Can't start a system after update
After updating my system [incl. kernel] I didn’t restart a pc, but run a hibernation [yes, my fault]. The system didn’t start after this,
systemd-journald.service start operation timed out terminating
and
Failed to start  Journal Service
I can’t enter TTY [ctrl+alt+F1/2 gives no effect], so I booted from liveusb. After succesfully mounting the partition [it’s encrypted] I can’t chroot into the system:
grub-probe error: cannot find a GRUB drive for /dev/sdb1. Check your device.map
GRUB is on other partition, but it’s mounted and I can see files inside. It’s EFI.
Any ideas for next steps?
You did try to boot at least one time after the failed attempt?
Or did you just go straight to booting the live system?
How did you (attempt to) do that?
With:
manjaro-chroot -a
That won’t work with an encrypted system.
You need to mount the partitions in the proper order yourself,
to /mnt for example,
then chroot by:
manjaro-chroot /mnt
When attempting to chroot please provide all output. Is /dev/sdb1 the expected partition? Please, provide as well output of
sudo fdisk -l
and explain what partitions are of relevance.
Thanks for your quick and helpful answer!
Yes, I tried couple of times.
So I have succesfully chrooted into the system, there’re some broken dependencies related to the package electron30 [I hate this package, always problems, on every update]. How can I ignore those from here? I am using:
pamac upgrade && pamac upgrade --aur --devel || echo -e
This is from AUR. Uninstall it, update normal repos by
sudo pacman -Syu
and then rebuilt it.
Don’t put it one ignore - it will keep being a problem.
Fix it properly - uninstall it and use a repo version if possible - or uninstall, update the base system and then tend to whatever AUR packages.
updating repos works but when it comes to actually upgrading:
System has not been booted with systemd as init system (PID 1) can't operate.
Failed to connect to system scope bus via local transport: Host is down
So: how did you do it?
Had to unmount and close luks partition with cryptsetup first, then open again from terminal with cryptsetup and mount.
Too vague.
But that’s fine when you know what you are doing.
I asked again because I have never seen this (error) message in a chroot scenario.
  1. I have created /mnt/boot and /mnt/root.
  2. Mounted sda2 [boot partition] to /mnt/boot
  3. Tried to open sda1 [root] with cryptsetup but it said it’s already mounted/mapped
  4. cryptsetup --type luks close /dev/sda1 [uuid]
  5. then the same but reopen
  6. mount -v /dev/mapper/[luks-id]
  7. manjaro-chroot /mnt but didn’t work
  8. manjaro-chroot /mnt/root
Still vague, but it doesn’t look right from what you described.
First mount / (the encrypted system root) - then /boot onto it, if it is separate.
Else you’ll end up with / “blocking” your /boot … (if you first mount /boot, then / onto/over it)
… but that kind of layout isn’t standard
lsblk -f
before and after the mount steps is what I do to identify the partitions and make sure I mount in the correct spot and order.
sda 8:0 0 476.9G 0 disk
├─sda1 8:1 0 250G 0 part
│ └─623ea5ad-e9b5-48cc-af3c-a72c069db48b 254:0 0 250G 0 crypt /mnt/root
├─sda2 8:2 0 256M 0 part /mnt/boot
├─sda3 8:3 0 148.1G 0 part
└─sda4 8:4 0 24G 0 part
So first I will mount sda1 as /mnt/root and then sda2 as /mnt/root/boot, right?
Please provide system information as described below.
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
…and…
Update Announcements
Required reading
Resources
I believe you may benefit from
Basically: Yes
But why so complicated?
lsblk -f
is more transparent (tells you more, gives more information) than whatever command you used.
From what I know so far:
Mount crypt to /mnt.
Then mount (sda2) /boot to /mnt/boot
… if you know that /dev/sda2 holds the contents of /boot
It is not a layout produced by a standard installation - this has got an unencrypted EFI partition and this needs to be mounted to /boot/efi
You can check /etc/fstab in the decrypted partition once you mounted it.
