noam
29 March 2021 20:36
1
Hello,
I’m using Manjaro for a while, after the latest Manjaro update, I can’t shutdown, reboot, or suspend the system properly.
When I shutdown/reboot:
Monitors turn black but the PC not shutting off.
When I suspend:
Systems go down but can’t resume.
I’ve tried installing Nvidia 450xx drivers and going back to kernel 5.4 but it didn’t help.
I don’t really know how to debug power issues, any guidance will be appreciated.
❯ inxi -Fza --no-host
System: Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=93ad7007-7506-4571-a86d-1e002de5f073 rw quiet
udev.log_priority=3 intel_idle.max_cstate=1 intel_iommu=off
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: Gigabyte model: Z68AP-D3 serial: <filter> UEFI: Award v: FD date: 03/20/2012
CPU: Info: Quad Core model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 cache: L2: 8 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 54295
Speed: 3691 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 3691 2: 3692 3: 3691 4: 3692 5: 3691 6: 3692 7: 3692
8: 3691
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: NVIDIA GK106 [GeForce GTX 660] driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:11c0 class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.4x13.5") s-diag: 1252mm (49.3")
Monitor-1: DP-1.8 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DP-1.1 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: GeForce GTX 660/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GK106 HDMI Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0b class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: de00 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR5416 Wireless Network Adapter [AR5008 802.11bgn] driver: ath9k v: kernel port: de00
bus-ID: 06:00.0 chip-ID: 168c:0023 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Drives: Local Storage: total: 1.46 TiB used: 122.04 GiB (8.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: R013 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZRX-00A8LB0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1A01 scheme: MBR
Partition: ID-1: / raw-size: 446.63 GiB size: 438.62 GiB (98.21%) used: 122.04 GiB (27.8%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 15.61 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 34%
Info: Processes: 251 Uptime: 16m wakeups: 0 Memory: 23.47 GiB used: 3.46 GiB (14.7%) Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1476 lib: 391 flatpak: 0 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.03
❯ sudo mhwd-kernel -li
Currently running: 5.10.23-1-MANJARO (linux510)
* linux510
* linux54
❯ sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
noam
2 April 2021 11:48
3
Hi, @Fabby , thanks a lot for your response!
Didn’t know about the REISUB/SUO, this will save me a lot of cold power downs.
I’ve followed your instructions and successfully managed to reboot using the SysRq method.
Added the following output as well.
Besides, I know my setup is quite old, almost 10 years old. Do you think I should use an older kernel? and not the latest (currently I use 5.10).
#59 0x00007fe0beca55f7 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x275f7)
#60 0x00007fe0beca55f7 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x275f7)
#61 0x00007fe0beca55f7 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x275f7)
#62 0x00007fe0beca55f7 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x275f7)
#63 0x00007fe0beca55f7 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x275f7)
Stack trace of thread 1146:
#0 0x00007fe0be32ebf3 pselect (libc.so.6 + 0xf6bf3)
#1 0x00007fe0bc9f7524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
#2 0x00007fe0bc9f88a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
#3 0x00007fe0bd826299 start_thread (libpthread.so.0 + 0x9299)
#4 0x00007fe0be337053 __clone (libc.so.6 + 0xff053)
Stack trace of thread 1141:
#0 0x00007fe0be2fff4b getdents64 (libc.so.6 + 0xc7f4b)
#1 0x00007fe0be2ffffd readdir (libc.so.6 + 0xc7ffd)
