I recently upgraded my kernel to 6.1.25-1 (LTS).
After upgrading i cant switch power profiles. Power profile is stuck at balanced mode.
cat /sys/firmware/acpi/platform_profile_choices
shows 3 profiles cool / balanced / performance
but when i try to change my power profile
powerprofilesctl set performance
it gives the following error
Failed to communicate with power-profiles-daemon: g-io-error-quark: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._g_2dio_2derror_2dquark.Code15: Error writing ‘/sys/firmware/acpi/platform_profile’: Operation not supported (15)
and
sudo systemctl status power-profiles-daemon
shows
Failed to activate driver ‘platform_profile’: Error writing ‘/sys/firmware/acpi/platform_profile’: Operation not supported
DEVICE DETAILS
OS: Manjaro Linux x86_64
Host: OMEN by HP Laptop 15-dc1xxx
Kernel: 6.1.25-1-MANJARO
Uptime: 11 mins
Packages: 1279 (pacman)
Shell: zsh 5.9
Resolution: 1920x1080, 1920x1080
DE: GNOME 43.4
WM: Mutter
WM Theme: CustomAccentColors
Theme: Adw-dark [GTK2/3]
Icons: Papirus-Dark-Maia [GTK2/3]
Terminal: gnome-terminal
CPU: Intel i7-9750H (12) @ 4.500GHz
GPU: NVIDIA GeForce GTX 1650 Mobile / Max-Q
GPU: Intel CoffeeLake-H GT2 [UHD Graphics 630]
Memory: 3449MiB / 15802MiB
