I recently updated my laptop but I can’t turn it off , it get stuck on black screen but I can see my mouse pointer, this went for around half an hour then I had to force turn off my laptop.
When I plugged in my charger I can’t see battery icon but when I plugged it out I can see battery icon.
Hi, a bit of system info may help here:
inxi -zv8
(highlight pasted output and click the </> at the top of the reply window).
There is also REISUB which can avoid a hard power-off:
Thanks !
Kernel: 5.10.226-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f2158531-513d-457e-99eb-962cabe45fbd rw quiet apparmor=1
security=apparmor resume=UUID=d4a2bbfe-f657-4b6d-ad7b-291b32ce3bb1
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0FGN4M v: A00 serial: <superuser required> part-nu: 078C
uuid: <superuser required> UEFI: Dell v: 2.10.0 date: 05/10/2019
ID-1: BAT0 charge: 7.8 Wh (30.7%) condition: 25.4/41.4 Wh (61.2%)
volts: 15.2 min: 14.8 model: SMP DELL GR43778 type: Li-ion serial: <filter>
status: charging
System RAM: total: 8 GiB available: 7.64 GiB used: 1.65 GiB (21.6%)
Device-1: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered)
size: 4 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: 80AD000080AD part-no: HMA851S6AFR6N-UH serial: <filter>
Device-2: DIMM B type: DDR4 detail: synchronous unbuffered (unregistered)
manufacturer: 80CE000080CE part-no: M471A5244BB0-CRC serial: <filter>
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
Topology: cpus: 1x dies: 1 cores: 2 threads: 4 tpc: 2 smt: enabled cache:
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 400/2000 scaling: driver: intel_pstate
governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 16006
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
chip-ID: 1bcf:28c0 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0690 built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329
y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 3.73 GiB unified: yes
API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu
name: Intel HD Graphics 520 (SKL GT2) driver: mesa intel v: 24.2.4-arch1.0.1
device-ID: 8086:1916 surfaces: xcb,xlib
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70
class-ID: 0403
API: ALSA v: k5.10.226-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 0cf3:e009
class-ID: e001
Local Storage: total: 931.51 GiB used: 833.71 GiB (89.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1002 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C2
dev-links: cdrom
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 82.35 GiB (84.1%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: f2158531-513d-457e-99eb-962cabe45fbd
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6699-007E
ID-3: /mnt/be9fd59c-519e-4b50-a158-0e15e4410673 raw-size: 822.42 GiB
size: 808.43 GiB (98.30%) used: 751.36 GiB (92.9%) fs: ext4 dev: /dev/sda4
maj-min: 8:4 label: N/A uuid: be9fd59c-519e-4b50-a158-0e15e4410673
ID-1: swap-1 type: partition size: 8.59 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: d4a2bbfe-f657-4b6d-ad7b-291b32ce3bb1
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Sunplus Innovation Integrated_Webcam_HD type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1bcf:28c0 class-ID: 0e02
Device-2: 1-6:3 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-3: 1-8:4 info: Qualcomm Atheros type: bluetooth driver: btusb
power: 100mA chip-ID: 0cf3:e009 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 40.0 C pch: 40.0 C mobo: 40.0 C
Fan Speeds (rpm): cpu: 0
Packages: 1674 pm: pacman pkgs: 1670 libs: 457 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 4
1: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
2: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
3: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
7: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
8: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 203
1: cpu: 100% command: ps pid: 2514 mem: 3.30 MiB (0.0%)
2: cpu: 11.5% command: chromium pid: 1919 mem: 121.7 MiB (1.5%)
3: cpu: 10.0% command: chromium pid: 2257 mem: 232.9 MiB (2.9%)
4: cpu: 7.7% command: chromium pid: 1871 mem: 277.5 MiB (3.5%)
5: cpu: 7.4% command: zsh pid: 2450 mem: 12.4 MiB (0.1%)
Memory top: 5 of 203
1: mem: 304.5 MiB (3.8%) command: plasmashell pid: 999 cpu: 1.0%
2: mem: 277.5 MiB (3.5%) command: chromium pid: 1871 cpu: 7.7%
3: mem: 232.9 MiB (2.9%) command: chromium pid: 2257 cpu: 10.0%
4: mem: 172.4 MiB (2.2%) command: chromium pid: 2305 cpu: 2.4%
5: mem: 160.6 MiB (2.0%) command: kwin_x11 pid: 977 cpu: 4.3%
Processes: 203 Power: uptime: 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.36
Thanks!
What I’d suggest with the first one is try the linux66 (LTS) kernel. Your machine appears to be new enough to work fine with that.
For the icon, you can set visibility in Plasma by right-clicking on an empty space in the notifications area, selecting Configure System Tray, click Entries, then you can set visibility per item as you desire.
Cheers!
You may also want to review the Known Issues from the 2024-10-01 stable update > KDE Plasma hangs on Shutdown, Restart and Logout.
Ohh Thanks it did help
updating to newer kernel didn’t work but below post shared by @Takakage worked
but going to ==> Status and notification ==> Entries
did resolve battery icon issue
Thank you !
