Can't Uninstall Discord Snap
This is the first issue I’m seriously struggling with in a long time. I tried to launch Discord (Snap version), but it simply won’t. I tried uninstalling it, but I get this error:
status-code=500 kind=(null) message=system does not fully support snapd: cannot mount squashfs image using “squashfs”:
mount: /tmp/syscheck-mountpoint-3983320642: /dev/loop23 already mounted or mount point busy.
dmesg(1) may have more information after failed mount system call.
I tried reinstalling snapd and squashfs, but that doesn’t work. Any ideas?
Seems like you already used that mount point.
Snaps, being lovely as they are, are all mounted during system start.
Yes, all of them, including all various versions, and even if you never open a snap program.
Clean up your snaps and restart.
You can look at them (and maybe see unnecessary duplicates) with
snap list
Interesting, I’ve never had to “clean up my snaps” before… Honestly, I don’t use them much. This is the output for “snap list”:
Name Version Rev Tracking Publisher Notes
bare 1.0 5 latest/stable canonical✓ base
core18 20231027 2812 latest/stable canonical✓ base
core20 20240227 2264 latest/stable canonical✓ base
core22 20240408 1380 latest/stable canonical✓ base
cups 2.4.7-8 1044 latest/stable openprinting✓ -
discord 0.0.51 188 latest/stable snapcrafters✪ -
dosbox-x 2023.10.06 1261 latest/stable snapcrafters✪ -
gnome-3-28-1804 3.28.0-19-g98f9e67.98f9e67 198 latest/stable canonical✓ -
gnome-3-38-2004 0+git.efb213a 143 latest/stable canonical✓ -
gnome-42-2204 0+git.510a601 176 latest/stable canonical✓ -
gtk-common-themes 0.1-81-g442e511 1535 latest/stable canonical✓ -
snapd 2.62 21465 latest/stable canonical✓ snapd
Is there a command to clean them up, or is that a dumb question?
Not dumb.
But snaps dont offer something perfectly easy.
There are some script-magiks to remove ‘disabled’ ones … but it appears none of yours are disabled.
Here is an example anyways
LANG=C snap list --all | awk '/disabled/{print $1, $3}' | while read -r snapname revision; do sudo snap remove "$snapname" --revision="$revision" ; done
But you do have multiples of a sort - multiple gnome’s and multiple core’s
If I were you and wanted to keep some of them, I would begin by removing any I dont need and aiming for the oldest iteration of any duplicates.
sudo snap remove gnome-3-28-1804
Here is the archwiki on snaps just because
https://wiki.archlinux.org/title/Snap
I tried that, but still get the same “error: system does not fully support snapd: cannot mount squashfs image using “squashfs”: -----”
Im wondering if there is something more largely wrong with the environment.
Is this system on bare metal?
Maybe lets get system info.
I notice your profile kernel is listed as 5.12, but that is not correct, right?
inxi -Farz
Yes, it’s on bare metal. The kernel is 6.8
inxi -Farz output:
 Kernel: 6.8.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
    root=UUID=a0802bff-61ff-41f8-90ac-9efb870863e4 rw quiet apparmor=1
    security=apparmor resume=UUID=0b135afd-3010-4506-8b2e-2e2497bdb930
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 with: latte-dock vt: 2 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550 Steel Legend
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: P2.10 date: 08/04/2021
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2199 high: 2200 min/max: 2200/4874 boost: enabled
    scaling: driver: acpi-cpufreq governor: powersave cores: 1: 2196 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
    12: 2200 bogomips: 88664
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
    vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, Writeback-1
    bus-ID: 09:00.0 chip-ID: 1002:73df class-ID: 0300
  Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: DP-3 mapped: DisplayPort-2 model: Samsung LC27G5xT
    serial: <filter> built: 2021 res: 2560x1440 hz: 144 dpi: 93 gamma: 1.2
    size: 698x393mm (27.48x15.47") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
    navi22 LLVM 16.0.6 DRM 3.57 6.8.5-1-MANJARO) device-ID: 1002:73df
    memory: 11.72 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.2-manjaro1.1
    device-ID: 1002:73df surfaces: xcb,xlib
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Corsair VOID ELITE Wireless Gaming Dongle
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 1b1c:0a51 class-ID: 0300
  API: ALSA v: k6.8.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 4.1 TiB used: 636.08 GiB (15.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT343.4 temp: 26.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 111110WD temp: 41.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253X5480G
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 61.3 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZRX-00L4HB0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1A01 scheme: MBR
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-9YN162
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC47 scheme: MBR
  ID-1: / raw-size: 944.77 GiB size: 928.86 GiB (98.32%)
    used: 636.05 GiB (68.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 25.9 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 34.5 C mobo: 33.0 C gpu: amdgpu temp: 41.0 C
    mem: 36.0 C
  Fan Speeds (rpm): fan-1: 356 fan-2: 797 fan-3: 300 fan-4: 0 fan-5: 582
    fan-6: 0 fan-7: 576 gpu: amdgpu fan: 0
  Packages: 1940 pm: dpkg pkgs: 0 pm: pacman pkgs: 1912 libs: 495 tools: pamac
    pm: flatpak pkgs: 15 pm: snap pkgs: 13
    1: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    2: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    3: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    5: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    6: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    8: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    10: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    11: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    13: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    15: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    16: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    18: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    19: https://repos.silknet.com/manjaro/stable/$repo/$arch
    20: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    21: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    22: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    23: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    24: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    26: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    27: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    28: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    29: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    30: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    31: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    33: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    34: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    35: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    37: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    38: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    39: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    40: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    41: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    42: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    43: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    44: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    45: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    46: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    47: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    48: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    49: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    50: http://manjaro.grena.ge/stable/$repo/$arch
    51: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    52: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    53: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    54: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    55: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    56: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    57: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    58: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    59: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    60: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    61: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    62: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    63: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    64: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    65: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    66: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    67: https://mirror.23m.com/manjaro/stable/$repo/$arch
    68: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    69: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    70: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    71: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    72: https://mirror.init7.net/manjaro/stable/$repo/$arch
    73: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
    74: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    75: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
    76: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    77: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    78: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    79: https://linorg.usp.br/manjaro/stable/$repo/$arch
    80: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    81: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    82: https://manjaro.kurdy.org/stable/$repo/$arch
    83: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    84: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    85: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    86: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    87: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    88: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    89: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    90: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    91: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    92: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    93: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    94: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    95: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    96: https://manjaro.kyberorg.fi/stable/$repo/$arch
    97: https://mirrors2.manjaro.org/stable/$repo/$arch
    98: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    99: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    100: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    101: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
  Memory: total: 32 GiB available: 31.27 GiB used: 2.73 GiB (8.7%)
  Processes: 312 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.5 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: yakuake inxi: 3.3.34
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Ah.
I forgot.
SNAPs do not work with kernel 6.8.
This is an ubuntu thing, and they apparently dont care.
There are some topics here on the matter.
In the meantime to use SNAP - try 6.6
oh, really? that’s kinda weird. I’ll just roll it back and then install the repo version. Thank you so much for your help!
Well sure enough, I rolled the kernel back and Bob’s yer uncle, it works now. Thank you again cscs!