Here as an example the process on my system - it is a VM
lsblk -f         ✔
NAME   FSTYPE      FSVER            LABEL             UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0  squashfs    4.0        0   100% /run/miso/sfs/livefs
loop1  squashfs    4.0        0   100% /run/miso/sfs/mhwdfs
loop2  squashfs    4.0        0   100% /run/miso/sfs/desktopfs
loop3  squashfs    4.0        0   100% /run/miso/sfs/rootfs
sr0    iso9660     Joliet Extension MANJARO_XFCE_2421 2024-12-16-11-22-45-00                     0   100% /run/miso/bootmnt
vda
├─vda1 vfat        FAT32                              2630-51D3
└─vda2 crypto_LUKS 1                                  2aefff29-916e-47fe-959e-2213881b5487
vdb
└─vdb1 ext4        1.0              pacmancache       98195df8-0bc0-4b79-abb7-8ea21d40999f
sudo cryptsetup open /dev/vda2 crypt         ✔
Geben Sie die Passphrase für »/dev/vda2« ein:
sudo mount /dev/mapper/crypt /mnt
cat /mnt/etc/fstab         ✔
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=2630-51D3                            /boot/efi      vfat    defaults,umask=0077 0 2
/dev/mapper/luks-2aefff29-916e-47fe-959e-2213881b5487 /              ext4    defaults   0 1
UUID=98195df8-0bc0-4b79-abb7-8ea21d40999f /var/cache/pacman/pkg ext4 defaults 0 1
note this line:
sudo mount /dev/vda1 /mnt/boot/efi
manjaro-chroot /mnt /bin/bash
→ I’m in chroot
OK, thanks for your help. It always amazes me how great is Linux community :slight_smile:
So:
  1. The sda2 was indeed to be mounted as /boot/efi, thanks for advice to check fstab. I’m not familiar with this efi-related layout… :confused:
  2. I have found another alien package - fsearch - thanks for the tutorial telling me how to identify those
  3. Now I’m having upgrade run successfully, I’ll edit this message if it’ll help
Unfortunately an update of the system didn’t resolve the problem yet:
dev-sdb1.device: Job dev-sdb1.device/start timed out.
Timed out waiting for device dev/sdb1
Dependency failed for media/m
and
systemd-journal.service: start operation timed out. Terminating
systemd-journal.service: State 'stop-sigterm' timed out. Killing
We don’t know what /dev/sdb1 is or whether it is in /etc/fstab.
Apparently it is mentioned somewhere.
… still no system information to go off of …
inxi -zv8
contents of /etc/fstab could help to shed light …
Perhaps it is in /etc/fstab, but not physically present? Who knows …
Sorry, couldn’t run web browser from liveusb nor copy the output, here’s fstab:
UUID=24C7-868A                                          /boot/efi   vfat    umask=0077          0 2
/dev/mapper/luks-1fe07266-2764-41a7-87ee-771dea9e8e02   /           ext4    noatime             0 1
UUID=15f54ad7-083d-45c2-bbd4-5f5bd715aa3e               swap        swap    noatime             0 0
tmpfs                                                   /tmp        tmpfs   noatime,mode=1777   0 0
/dev/sdb1                                               /media/m    ntfs    nofail              0 0
inxi:
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDEM_2421 quiet
    systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
    radeon.modeset=1
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Laptop System: Dell product: Latitude E5470 v: N/A
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: Dell model: 03MT0C v: A00 serial: <superuser required> part-nu: 06DE
    uuid: <superuser required> UEFI-[Legacy]: Dell v: 1.21.6 date: 10/02/2019
  ID-1: BAT0 charge: 44.3 Wh (84.7%) condition: 52.3/62.0 Wh (84.3%)
    volts: 8.5 min: 7.6 model: LGC-LGC4.20 DELL HK6DV type: Li-ion
    serial: <filter> status: charging
  System RAM: total: 16 GiB available: 15.31 GiB used: 2.52 GiB (16.4%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: DIMM A type: DDR4 detail: synchronous size: 16 GiB
    speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: SK Hynix part-no: HMA82GS6MFR8N-TF serial: <filter>
  Device-2: DIMM B type: no module installed
  Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 500 min/max: 400/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 22408
    sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Topaz XT [Radeon R7 M260/M265
    / M340/M360 M440/M445 530/535 620/625 Mobile] vendor: Dell driver: N/A
    alternate: amdgpu arch: GCN-3 code: Volcanic Islands process: TSMC 28nm
    built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6900 class-ID: 0380
  Device-3: Sunplus Innovation Integrated_Webcam_FHD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
    chip-ID: 1bcf:2b93 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x103d built: 2015 res: 1920x1080
    hz: 60 dpi: 158 gamma: 1.2 chroma: red: x: 0.643 y: 0.333 green: x: 0.314
    y: 0.627 blue: x: 0.157 y: 0.059 white: x: 0.314 y: 0.329
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 7.47 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 520 (SKL GT2) driver: N/A device-ID: 8086:1916
    surfaces: xcb,xlib
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d70
    class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
  IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
  IF-ID-1: wwp0s20f0u2i12 state: down mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:8 chip-ID: 8087:0a2b
    class-ID: e001
  Local Storage: total: 480.69 GiB used: 0 KiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLN512HMJP-000L7
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1L6Q scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 model: General size: 3.75 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
    mode: 2.0 tech: N/A serial: <filter> fw-rev: 5.00 scheme: MBR
  Message: No partition data found.