#2 0x00007fe0be96e67c n/a (libQt5Core.so.5 + 0x24767c)
#3 0x00007fe0be8fdc0e n/a (libQt5Core.so.5 + 0x1d6c0e)
#4 0x00007fe0be8fe4bb n/a (libQt5Core.so.5 + 0x1d74bb)
#5 0x00007fe0be8fe93e _ZN12QDirIteratorC2ERK7QString6QFlagsIN4QDir6FilterEES3_INS_12IteratorFlagEE (libQt5Core.so.5 + 0x1d793e)
#6 0x00005651b0020107 n/a (baloo_file + 0x21107)
#7 0x00005651b002a37e n/a (baloo_file + 0x2b37e)
#8 0x00005651b0028c99 n/a (baloo_file + 0x29c99)
#9 0x00007fe0bea09532 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2e2532)
#10 0x00007fe0be9dca00 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2b5a00)
#11 0x00007fe0be9df523 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x2b8523)
#12 0x00007fe0bea36054 n/a (libQt5Core.so.5 + 0x30f054)
#13 0x00007fe0bcf69b84 g_main_context_dispatch (libglib-2.0.so.0 + 0x53b84)
#14 0x00007fe0bcfbdc21 n/a (libglib-2.0.so.0 + 0xa7c21)
#15 0x00007fe0bcf683b1 g_main_context_iteration (libglib-2.0.so.0 + 0x523b1)
#16 0x00007fe0bea35691 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e691)
#17 0x00007fe0be9db3ac _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43ac)
#18 0x00007fe0be9e3844 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2bc844)
#19 0x00005651b000c2b4 n/a (baloo_file + 0xd2b4)
#20 0x00007fe0be25fb25 __libc_start_main (libc.so.6 + 0x27b25)
#21 0x00005651b000c4be n/a (baloo_file + 0xd4be)
Stack trace of thread 1145:
#0 0x00007fe0be32c37f __poll (libc.so.6 + 0xf437f)
#1 0x00007fe0bcfbdbaf n/a (libglib-2.0.so.0 + 0xa7baf)
#2 0x00007fe0bcf683b1 g_main_context_iteration (libglib-2.0.so.0 + 0x523b1)
#3 0x00007fe0bea35691 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e691)
#4 0x00007fe0be9db3ac _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43ac)
#5 0x00007fe0be7f3d12 _ZN7QThread4execEv (libQt5Core.so.5 + 0xccd12)
#6 0x00007fe0becc9098 n/a (libQt5DBus.so.5 + 0x17098)
#7 0x00007fe0be7f4eff n/a (libQt5Core.so.5 + 0xcdeff)
#8 0x00007fe0bd826299 start_thread (libpthread.so.0 + 0x9299)
#9 0x00007fe0be337053 __clone (libc.so.6 + 0xff053)
Apr 02 14:30:53 manjaro pulseaudio[1165]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
I know I used to have this issue before and the solution was related to the GPU driver I think. But I don’t remember exactly. Aren’t power-related issues sometimes happen because of the driver?
Here:
root=UUID=93ad7007-7506-4571-a86d-1e002de5f073 rw udev.log_priority=3
Console: tty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: Gigabyte model: Z68AP-D3 serial: N/A UEFI: Award v: FD
date: 03/20/2012
RAM: total: 23.47 GiB used: 2.57 GiB (11.0%)
Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
note: est. voltage: 5.0
Device-1: A0 size: 4 GiB info: single-bank speed: 1333 MT/s type: Unknown
detail: none bus-width: 2244 bits total: 2304 bits manufacturer: N/A
part-no: N/A serial: N/A
Device-2: A1 size: 4 GiB info: single-bank speed: 1333 MT/s type: Unknown
Device-3: A2 size: 8 GiB info: single-bank speed: 1333 MT/s type: Unknown
detail: none bus-width: 2052 bits total: 2304 bits manufacturer: N/A
Device-4: A3 size: 8 GiB info: single-bank speed: 1333 MT/s type: Unknown
Info: Quad Core model: Intel Core i7-3770 socket: 478 (1155) note: check
stepping: 9 microcode: 21 cache: L1: 64 KiB L2: 8 MiB bogomips: 54300
Speed: 3693 MHz min/max: 1600/3900 MHz base/boost: 3700/4000 volts: 1.0 V
ext-clock: 100 MHz Core speeds (MHz): 1: 3693 2: 3692 3: 3692 4: 3691
5: 3692 6: 3692 7: 3692 8: 3692
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:11c0
class-ID: 0300
Display: server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia
direct render: Yes
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
vendor: Gigabyte driver: r8169 v: kernel port: de00 bus-ID: 04:00.0
IP v6: <filter> type: noprefixroute scope: global
Device-2: Qualcomm Atheros AR5416 Wireless Network Adapter [AR5008 802.11bgn] driver: ath9k v: kernel port: de00 bus-ID: 06:00.0 chip-ID: 168c:0023
class-ID: 0280
Message: No Bluetooth data was found.
