Weird boot up, so I force re-start.
I last left my pc on suspend. I wake it by pressing spacebar. Nothing happened. Not even grub showed, the screen would turn on but just display black. I press the restart button on my pc and this time the Mobo logo showed. It takes me straight to my desktop, bypassing login.
My environment changed.
the effects:
I load to the default background, the task bar is missing, all my virtual desktops are gone (and their custom wallpapers), the task bar is gone, I’m logged out of all applications and
pulseaudio --start
returns
Deamon startup failed
so that means no audio.
I feel lucky to find that the application launcher actually opens with meta key.
My homescreen icons are in the same place, though.
What I have tried
I have restarted my pc a few times, logged in/out. I went to a different user and their environment is fine.
My system is up-to-date: sudo pacman -Suy
tells me there is nothing to do.
Edit: output of inxi
Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=b5020253-8d75-4ad1-abef-d3d0c07dffe0 ro quiet apparmor=1
security=apparmor resume=UUID=462e5d82-aebf-4886-8a60-8a8afd2cf5d5
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <filter> UEFI [Legacy]: American Megatrends v: 5220 date: 09/12/2019
RAM: total: 15.63 GiB used: 2.8 GiB (17.9%)
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D L2 cache: 3 MiB
bogomips: 92265
Speed: 1472 MHz min/max: 1550/3850 MHz boost: disabled Core speeds (MHz):
1: 1472 2: 1409 3: 1374 4: 1374 5: 1529 6: 1375 7: 1329 8: 2164 9: 3518
10: 1535 11: 1534 12: 2529
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus ID: 09:00.0
chip ID: 10de:1b83 class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 09:00.1 chip ID: 10de:10f0
class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0b:00.3 chip ID: 1022:1457 class ID: 0403
Device-3: Cambridge Silicon Radio FiiO BTR3K type: USB driver: snd-usb-audio
bus ID: 1-2:2 chip ID: 0a12:1004 class ID: 0102 serial: <filter>
Device-4: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-3:3 chip ID: 046d:081b class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.11.2-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 03:00.0
chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000
bus ID: 08:00.0 chip ID: 8086:2723 class ID: 0280
IF: wlp8s0 state: up mac: <filter>
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-6:4
chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 350.27 GiB used: 66.63 GiB (19.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS256GSSD370S
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 6KB scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 120GB
size: 111.8 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 00RL scheme: MBR
ID-1: / raw size: 94.6 GiB size: 92.61 GiB (97.90%) used: 66.63 GiB (71.9%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: b5020253-8d75-4ad1-abef-d3d0c07dffe0
ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 462e5d82-aebf-4886-8a60-8a8afd2cf5d5
ID-1: /dev/sda1 maj-min: 8:1 size: 238.47 GiB fs: f2fs label: N/A
uuid: ed197c39-70fa-469a-854e-ce3364c126ab
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-2:2 info: Cambridge Silicon Radio FiiO BTR3K type: Audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-2: 1-3:3 info: Logitech Webcam C310 type: Video,Audio
Device-3: 1-6:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029 class ID: e001
Device-4: 1-7:5 info: Hoksi DURGOD Taurus K320 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 2f68:0082 class ID: 0300
Device-5: 1-10:6 info: Razer USA Viper (wired) type: Mouse,Keyboard
chip ID: 1532:0078 class ID: 0301
chip ID: 1d6b:0003 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 28.4 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 343 Uptime: 1h 52m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1292 pacman: 1288 lib: 416 flatpak: 4 Shell: fish
v: 3.1.2 default: Bash v: 5.1.0 running in: xfce4-terminal inxi: 3.3.01
I cannot find anything about this after lots of searching. Is it an expected result of something I must have done?
