Hello,
Upon boot I get this output below.
Can’t put system to sleep.
[jesuslinux@A9410 ~]$ sudo journalctl -b
[sudo] password for jesuslinux:
fev 01 20:33:43 A9410 kernel: Linux version 6.6.10-1-MANJARO (builduser@fv-az1496-324) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutil>
fev 01 20:33:43 A9410 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=b9c1fd33-2f73-4159-9a12-ed4859c31e0f rw quie>
fev 01 20:33:43 A9410 kernel: BIOS-provided physical RAM map:
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000dd61ffff] usable
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000dd620000-0x00000000dd741fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000dd742000-0x00000000dd784fff] ACPI data
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000dd785000-0x00000000ddc2afff] ACPI NVS
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000ddc2b000-0x00000000ddf44fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000ddf45000-0x00000000de0ddfff] usable
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000de0de000-0x00000000de618fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000de619000-0x00000000dec3efff] usable
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000dec3f000-0x00000000deff7fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000deff8000-0x00000000deffffff] usable
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000fe600000-0x00000000fe6fffff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000fedc0000-0x00000000fedc0fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedc8fff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
fev 01 20:33:43 A9410 kernel: BIOS-e820: [mem 0x0000000100000000-0x00000001feffffff] usable
fev 01 20:33:43 A9410 kernel: NX (Execute Disable) protection: active
fev 01 20:33:43 A9410 kernel: APIC: Static calls initialized
fev 01 20:33:43 A9410 kernel: e820: update [mem 0xcc2e6018-0xcc2f5c57] usable ==> usable
...skipping...
fev 01 21:32:14 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:32:20 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:32:25 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:32:30 A9410 systemd[1]: systemd-timedated.service: Deactivated successfully.
fev 01 21:32:36 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:32:41 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:32:46 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:32:51 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:32:55 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:33:05 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:33:11 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:35:24 A9410 rtkit-daemon[770]: Supervising 7 threads of 4 processes of 1 users.
fev 01 21:37:50 A9410 systemd[658]: Started dbus-:1.2-org.xfce.Xfconf@2.service.
fev 01 21:37:50 A9410 polkitd[432]: Registered Authentication Agent for unix-process:2717:385863 (system bus name :1.89 [flatpak list]>
fev 01 21:37:50 A9410 polkitd[432]: Unregistered Authentication Agent for unix-process:2717:385863 (system bus name :1.89, object path>
fev 01 21:37:59 A9410 sudo[2835]: jesuslinux : TTY=pts/0 ; PWD=/home/jesuslinux ; USER=root ; COMMAND=/usr/bin/journalctl -b
fev 01 21:37:59 A9410 sudo[2835]: pam_unix(sudo:session): session opened for user root(uid=0) by jesuslinux(uid=1000)
...skipping...
Is it a kernel issue?
I tried with other LTS kernel and it’s the same…
What is your issue? There is nothing in the log indicating any errors or attempts or suspending.
I get this when I try to suspend laptop.
Also when I close lid (its set to suspend) I can’t login with my password.
Also is the output from above normal?
Log after I tried to suspend system:
...skipping...
fev 01 22:38:00 A9410 rtkit-daemon[770]: Supervising 8 threads of 5 processes of 1 users.
fev 01 22:46:28 A9410 systemd[658]: Started dbus-:1.2-org.xfce.Xfconf@3.service.
fev 01 22:46:33 A9410 rtkit-daemon[770]: Supervising 8 threads of 5 processes of 1 users.
fev 01 22:48:06 A9410 rtkit-daemon[770]: Supervising 8 threads of 5 processes of 1 users.
fev 01 22:53:47 A9410 NetworkManager[428]: <info> [1706828027.3327] dhcp4 (wlo1): state changed new lease, address=192.168.43.127
fev 01 22:53:47 A9410 systemd[1]: Starting Network Manager Script Dispatcher Service...
fev 01 22:53:47 A9410 systemd[1]: Started Network Manager Script Dispatcher Service.
fev 01 22:53:57 A9410 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
fev 01 22:54:40 A9410 rtkit-daemon[770]: Supervising 8 threads of 5 processes of 1 users.
fev 01 22:55:47 A9410 systemd[658]: Started dbus-:1.2-org.xfce.Xfconf@4.service.