Message: No LVM data was found.
Local Storage: total: 1.46 TiB used: 122.76 GiB (8.2%)
family: Driven SSDs size: 111.79 GiB block-size: physical: 512 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: BBF0 temp: 24 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 295d 22h cycles: 5269
read: 5972 GiB written: 10366 GiB Pre-Fail: retired block: 100 threshold: 3
family: Micron Client SSDs size: 447.13 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: R013 temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 57d 14h cycles: 826
written: 3.95 TiB
family: Green size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
sata: 3.0 speed: 3.0 Gb/s serial: <filter> rev: 1A01 temp: 26 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 74d 4h cycles: 2428
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22NS40 rev: NL02
dev-links: cdrom
used: 122.76 GiB (28.0%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: 93ad7007-7506-4571-a86d-1e002de5f073
used: 280 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 585C-E1F5
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: Recovery
uuid: CA32DC2F32DC226D
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 44DC-D11A
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 111.16 GiB fs: ntfs label: N/A
uuid: B0C6EF69C6EF2E72
ID-5: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ntfs label: N/A
uuid: DE144B50144B2B3B
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-8: 5-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 5-1.1:3 info: Razer USA RZ01-0036 Optical Gaming Mouse [Abyssus]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1532:001c class-ID: 0301
Device-2: 5-1.2:4 info: Cooler Master MasterKeys Pro L type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 2516:003b class-ID: 0300
Device-3: 5-1.4:5 info: Realtek BillBoard Device type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 0bda:5400 class-ID: 1100
serial: <filter>
Hub-9: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 219 Uptime: 14m wakeups: 0 Init: systemd v: 247 tool: systemctl
flatpak: 0 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.0
noam
10 April 2021 12:39
5
Thanks again for the help, and sorry for the delay in my responses…
I’ve got the desired configuration:
LTS kernel running: 5.4.108-1-MANJARO
Nvidia driver from repo: 460.67
Still have an issue with the shutdown/reboot.
-- Journal begins at Fri 2021-03-12 19:47:53 IST, ends at Sat 2021-04-10 15:36:24 IDT. --
Apr 10 15:21:23 manjaro kernel: proc: Bad value for 'hidepid'
Apr 10 15:21:47 manjaro kernel: proc: Bad value for 'hidepid'
Apr 10 15:21:51 manjaro sddm[678]: Unable to find autologin session entry "plasma.desktopplasma.desktop"
Apr 10 15:25:00 manjaro pulseaudio[1085]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Few things about my system which may be related.
I have 2 monitors connected via Daisy-Chaining Display-port.
Fabby
10 April 2021 13:36
6
The last log doesn’t contain anything… Do you shut down using a REISUO when you cannot shut down?
noam
11 April 2021 05:20
7
Yes, once the monitors are off and the system looks like nothing happens, I used REISUB/SUO.
Fabby
11 April 2021 10:03
8
If you remove:
does it work then?
(just trying to make the config simpler because I’m stumped by your issue)
noam
11 April 2021 20:16
9
OK,
Looks like reboot is the only issue I have currently.
Shutting down works, it takes more than 3 Minutes but it works.
I get an error regarding:
umount: /oldroot/sys: target is busy.
I found this thread: Hanging On Shutdown: umount /oldroot/sys: target is busy
Tried following it but it didn’t help, I’ll need to retry that again, I’ve might miss something.
I’ll try working with only one monitort and will update it’s effect.
Fabby
11 April 2021 21:16
10
That’s a bug in the Manjaro kernel: it can be safely ignored. (I have this too)
Try:
sudo reboot
and report back, please?
