If I try to suspend or hibernate my laptop, the cursor disappears, it turns the networking and bluetooth off, but the screens stays on. After let’s say 10 seconds it just turns back everything and works as if nothing happened. Thanks for your help in advance!
Does that work? If yes, please continue to the next step. If not, note the time and provide the relevant journalctl --system --boot=0 --priority=3 entries.
Log in.
Hibernate
Does that work? If yes, please continue to the next step. If not, note the time and provide the relevant journalctl --system --boot=0 --priority=3 entries (I.E. excluding everything before #4)
Start your applications one by one and try hibernating until your problem arises. The last application you started prevents your computer from hibernating: use its configuration page to disable that feature if that’s what you really want.
3.It work without an issue.
5.I get a blank screen only with some error message in the corner. It says something like: no irq handler for vector.
Here is the output you asked for:
jún 23 18:44:15 DGDELL kernel: ACPI BIOS Error (bug): Could not resolve symbol >
jún 23 18:44:15 DGDELL kernel: ACPI Error: Aborting method \_TZ.TZ00._TMP due t>
jún 23 18:44:15 DGDELL kernel: ACPI Error: Aborting method \_TZ.TZ01._TMP due t>
jún 23 18:45:40 DGDELL kernel: ACPI BIOS Error (bug): Could not resolve symbol >
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FNCL due to pre>
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN04._ON due to>
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN03._ON due to>
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN02._ON due to>
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN01._ON due to>
lines 1-23...skipping...
-- Journal begins at Sun 2021-03-14 22:29:27 CET, ends at Wed 2021-06-23 18:46:43 CEST. --
jún 23 18:44:15 DGDELL kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPCB.HEC.ECAV], AE_NOT_FOUND (20200925/psargs-330)
jún 23 18:44:15 DGDELL kernel: ACPI Error: Aborting method \_TZ.TZ00._TMP due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
jún 23 18:44:15 DGDELL kernel: ACPI Error: Aborting method \_TZ.TZ01._TMP due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
jún 23 18:45:40 DGDELL kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPCB.HEC.ECAV], AE_NOT_FOUND (20200925/psargs-330)
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FNCL due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN04._ON due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN03._ON due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN02._ON due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN01._ON due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
jún 23 18:45:40 DGDELL kernel: ACPI Error: Aborting method \_TZ.FN00._ON due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
jún 23 18:45:40 DGDELL kernel: __common_interrupt: 5.33 No irq handler for vector
jún 23 18:45:40 DGDELL kernel: acpi-fan PNP0C0B:00: Error updating fan power state
jún 23 18:45:40 DGDELL kernel: PM: dpm_run_callback(): platform_pm_restore+0x0/0x40 returns -19
jún 23 18:45:40 DGDELL kernel: PM: Device PNP0C0B:00 failed to restore: error -19
jún 23 18:45:40 DGDELL kernel: acpi-fan PNP0C0B:01: Error updating fan power state
jún 23 18:45:40 DGDELL kernel: PM: Device PNP0C0B:01 failed to restore: error -19
jún 23 18:45:40 DGDELL kernel: acpi-fan PNP0C0B:02: Error updating fan power state
jún 23 18:45:40 DGDELL kernel: PM: Device PNP0C0B:02 failed to restore: error -19
jún 23 18:45:40 DGDELL kernel: acpi-fan PNP0C0B:03: Error updating fan power state
jún 23 18:45:40 DGDELL kernel: PM: Device PNP0C0B:03 failed to restore: error -19
jún 27 18:06:36 DGDELL kernel: Freezing of tasks failed after 20.008 seconds (1 tasks refusing to freeze, wq_busy=0):
jún 27 18:06:36 DGDELL systemd-sleep[36957]: Failed to suspend system. System resumed again: Device or resource busy
jún 27 18:06:42 DGDELL bluetoothd[816]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
jún 27 18:06:42 DGDELL systemd[1]: Failed to start Hibernate.
Disabled bluetooth service with this command: sudo systemctl disable bluetooth.service
It is still the same.
I even removed blueman and then disabled the bluetooth service, but it is still preventing hibernation.
