty ![]()
But how can I also remove the audio devices that were created?
Easy Effects Source & Sink are still there Easy Effects Source & Sink are still there
cd .config
ls | grep easy
any existing folder that could rely on easyeffects ?
ls | grep easy
Shows this:
easyeffects
rm -rf ~/.config/easyeffects
reboot, check and report
Rebooted, everything seems to be gone thanks again! <3
Just a word of caution: Discover should not be used for installing anything system-related. You can use it for installing themes and widgets, but don’t use it for software. Use pamac or pacman instead. ![]()