fev 01 22:55:48 A9410 polkitd[432]: Registered Authentication Agent for unix-process:4258:853588 (system bus name :1.110 [flatpak list>
fev 01 22:55:48 A9410 polkitd[432]: Unregistered Authentication Agent for unix-process:4258:853588 (system bus name :1.110, object pat>
fev 01 23:00:01 A9410 CROND[4429]: (root) CMD (timeshift --check --scripted)
fev 01 23:00:01 A9410 CROND[4428]: (root) CMDOUT (Mounted '/dev/sda7' at '/run/timeshift/4429/backup')
fev 01 23:00:01 A9410 CROND[4428]: (root) CMDOUT (Monthly snapshot are enabled)
fev 01 23:00:01 A9410 CROND[4428]: (root) CMDOUT (Last monthly snapshot is 1 days old)
fev 01 23:00:01 A9410 CROND[4428]: (root) CMDOUT (------------------------------------------------------------------------------)
fev 01 23:00:01 A9410 crontab[4457]: (root) LIST (root)
fev 01 23:00:01 A9410 crontab[4458]: (root) LIST (root)
fev 01 23:00:01 A9410 systemd[1]: run-timeshift-4429-backup.mount: Deactivated successfully.
fev 01 23:00:01 A9410 CROND[4428]: (root) CMDEND (timeshift --check --scripted)
fev 01 23:00:16 A9410 sudo[4468]: jesuslinux : TTY=pts/0 ; PWD=/home/jesuslinux ; USER=root ; COMMAND=/usr/bin/journalctl -b
fev 01 23:00:16 A9410 sudo[4468]: pam_unix(sudo:session): session opened for user root(uid=0) by jesuslinux(uid=1000)
lines 1835-1862/1862 (END)
Hello,
In the a laptop that I fresh installed Manjaro XFCE a month or so ago I can’t put it to sleep.
This appears:
![image](https://forum.manjaro.org/uploads/default/original/3X/5/e/5e525a588d06175d93d6d14708f30fe11372f906.png)
Also the lock screen button on Whisker Menu does nothing.
I have been trying several things and reading the forum to no avail.
System is up to date running
6.6.10-1-MANJARO
Already tried running the previous LTS Kernel on boot and the same thing happens.
Also checked Power Manager and Session Startup on Settings.
How do I resolve this?
Thanks
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=b9c1fd33-2f73-4159-9a12-ed4859c31e0f rw quiet splash apparmor=1
security=apparmor resume=UUID=4a33bf11-5d98-47c4-96d8-a5f475484937
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Notebook v: N/A
Mobo: HP model: 81FB v: 80.21 serial: <superuser required>
UEFI: American Megatrends v: F.32 date: 04/26/2019
ID-1: BAT0 charge: 26.4 Wh (100.0%) condition: 26.4/26.4 Wh (100.0%)
volts: 8.5 min: 7.7 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: full cycles: 237
System RAM: total: 8 GiB note: est. available: 7.22 GiB
used: 3.59 GiB (49.8%)
Info: model: AMD A9-9410 RADEON R5 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
arch: Excavator level: v3 note: check built: 2015 process: GF 28nm
family: 0x15 (21) model-id: 0x70 (112) stepping: 0 microcode: 0x6006705
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1747 high: 1775 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1775 2: 1720
bogomips: 11583
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce tsc tsc_scale v_vmsave_vmload
vgif vmcb_clean vme vmmcall wdt xop xsave xsaveopt
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Sunplus Innovation HP Wide Vision HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:3
chip-ID: 1bcf:2c87 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c6 built: 2013 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1366x768 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.5 vendor: amd mesa v: 23.3.3-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon R5 Graphics (radeonsi stoney LLVM
16.0.6 DRM 3.54 6.6.10-1-MANJARO) device-ID: 1002:98e4 memory: 500 MiB
unified: no
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:b723
class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:4 chip-ID: 0bda:b008
Local Storage: total: 238.47 GiB used: 105.06 GiB (44.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SKC600256G
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH61
dev-links: cdrom
ID-1: / raw-size: 99.5 GiB size: 97.38 GiB (97.87%) used: 40.66 GiB (41.8%)
fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: b9c1fd33-2f73-4159-9a12-ed4859c31e0f
ID-2: /boot/efi raw-size: 512.6 MiB size: 511.6 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: B86F-09A6
ID-3: /mnt/AED21046D2101565 raw-size: 129.87 GiB size: 129.87 GiB (100.00%)
used: 64.4 GiB (49.6%) fs: ntfs dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: AED21046D2101565
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 4a33bf11-5d98-47c4-96d8-a5f475484937
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: A20F-4ADA
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 500 MiB fs: ntfs label: N/A
uuid: 101203091202F38E
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.3:3 info: Sunplus Innovation HP Wide Vision HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 1bcf:2c87 class-ID: 0e02
Device-2: 1-1.4:4 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 2-1:2 info: MOSART Semi. 2.4G Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3938:1031 class-ID: 0301
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 64.1 C mobo: N/A gpu: amdgpu temp: 64.0 C
Fan Speeds (rpm): N/A
Processes: 202 Uptime: 3h 28m wakeups: 1 Init: systemd v: 255
Packages: 1206 pm: pacman pkgs: 1199 libs: 359 tools: pamac pm: flatpak
pkgs: 7 Shell: Bash v: 5.2.21 running-in: xfce4-terminal inxi: 3.3.31