  ID-1: /dev/sda2 maj-min: 8:2 size: 256 MiB fs: vfat label: N/A
    uuid: 24C7-868A
  ID-2: /dev/sda3 maj-min: 8:3 size: 148.1 GiB fs: ntfs label: win
    uuid: 48640FA16A1A063F
  ID-3: /dev/sda4 maj-min: 8:4 size: 24 GiB fs: swap label: N/A
    uuid: 15f54ad7-083d-45c2-bbd4-5f5bd715aa3e
  ID-4: /dev/sdb1 maj-min: 8:17 size: 3.37 GiB fs: iso9660
  ID-5: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 9600-2AFB
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:9 info: Areson Corp Elecom MR-K013 Multicard Reader
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 25a7:fa61 class-ID: 0301
  Device-2: 1-2:2 info: Sunplus Innovation Integrated_Webcam_FHD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1bcf:2b93 class-ID: 0e02
  Device-3: 1-3:3 info: LogiLink UDisk flash drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: abcd:1234 class-ID: 0806
    serial: <filter>
  Hub-2: 1-4:4 info: Dell internal USB Hub of E-Port Replicator ports: 3
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 413c:2513 class-ID: 0900
  Device-1: 1-5:5 info: Elan Micro Touchscreen type: HID
    driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
    chip-ID: 04f3:20ba class-ID: 0300
  Hub-3: 1-6:6 info: Dell internal USB Hub of E-Port Replicator ports: 3
  Device-1: 1-7:7 info: Broadcom 5880 type: smart card driver: N/A
    interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0a5c:5834 class-ID: 0b00 serial: <filter>
  Device-2: 1-8:8 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Hub-4: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  Device-1: 2-2:2 info: Dell DW5811e Snapdragon™ X7 LTE
    type: communication,CDC-data driver: cdc_mbim interfaces: 2 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
    chip-ID: 413c:81b6 class-ID: 0a00 serial: <filter>
  System Temperatures: cpu: 57.0 C pch: 50.5 C mobo: 45.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1172 libs: 316 tools: pamac
    1: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    2: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    3: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    4: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    5: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    6: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    7: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    9: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    10: https://mirrors2.manjaro.org/stable/$repo/$arch
    11: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    12: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    13: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    14: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    15: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    16: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    17: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    18: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    19: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    20: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    21: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    22: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    23: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    24: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    25: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    26: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    27: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    28: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    30: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    31: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    32: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    33: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    34: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    35: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    36: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    37: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    39: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    40: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    41: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    42: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    43: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    44: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    45: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    46: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    47: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    48: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    49: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    50: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    51: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    52: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    53: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    54: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    55: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    56: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    57: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    58: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    59: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    60: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    62: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    63: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://mirror.23m.com/manjaro/stable/$repo/$arch
    65: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    66: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    67: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    68: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    69: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    70: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    71: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    72: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    74: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    75: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    76: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    78: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    79: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    80: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    81: https://manjaro.ynh.ovh/stable/$repo/$arch
    82: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    83: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    84: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    85: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    86: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    87: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    88: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    89: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    90: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    91: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    92: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    93: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    94: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    95: https://linorg.usp.br/manjaro/stable/$repo/$arch
    96: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    97: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    98: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    99: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    100: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    101: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    102: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    103: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    104: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    105: https://repos.silknet.com/manjaro/stable/$repo/$arch
    106: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    107: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    108: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    109: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    110: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    111: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    112: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    113: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    114: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    115: http://manjaro.mirror.ac.za/stable/$repo/$arch
    116: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    117: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    118: https://mirror.init7.net/manjaro/stable/$repo/$arch
    119: https://manjaro.kurdy.org/stable/$repo/$arch
    120: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    121: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    122: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    123: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    124: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    125: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    126: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    127: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    128: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    129: http://manjaro.grena.ge/stable/$repo/$arch
    130: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    131: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    132: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 211
  1: cpu: 100% command: ps pid: 2598 mem: 3.26 MiB (0.0%)
  2: cpu: 64.5% command: firefox pid: 1999 mem: 436.3 MiB (2.7%)
  3: cpu: 18.2% command: firefox pid: 2322 mem: 264.0 MiB (1.6%)
  4: cpu: 9.2% command: firefox pid: 2361 mem: 185.0 MiB (1.1%)
  5: cpu: 8.9% command: kwin_x11 pid: 1213 mem: 167.7 MiB (1.0%)
  Memory top: 5 of 211
  1: mem: 436.3 MiB (2.7%) command: firefox pid: 1999 cpu: 64.5%
  2: mem: 277.7 MiB (1.7%) command: plasmashell pid: 1270 cpu: 5.4%
  3: mem: 264.0 MiB (1.6%) command: firefox pid: 2322 cpu: 18.2%
  4: mem: 185.0 MiB (1.1%) command: firefox pid: 2361 cpu: 9.2%
  5: mem: 167.7 MiB (1.0%) command: kwin_x11 pid: 1213 cpu: 8.9%
  Processes: 211 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.08 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.36