These are the entries now:
jún 28 13:22:14 DGDELL kernel: Freezing of tasks failed after 20.010 seconds (1 tasks refusing to freeze, wq_busy=0):
jún 28 13:22:14 DGDELL systemd-sleep[21220]: Failed to suspend system. System resumed again: Device or resource busy
jún 28 13:22:20 DGDELL bluetoothd[1069]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
jún 28 13:22:20 DGDELL systemd[1]: Failed to start Hibernate.
for some meaningful text that identifies the task. (“around”" = Both before and after)
If that doesn’t identify the actual task(s), increase the priority step by step from 4 to 5, 6, 7 (don’t immediately take 7 as that is debug level) until the offending task is identified. Then feed back, please.
I found this, what looks like the crash report, I guess.
journalctl --system --boot=0 --priority=6
jún 28 17:02:44 DGDELL kernel: Freezing of tasks failed after 20.007 seconds (1 tasks refusing to freeze, wq_busy=0):
jún 28 17:02:44 DGDELL kernel: task:baloo_file state:D stack: 0 pid: 1427 ppid: 1238 flags:0x00004084
jún 28 17:02:44 DGDELL kernel: Call Trace:
jún 28 17:02:44 DGDELL kernel: __schedule+0x288/0x800
jún 28 17:02:44 DGDELL kernel: schedule+0x5b/0xc0
jún 28 17:02:44 DGDELL kernel: request_wait_answer+0xa8/0x200 [fuse]
jún 28 17:02:44 DGDELL kernel: ? wait_woken+0x80/0x80
jún 28 17:02:44 DGDELL kernel: fuse_simple_request+0x19b/0x310 [fuse]
jún 28 17:02:44 DGDELL kernel: fuse_readdir_uncached+0x182/0x7a0 [fuse]
jún 28 17:02:44 DGDELL kernel: ? kmem_cache_free+0x103/0x460
jún 28 17:02:44 DGDELL kernel: ? filename_lookup+0x127/0x1b0
jún 28 17:02:44 DGDELL kernel: fuse_readdir+0x149/0x6a0 [fuse]
jún 28 17:02:44 DGDELL kernel: ? apparmor_file_permission+0x6b/0x160
jún 28 17:02:44 DGDELL kernel: iterate_dir+0x164/0x1b0
jún 28 17:02:44 DGDELL kernel: __x64_sys_getdents64+0x80/0x120
jún 28 17:02:44 DGDELL kernel: ? __ia32_compat_sys_getdents+0x120/0x120
jún 28 17:02:44 DGDELL kernel: ? syscall_trace_enter.constprop.0+0x12c/0x1b0
jún 28 17:02:44 DGDELL kernel: do_syscall_64+0x33/0x40
jún 28 17:02:44 DGDELL kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
jún 28 17:02:44 DGDELL kernel: RIP: 0033:0x7f8a77588897
jún 28 17:02:44 DGDELL kernel: RSP: 002b:00007fff19526d78 EFLAGS: 00000293 ORIG_RAX: 00000000000000d9
jún 28 17:02:44 DGDELL kernel: RAX: ffffffffffffffda RBX: 00005647b0e4aa20 RCX: 00007f8a77588897
jún 28 17:02:44 DGDELL kernel: RDX: 0000000000008000 RSI: 00005647b0e4aa50 RDI: 000000000000000e
jún 28 17:02:44 DGDELL kernel: RBP: 00005647b0e4aa50 R08: 0000000000000030 R09: 00007f8a77681a60
jún 28 17:02:44 DGDELL kernel: R10: 00005647b0e3a0a0 R11: 0000000000000293 R12: ffffffffffffff08
jún 28 17:02:44 DGDELL kernel: R13: 00005647b0e4aa24 R14: 0000000000000002 R15: 00007fff19526ea0
Before this it shuts down the network manager successfully, then unregisters the bluetooth connections successfully. With priority level 7 I found nothing useful, other than the same with level 6.
This message comes from, in my understanding, when the system restarts itself, and just doesn’t find my headphones, because it was turned off.
Once the offending task is identified, disable that task and file a bug report for that one so the problem will go away in the future for you and everyone else.
In your specific case, disabling baloo as:
Baloo (the file indexer) crashes when going to sleep.
