Can't start steam (libGL error)
Hello, I just booted my system and can’t start steam now, It was working perfectly before reboot. Tried searching error on google, nothing works.
Steam log:
steam.sh[2263]: Running Steam on manjarolinux 21.1.6 64-bit
steam.sh[2263]: STEAM_RUNTIME is enabled automatically
setup.sh[2336]: Steam runtime environment up-to-date!
steam.sh[2263]: Steam client's requirements are satisfied
[2021-12-05 18:23:44] Startup - updater built Nov 22 2021 22:06:59
Installing breakpad exception handler for appid(steam)/version(1637624439)
libGL error: MESA-LOADER: failed to open iris: libffi.so.7: wrong ELF class: ELFCLASS64 (search paths /usr/lib32/dri, suffix _dri)
libGL error: failed to load driver: iris
libGL error: MESA-LOADER: failed to open swrast: libffi.so.7: wrong ELF class: ELFCLASS64 (search paths /usr/lib32/dri, suffix _dri)
libGL error: failed to load driver: swrast
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
Major opcode of failed request:  152 (GLX)
Minor opcode of failed request:  3 (X_GLXCreateContext)
Value in failed request:  0x0
Serial number of failed request:  48
xerror_handler: X failed, continuing
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2021-12-05 18:23:44] Loading cached metrics from disk (/home/user/.local/share/Steam/package/steam_client_metrics.bin)
[2021-12-05 18:23:44] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-12-05 18:23:44] Using the following download hosts for Public, Realm steamglobal
[2021-12-05 18:23:44] 1. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-12-05 18:23:44] Checking for update on startup
[2021-12-05 18:23:44] Checking for available updates...
[2021-12-05 18:23:44] Downloading manifest: http://media.steampowered.com/client/steam_client_ubuntu12
[2021-12-05 18:23:44] Download skipped: /client/steam_client_ubuntu12 version 1637624439, installed version 1637624439, existing pending version 0
[2021-12-05 18:23:44] Nothing to do
[2021-12-05 18:23:44] Verifying installation...
[2021-12-05 18:23:44] Performing checksum verification of executable files
[2021-12-05 18:23:45] Verification complete
Loaded SDL version 2.0.17-6897280
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:2405): Gtk-WARNING **: 18:23:45.830: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
Steam: An X Error occurred
X Error of failed request:  BadMatch (invalid parameter attributes)
Serial number of failed request:  49
crash_20211205182345_4.dmp[2412]: Uploading dump (out-of-process)
/tmp/dumps/crash_20211205182345_4.dmp
/home/user/.local/share/Steam/steam.sh: line 794:  2405 Segmentation fault      (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
Welcome to the forum! :wave:
Sounds like a driver issue.
Please post your system info as outlined here:
Actually it’s an issue running Steam, he hasn’t been able to play a game yet. :wink:
